9
Everything posted by Michael
Next Gen Z will be lighter & cheaper! Good or Bad?
Michael replied to ArchetypeDatsun's topic in Non Tech Board
Maybe, just maybe, fuel efficiency and environmental considerations will finally drive manufacturers to aggressively reduce vehicle weight. And maybe, just maybe, that weight reduction will retain power-to-weight ratios by reducing HP less than reducing weight. In other words, I'm OK with a smaller and less powerful engine, provided that the overall vehicle is proportionately even smaller. My daily driver is a 1991 Miata, with a hardtop. I did the convertible thing for a while, but have become jaded and now prefer a proper hardtop. Maybe their ND generation will revert to the original simple/light model, maybe not. But the current Miata, the NC, went the same way as the Datsun Z and the BMW 3-series... heavier, cushier, more features, but not really "better". The contrast between my Miata and E36 M3 is amazing. The M3 just blows away the Miata in acceleration, braking, road-holding and high-speed handling, but the Miata is more fun to drive. It's more nimble, better connected to the road, more elemental, and just easier to drive. The M3 requires good clutch technique, proper timing of shifting and so forth. The Miata would be an easy car for a beginner driver to learn stick-shift... it's that easy to drive smoothly. But it's noisy and gutless. Keep in mind, however, that both the Miata and M3 are 90s cars... pushing 20 years old. That's half of the age of our Zs, but is NOT a new car anymore! At that age, cars require extensive preventative maintenance, and become a risk on long highway trips. Maybe this new Subaru/Toyota venture with their "compact" coupe is the threshold of a new trend. Hopefully! But the real problem is consumer demographics. Who is going to buy these light new coupes? There is no baby-boom generation clamoring for independence and high performance. Kids are buying boxy people-transporters, not 2-seaters. In Asia, the rising consumer tidalwave wants luxury and comfort, not acceleration and handling. The Chinese just love the huge gaudy FWD Buicks! Let's hope that things will improve by time that the Millenial generation reaches prime sport-car buying years (age 50 or so). Until then, I'm skeptical. -
The stock-brakes vs. big-brakes debate is interminable, but I want to interject with this twist: what does one do, if one is agnostic about brakes, but wishes to convert to 5-lug setup with minimal hassle? By "hassle" I mean new/repositioned calipers, proportioning valves and so forth. My application should be fine with stock brakes, pending proper component reconditioning. But I really crave the utility of 5-lugs for the greater wheel choices. Note that the 300ZX setup, which does have 5-lugs, is a fairly major brake upgrade too. For the rear, Modern Motorsports offers an option to redrill the stock stub axles (and drums?), but anecdotal evidence does not favor this option. For the front rotors, I am not aware of people redrilling for 5-lugs. Thoughts?
The E90 3-series has really lost its way... too large, too cushy, too heavy. Instead of the E90 M3, have you considered the "M" version of the 1-series? Indeed there really is no modern car that combines decent comfort/quality/features, acceleration and gas mileage. Maybe the C5 Corvette.... I drove an early model (LS1) for a couple of weeks, while acting as caretaker for a friend. It is moderately faster than my lightly-modded E36 M3, and I emphasize "moderately"... not enough to justify a replacement. Low-end torque is better, but overall feel is less connected and more fussy. Plus those seats are absolutely horrible.
There was an article in Hot Rod Magazine a few years ago, on installing a 2JZ in a 1967 (?) Camaro. Then there was a torrent of irate letters to the editor.
Arizona Z 5- Lug Brake Kit... What Rims To Use?
Michael replied to Wheeler's topic in Brakes, Wheels, Suspension and Chassis
If I did the 5-lug swap (something that I'm contemplating right now), I'd love to run Weld 15"x10" Aluma-Stars in the rear, with something like 29.5"x11.5" drag slicks. But that will probably not clear the stock fender, the springs, or both. -
Electric fan affecting electric fuel pump?
Michael replied to Datz350's topic in Gen I & II Chevy V8 Tech Board
Off-topic here, but it sounds like you've stumbled on a conversion-project which essentially does run, but which suffers from myriad problems, because it was done cheaply and without love. This happens often. Presently you have the fuel-pump/fan electrical problem. Once that's solved, other problems will present themselves. And so on, for several months. But on the bright side, you have a more or less functional conversion, which you probably bought for pennies on the dollar. Conceivably a not-too-distant project will be swapping the powertrain to a 350 or 383, with a T5 or similar 5-speed, or a 700R4. You already have the foundation for it, and if enough minor annoyances such as the fan/fuel-pump conspire against you, eventually you might decided to rid yourself of these problems with one concerted effort - namely, a full powertrain swap. -
The electric fan should have a heavy-gauge black wire to ground (say, 12 gauge or even 10 gauge), a heavy red wire going to a source of +12V (also probably 12 or 10 gauge), a "control" wire which goes to a switch that engages current-flow, and possibly a fourth wire connected to a water temperature gauge, which also goes to a switch of sorts. It sounds like the electric fan was miswired. Cooling fan companies such as Flex-a-lite (the brand that I happen to have, but others should be similar) should have wiring diagrams for free download. -
Good gas mileage is mainly about engine tuning and engine management. I don't wish to start a carburetor vs. fuel-injection debate here, but the preponderance of modern practice gives the nod to the tuning advantages of fuel injection. This, I think, is mainly why the LSx engines are delivering better mileage (in most cases) than the older small-blocks. My own example is atrocious: it gets single-digit mpg, but that's mostly because I am inept at tuning, and the carburetor is mismatched to the engine. The second variable is gear ratios and the rpm at which the engine achieves peak volumetric efficiency. Mismatch those two, or end up with too deep of a top-gear, and mpg will suffer. The worst case is a mild engine forced to rev high because of a deep rear-gear ratio and no overdrive. Boiling this down to a simplistic list: - everything sorted out, excellent tune: high 20s - modern fuel injection or very good carb tuning skills: low 20s - mild engine, mediocre tuning skills: high teens - aggressive engine, and/or tuning mistakes: low teens - incompetence: single-digits.
My story doesn't involve serendipitous encounters with smashingly good deals, negotiations with parents, Craigslist scores or barnyard finds, or teenage infatuation. My foray into Z's began in my late 20s, after spending a decade driving various nondescript Toyotas. At the time I was living in Los Angeles, going through graduate school, and bemoaning my impending entry into the "professional world" without getting the sports-car bug out of my system. But I didn't want a "new car" - too expensive and too tame. I bought a Z because I was interested in a limber, attractive older sports-car with a large engine compartment that could seamlessly receive a V8 transplant. I never really wanted a muscle car or a classic sports car, but an eclectic blend of both. The choices were something English or nominally English (Shelby Cobra, Sunbeam Tiger); the Z; an Opel GT; and a handful of other 70s Japanese cars such as the Celica or RX-7. But I didn't want a convertible, which ruled out the British options. The Opel and RX-7 really had rather small engine bays (especially the Opel), and the Celica was too much like a generic coupe according to my tastes of the time. Plus, I always liked hatchbacks. The Z was a natural choice. My first attempt was a 1972, with awful rust problems, as it turned out. My second attempt was a reasonable rust-free 1978. My current car, bought at the twilight of the 20th century, is a combination of those two. It has been an on-again off-again romance. After many years of dead-end and angst-ridden tribulations, the car finally runs, albeit turning it into something genuinely enjoyable and reliable will require many more years and dedication of labor. The irony is that today, my daily driver is a Mazda Miata - a convertible, a lowly 4-cylinder lacking grunt or poise. But there is something endearingly charming about it, not the least of which is the remarkable reliability for a 20+ year-old car with sporting pretensions. Sometimes I fantasize about getting another Miata for a V8 swap, but it's so much more difficult in the Miata than in a Z, that a person of my lethargy and ignorance would be completely overwhelmed. You see, it takes decades of sports-car ownership to genuinely appreciate one's limits!
Might be a worthwhile deal if negotiated down to $500, especially if it comes with the young lady in the 3rd photo in the Craigslist ad.
Staring tear down for V8 Conversion
Michael replied to DatsunLSX's topic in Gen I & II Chevy V8 Tech Board
If I'm not mistaken, the mounting location on the tailshaft is different between the TH350 and TH400. That however should be a relatively minor issue. The larger issue, as MikeKZ pointed out, is the ratios in the TH350/400. -
It's probably not realistic because most drill presses are not designed to take lateral loads on the drill chuck. They will chatter, producing a rough and uneven cut. Also, the drill press frame is insufficiently rigid, and the connection between the work-table and the shaft supporting the drill motor/belts/chuck is too flimsy. A better choice is buying a used mainstream mill. Decent examples can be found for around $1000. In the long run, you'll spend more money on attachments (various cutters, end-mills and so forth) than on the machine.
Indeed, ironies abound. Congratulations on a successful business and on severing the umbilical from corporate life. Personally, I prefer to say "no" to capitalism entirely, and have spent my so-called adult life working for the federal government. It oozes corporate-speak and the smarmy culture of management, but at the same time, the overall impotence of managers gives employees very wide freedom, especially if those employees are technical specialists and define their own job.
Pondering this for a few days, maybe this thread is a good occasion to revisit the BBC vs. SBC debate. So I'm going to revise my recommendations posted earlier in this thread. Back in the mid 1990s, when first having come across the JTR book, my initial sentiment was towards the small block. This was before the LS series and before the explosion in aftermarket support such as mainstream aluminum heads. Then I met the fellow who ended up doing the roll cage and other fabrication for my swap. He was a die-hard BBC guy, coming from a 1970s drag racing background. He swayed my opinion to big blocks because stock vs. stock, they had a durability and torque advantage that was difficult for small blocks to match. And back then, advantages of stock engine architecture were important. Thus my build was based on a Mark IV 454 BBC. Now having lived with a BBC for a while, I have second thoughts. I did not realize how much of the engine components would eventually be replaced with aftermarket parts, rendering the stock engine's advantages or disadvantages moot. And technology has moved on, of course. For example, now aftermarket cylinder heads are reaching flow numbers that 10 years ago were impressive even for big blocks. In the proverbial "if I were doing it all over again" - in 2012 - I would probably go with the LS series, especially if I could find a donor engine in good condition. The only exception is if the goal was truly maximum HP. Then an aftermarket BBC-flavored block (well over 500 cubic inches) starts making sense. Today if I were doing the V8 Datsun swap, I'd probably first purchase a running F-body from 1998-2002, and use that as the donor.
I would spend the $200 on sufficient quantities of intoxicating fluids, such that the paint job and condition of the body would begin to resemble that of a championship-winning hot rod. If genuine reality is intractably out of reach, compensate through solipsistic surrogates. The keenest satisfaction is not in the production of a beautiful machine, but in the reorientation of one's sensibilities to obviate the need for great effort towards ultimately unsatisfying pursuits.
Big blocks have their advantages, and these are not merely originality or the appeal of exotica. However, don't bother with a 396, unless it's a mock-up for engine installation. Build at least an overbored 454 (ideally with a stroker crank), or go with an aftermarket block. The complexity and cost of a big-block swap are only borne by aggressive displacement and concomitant power levels. Definitely use high-end aftermarket heads, a mechanical roller cam, good bottom-end components and the appropriate intake and exhaust systems. Plan on $10K+ for a suitable engine, and driveline components to match.
A mismatched combination with an unknown history sold by a neophyte (or cagy) seller... Maybe 5000 rpm usable redline and 5500 rpm never-exceed redline. Figure on 220 ft-lb torque and 170 hp.
torque curve available?
Indeed, Problem 3.81 is incorrectly worded, and that would confuse students. But resolving vectors into their components, finding magnitudes and directions, etc., is essential for mechanical/aerospace engineers. Something else to note... as you become more senior as an engineer, you'll be doing far less calculation and far more writing and speaking. So after enough time on the job, the primary skill set is supplanted by more of a humanities-type of skill set. The math however continues to be important, not through direct calculation, but in understanding the equations and how to simplify them for making quick estimates. One route to consider is to switch to a "mechanical engineering technology" major at community-college. Get an associates degree that qualifies you to operate CNC machines and the like. Old-timer machinists are losing their jobs because they can't program the new machines. Get into that niche, get some practical experience, and a few years in the future you can decide whether to return to 4-year college for your BSE. Your employer might even offset the tuition.
To be pedantic, this probably belongs in the "drivetrain" subforum. The "world class" T5 is probably adequate for most applications, as the limiting factor will likely first be rear-wheel traction, rather than driveline stresses. The disadvantage of most domestic 4-speeds is the narrow spread between 1st and 4th gear. For a torquey engine in a light car, all of that shifting will be superfluous. And the highest gear is still too deep for comfortable highway cruising. A good example is my own mistake: I went with a Doug Nash 5-speed. Yes, it's a 5-speed, but 5th gear is 1:1. First gear is 3.27:1. So the highest to lowest ratio, 3.27 to 1, is quite narrow. The 4-speeds are even worse... some of them have a 2.2:1 first gear and 1:1 fifth. Unfortunately manual transmission options have not been improving over the years with anything close to the vigor that we've seen on the engine side. When the JTR manual first became popular, in the late 1990s, the LS engine series was just starting to hit the market, and the Datsun swap of choice was the traditional carbureted 350. The manual transmission choices were T5, the then-cumbersome T56, and the 4-speeds. Well, the T56 is still cumbersome. Just about the only change in the past dozen+ years has been the aftermarket support for the T5 (Forte's, G-force) - which is substantial and very good, but also very pricey ($2500 for a G-Force T5 upgrade).
Replacing the pistons likely means rebalancing the rotating assembly, and buying new rings. You'll need to confirm piston-valve clearance using a mockup installation with clay. Even if everything fits mechanically without interference, as Pyro and others have mentioned, the performance gain is incremental at best. And if you currently have a fairly well sorted combination, changing one component tends to trigger a cascade of requisite changes to keep the overall combination consistent. That of course raises costs and promotes risk. My recommendation would be to do nothing, assuming that you have a reasonably well-running engine, until you are ready for a significant upgrade in power. Then get the latest fancy aluminum heads, mechanical roller cam, forged pistons with the right compression ratio, rods, and so forth. The cost advantage of a Chevy small-block is in the low price of the as-is combo. Adding individual components to any engine, no matter how common, quickly gets to be expensive.
I'm all in favor of lightweight 2-seater sports cars rolling on 14" or even 13" wheels... something like my 1991 Mazda, only even lighter due to use of modern materials and chassis engineering. Say 120 hp from a 1.6L 4-cylinder (perhaps horizontally-opposed) in a 1800-lb car... decent performance and good fuel economy simultaneously. I don't believe that crash standards would be a problem, if bumpers are properly integrated into the chassis and the proper analysis (validated by testing) is done on crumple-zones and the like. The problem is market acceptance. People who crave this type of car tend to be ones who buy >20-year-old cars, not the latest models.
One possibility is to run bracing-tubes along the transmission tunnel. Triangulated bracing would be welded in between the front strut towers and the firewall (piercing the firewall), then continue along the transmission tunnel, and then kick up again to meet the bracing connecting the rear strut towers.
It's going to be a tough sell, considering that even economy cars in the current market are leaving the factory floor with 15" wheels. About the only market for 14" wheels is muscle-car restorations - and those probably are more for appearance than for handling prowess. I recently had a similar problem with my 1991 Mazda Miata, which is still on its stock 14" aluminum wheels. Its factory tire size is 185-60R14, which is becoming quite rare. As with S30 Zs, most NA Miata owners are "upgrading" their wheels to larger size... and this is on a car with maybe 90 hp to the rear wheels! My solution was to "downgrade" to 185-55R14 tires (Yokohama S-drive), which are somewhat smaller diameter and therefore throw off the speedometer, but have excellent grip. The lighter weight of the smaller tire carcass is also a bonus. On a brighter note, 15" wheel diameter is very popular for drag racing. So just a 1" increase greatly opens up the tire selection.
