9
Everything posted by Michael
Finally drove the thing this afternoon. Main impressions... the power is fine, but lacks the impact of outright rocket thrust. Perhaps my standards are unrealistic. With the close-ratio gearbox, more time is wasted in shifting than in actual acceleration; best results are starting in second gear, and immediately shifting into 5th. RPMs rise so quickly that I almost certainly over-revved the engine on several occasions. With four over-stretched rod bolts, this does not bespeak a comforting feeling. The good news is that this time, my safety-wired rosette of bolts holding the adjustable timing-sprocket seems to be holding, and there is no embarrassment of said bolts backing out and grinding into the timing cover. Speaking of timing, the engine likes around 12 degrees at 900 rpm (with vacuum advanced plugged). It starts relatively easily in the warm weather that has finally visited us in Ohio. This (the easy starting, not the weather) is a welcome improvement over the trouble that I had circa 2006, when I last seriously worked on the engine. My colleague and I took video of the "first drive", or thought that we had; sadly, the camera was on the wrong mode, and instead of amateur video, we have amateur images of weeds growing along my driveway. In a few weeks we'll try again, and I'll try to upload something to a video hosting site. Bottom line - yes, it's nice to have finally overcome the vast plethora of seemingly trifling difficulties that plagued this effort for over a decade, combining in their vile cabal to quell whatever urge one musters to make progress. But as I posted some weeks ago, the completion is anticlimactic. When I was in my mid-20s, I wanted brutal acceleration at all costs, convenience, reliability and everything else be damned. Now, approaching 40, I'd prefer the easy litheness of my Miata combined with the unhurried thrust and poise of my M3, but instead what I have is a Japanese muscle car. It's basically a Chevelle 454SS, minus 1200 lbs. Where to next? For as long as I have garage space, the Z will remain parked within, to occasionally be trotted out for a mild day's tilting at windmills. Maybe some day I'll take it to a chassis dyno for the obligatory bragging rights (or plaintive consternation over making 100hp less than Desktop Dyno is predicting - few things are so depressing as a great theory, so long oblivious to practical criticism, defeated by a 10-minute experiment). My advice to prospective swappers: keep it mild. And any operation so extensive as to keep your car on jackstands for over a few weeks, is best delayed until you're a wizened old man, doting in retirement on empty acres, empty save for weeds and field-mice, silent save for mating calls of toads rejoicing in the incessant rains of languishing spring.
Newbie trying to plan first build
Michael replied to SonewSodumb's topic in Gen I & II Chevy V8 Tech Board
The most troublesome, labor-intensive, frustrating and incommodious part of the Datsun V8 swap is rust abatement and the related chassis-reinforcement. Rusty car ==> project will drag on for years. So spend the extra money on a reasonably “rust-free†chassis (there are no entirely rust-free Datsuns in the known universe). The second most troublesome portion of the swap is the engine build. If you go the Gen-1 or-2 SBC route (350, 383, 406, etc.), be prepared for a rebuild and cost outlay for aftermarket parts: heads, cam and valvetrain, intake/carb, and so forth. Likely the eventual cost will be comparable to the LSx series. Reasons for building a traditional small-block (or big-block): (1) this is where your expertise lies, or (2) you have an established supply-chain for the traditional engines but not for the newer ones. Otherwise, go with the newer family. I say this as some one who built a traditional engine, and now regrets it. The actual swap itself – engine mounts, cooling system, charging system, fuel routing, electrical, exhaust – while not trivial, is not particularly difficult, IF you have a decent host vehicle and a decent engine/transmission combination ready for the swap. My recommendation is to first find a suitable Datsun, that runs reasonably well, that can be registered as a street car. Drive it for a year or two. Worry about the rust, about the suspension, about the bodywork, the interior, whatever. And only then, once you are familiar with the car and aware of its weaknesses, would you be well-positioned to work towards a swap. Good swaps take years. Unsuccessful swaps take decades. -
So I am looking at this 400 SBC...
Michael replied to Z for XC's topic in Gen I & II Chevy V8 Tech Board
A 400 SBC from a 1977 Suburban will serve as reasonable foundation, but don't expect impressive hp. The top model for that year, a 454, would barely crack 200 hp. That said, resist the temptation to make even minor modifications. It is easy to ruin an otherwise serviceable combo by tinkering here and there. Example: installing new flat-tappet cam; excellent way to wipe the lobes and to send lobe/lifter material all through the oil gallery and into the bearing shells. So, buy the engine, keep it stock, get your car running, become familiar with it, and only subsequently entertain notions of modifications. BTW you mentioned that your Z went through a stint with a 454. What happened? Why was it removed? -
Some of you have been following my progress since at least the 20th century. There – is that sufficiently pompous? After inveterate blunders, rebuilds, disassemblies and sallies at improvement, the 461 is now finally installed in my Z. As of 6 pm EST, 17 April 2011, the big-block roars back to life! Have not driven it yet – still need to bleed the clutch and to fill the gearbox with fluid. But after some fiddling with the carb, the engine achieved a stable idle at 850 rpm, without too much coughing or apoplectic shaking. A bittersweet achievement, as the lifters clank unpleasantly and the timing is troublesome to adjust. No great flaws, nothing that a little enlightened patience can’t fix. But the disappointment is that now having driven newer and more refined cars, I’ve lost the youthful urges for the visceral thumping of loud mufflers, large cam and so forth. However powerful it may be, there is less joy than disaffection. I find no elation, no relief, no self-satisfied feeling of achievement, even if this time the rockers really are oiling (they may not be), the freeze plugs are holding, and the exhaust is no longer brown. My next build, if there will be one, will not be a traditional American V8. Henceforth my enthusiasm for these engines will be purely passive. Perhaps I’ll attempt to turbocharge my Miata, or maybe swap in a silky fuel-injected V6. Something that gets more than 7 mpg and doesn’t require a helmet just to drive around the block. But now comes the pedestrian task of better tuning, sorting out the electricals. Don’t wire your kill switch to the battery positive cable – it does nothing while the alternator is charging. I know, because in a panic I had to kill the engine, and even outright removing the battery failed to achieve this. The only solution was to pull the ignition wires from the distributor!
First, be especially mindful of German car registration requirements, if your objective is to enjoy this car in Autobahn driving while stationed in Germany. I hear from an acquaintance who now works for Siemens in Germany, that registering a modified Datsun would not be an easy undertaking; much harder than say in California or other US locales known for automotive stringency. They have their own rules on roll cage design, bumper height , and many other factors. If you already have friends stationed in Germany, ask them about car registration and whether they were able to secure any sort of exemptions owing to their military status. Second, the lack of torque is not by itself an advantage, even for a high-rpm engine. Instead what happens is that an engine producing high volumetric efficiency at high rpm ends up being comparatively weak in low-rpm torque, because it has poor volumetric efficiency down there. It is self-defeating to intentionally reduce displacement in an attempt to bias in favor of high rpm power. Before you receive a barrage of links to books and web sites describing suggested builds, just consider the two main ingredients: the engine should breathe well at high rpm (carb, intake, valvetrain, heads, exhaust) and the rotating assembly (crank, rods, pistons, valvetrain) should remain robust at high rpm. That’s it. It’s not about rod-to-stroke ratio or bore-to-stroke-ratio or whatnot. Also note the gearing (tire diameter, rear axle ratio, transmission ratios) and what rpm range your desired cruising speed will place you. With a tall 5th gear (0.6 or whatnot) and a 3.54 rear, you may find that 7000 rpm is completely unnecessary. From my forays on Autobahns mostly in central Germany (general area from Darmstadt to Bonn and the Ruhr and west, up to Bremen, over to Braunschweig), it is quite rare to find an unlimited spot where you can buzz past around 240 kph; there’s too much traffic and too many curves in the road. Most “unlimited†stretches only allow getting up to around 200 kph before the next speed-limit warning sign looms ahead. There are a few satisfyingly wide, flat and comparatively empty stretches, such as south of Frankfurt airport, heading towards Darmstadt. But that’s only around 20 miles. So in reality, German vs. American driving (especially in Arizona) would not be tremendously different.
I Bit the bullit on a 406!! SBC 530 hp and 665 nm tq
Michael replied to frank280zx's topic in Gen I & II Chevy V8 Tech Board
Did the original poster buy a transmission? There was mention of doing so in April... and now it's April. Spring, the time for unbridled acquisition. Reconnecting my Doug Nash 5-speed to my BBC has driven home the obvious points that a heavy transmission isn't a good thing, and lack of a steep overdrive isn't a good thing. For large-displacement engines with mild tune, what we need is a small number of gears, very broadly spaced, with a steep first (used only for drag racing) and a very tall nth gear (used only for lazy highway cruising). In "normal" conditions a 2-speed will suffice, with the lower gear for starting/puttering, and the higher gear for rural roads and highways. So how about these gear ratios: 4:1, 2:1, 1:1, and 1:2? Manufacturers, are you listening? Pete's right about the G-force T5; best compromise of weight, shifting, and strength. Actually, even their gear ratios are not too bad, for the real world. -
Rear main seal leak – water, not oil!
Michael replied to Michael's topic in Gen I & II Chevy V8 Tech Board
Installed those brass freeze plugs (bought the kit from Jegs) last weekend, using Permatex #1 adhesive (brown, dries semi-hard, semi-ductile). So far, no leaks. Engine goes in next weekend, and might be fired up the weekend after. Bought a new HEI-style distributor (supposedly with some upgrades) and flushed the fuel system (has been sitting since fall of 2006). So, wish my luck - will this be the first "truly" successful firing of this engine since 1999? -
1990-1997 Mazda Miata
How can the typical airline passenger be SO dumb?
Michael replied to Globerunner513's topic in Non Tech Board
Singapore Air is definitely the best… best stewardesses in the best uniforms, best food, best in-flight video options. After flying various Asian airlines, European airlines, whatever – and then boarding a US flag carrier, the most obvious indication that it’s a US-flagged flight is that the stewardesses are almost spherical, gender-ambiguous and surly. Ain’t no place like “homeâ€. My employer negotiates airline ticket fares every fiscal year. Sometimes our rates are fairly low ($600 round trip to London Heathrow, from the US); other times they are outrageous ($1200 round trip from our Midwestern city to Washington DC). In no case are they ever cheap. But we get the same class of service as the fellow who snagged $95 tickets on Expedia or whatnot. I never check baggage, never carry liquids/gels, and usually have priority boarding. So the boarding process is relatively painless. Still, if I’m going to spend 14 hours inside a depressurized aluminum tube, it would at least help to be served by pleasant young ladies who know how to smile. -
5 Stud Front Hub Conversion
Michael replied to diggs's topic in Brakes, Wheels, Suspension and Chassis
2nd generation Chevy Camaro front rotors also fit the S30 Datsun front hubs nicely (not sure about offset, or what to do regarding mounting brake calipers). -
Aesthetics? Very pleasing. Weight? Not so much.
I don’t have intelligent advice to offer about component replacement for gaining another 20-30 hidden horsepower, but after working on one “high-performance†engine for many years, it’s worth noting the importance of reliability and simplicity over maximum performance. Maybe the present combo has insufficient duration to move the torque-peak to the rpm that you prefer, or the hydraulic roller cam will float the valves before the hp peak noses over. Maybe the headers aren’t scavenging optimally and you get a midrange dip in torque. Or the intake is poorly designed and some cylinders are running richer than others. If this isn’t a sophisticated competition engine, are any of these drawbacks genuinely profound losses? I would opine that a reasonably workable combo – where bearings aren’t getting spun, where valve guides are not puking oil, where the spark plugs are not fouling every 100 miles, where the rings are holding compression and the engine doesn’t stutter when you mash the throttle because the carb’s power-valve blew out insidiously – well, that combo is already a pretty good combo. And the route to improvement is through incremental massaging of an already proven combination. Even the most expensive and most exotic engine only makes about 1/3 hp sitting on the engine stand – and that’s if you’re in good shape and can run swiftly while pushing the stand.
My turn to seek advice about bikes and relationships
Michael replied to auxilary's topic in Non Tech Board
You guys are so jaded and cynical that you refuse to accept the possibility that maybe this girl's intent by nagging and prohibitions is merely to protect her guy. "Not allowing him" to purchase the motorcycle is perhaps a benighted form of expressing love, as opposed to jealousy that the bike would overtake the relationship or censure that it's an irresponsible spending of money. Have a reasoned conversation with her, explaining with cogent statistics that more displacement in a motorcycle does not correlate with risk of highway injury. Then explain that having considered your options, you are convinced that buying the bike is in your best interest. Her reaction will expose the nature of her sentiments: frustration or fear = OK, reluctant acceptance = excellent, disgust and exasperation = bad. -
The real travesty is when camera megapixel count is far greater than camera lens quality or capacity to focus. Then you get a huge (in memory) photograph at poor quality. Most of us use point-and-shoot cameras to record all things automotive. Today these cameras are often 10Mpix or larger – but the image quality is wasted on anything larger than maybe 3 Mpix. I make it a habit to down-sample in Photoshop all images from my point and shoot (Panasonic Lumix).
Mongo, you're absolutely right! It was a truculent freeze plug, hiding unobtrusively behind a coat of paint, but with a rusty gash exposing a weep-hole when prodded with a screwdriver. Evidently, freeze plugs rust when a block is left sitting for 5 years! -
1978 big block Chevy (stock block, crank, rods; everything else aftermarket). It’s been a long history, for those of you who have been following…. Since 1999. The latest escapade involved a disassembly, cleaning and reassembly to investigate why the pushrods would not oil when the oil pump was primed with a drill. During reassembly, I overtorqued a couple of rod bolts. I decided to proceed with reassembly, with all fresh gaskets (except for head gaskets, which are recycled after the last build, circa 2008; but the engine was never run after the last build). After reinstalling the engine, there was a water leak from one of the freeze plugs. Reinstalling a freeze plug in-situ proved to be impossible, whence I had to pull the engine again. With the engine out and a fresh freeze plug reinstalled, I refilled the water jacket. All freeze plugs held, but there is a significant water leak from the rear main oil seal! Let me repeat that – water leak (NOT oil!) from the real main old seal. How is that possible? This is a gusher, not a trickle. And it must have been there for a while, since the bottom of the bellhousing is very rusty – precisely where dripping water would have collected. Now what?
At that level of performance, why not consider a mechanical roller cam?
$70-100 per night may be wanton excess, but spending $50/week on beer and pub-food is a wiser investment than “saving†$50/week for auto parts. Drive reliable but inexpensive cars, eat well, and never buy more sophisticated auto parts than you can use in the near-term. Ever since I bought a $2500 Miata, making a whopping 100 hp, I’ve been a lot less concerned about making progress on my “500hp†Z. Now the spare change goes into occasional small luxuries like a tin of caviar or a nice bottle of wine. Much higher smiles-per-dollar than a fancy ignition system that I wouldn’t even hook up until 2019.
If they had a genuinely negative opinion of the car, they would have berated the car itself, and not its national origin. The fact that the insults were directed against Mexico is a sort of back-handed compliment on the car.
Time for the annual update? At some point in the not too terribly distant future, we might have forum members who weren't even born when the site first hit the cyber airwaves!
The romance of snow dissipates quickly. By the second or third storm, the spark is gone, and all that’s left is marital strife. Here in southwest Ohio the total snowfall has been moderate this season, but the cold has been sufficient to maintain almost uninterrupted snow cover from mid-December through the present. The combination of the length of my driveway and my laziness means that it (my driveway) remains unplowed. Yesterday I pulled the M3 out of hibernation for a brief jaunt to get the engine oil warmed up. Well, I ended up getting stuck in my own driveway – had to call AAA to pull me out! My present daily driver, a 1991 Miata, does fine in the snow/sleet/ice with snow tires – light car, decent traction. Even so, rural commutes are unpleasant. Any bridge or overpass could be iced over, and even with moderate snow cover there are drifts onto the roads from the various farm fields. Winter is supposedly a great time to get car work accomplished – but not in an unheated garage! You can bundle up to remain more or less comfortable, but skin sticking to wrenches isn’t a comfy feeling. Gloves, you say? Yes, but gloves soaked in coolant and oil aren’t comfortable either, unless you crave that sticky clammy feeling on your palms.
superchevy.com built a 400hp SBC for $1000
Michael replied to logan1's topic in Gen I & II Chevy V8 Tech Board
Now that's a more realistic magazine engine build! These guys bought some nice parts, spending $1800 for some ported AFRs (vs. the $600 Vortecs installed originally)... to lose 18 ft-lb of torque at 3500 rpm. Folks, this is exactly what happens in the real world. Sometimes we cut corners with massaged stock/cheap parts, and the combo works wonderfully. Then we get excited over the possibilities, "upgrade" (at high cost) and end up with inferior results. -
I don't see how a Z32 V8 swap would be any easier, cheaper or more "grass roots" than an E36. BTW there is a huge complexity/cost leap between the E36 and E46. In terms of engine bay size and overall simplicity, why not just consider the S30? It used to be that the S130 had an advantage of being "newer", cheaper to source, commanding less of a rarity premium. But in 2011 both S30 and S130 are fairly old cars. Your location is not clear from your signature file, and of course car availability depends strongly on location. In the U.S. Midwest, the S30 and S130 are equally rare. Chassis reinforcement becomes a priority when there is either extensive rust damage, or ambitious horsepower goals involved. For a mild 350 in a reasonably rust-free body, one should probably not worry about chassis reinforcement in any of the Z series. Personally I keep returning to the observation that the hard part is neither accomplishing the swap itself, or finding a suitable vehicle to receive the transplant, but building a strong engine. Lots of people get excited about doing a swap, but if the donor engine is relatively stock, perhaps the better bet would have been mild hotrodding or turbocharging of the stock engine. If you already have your engine sorted out, then the eventual swap candidate is not so important.
What happened to the original poster? Was the car eventually sold, or parted out? Now consider the fellow on the receiving end – the one making the lowball offer. He gets a great deal, right? Maybe not. Let’s call the purchase price $17K. He did not build the car, so he will likely be helpless when something breaks, and would be oblivious to festering ailments. So in a few months he’s looking at a $5000 bill for a proper repair. Either he pays, or gets screwed by an incompetent mechanic –or both. Then what? Then the car sits for a while, and next year is up for sale again. Asking price, $20K. The sale closes at $12K. Then wash, rinse, repeat. After a few circuits on Craigslist, the car hits the junkyard circa 2016, or gets sold for scrap. You know, I started out with a $700 1978 280Z. It had a smidgen of rust, but was otherwise whole, drove well and most of the electrical bits still worked. It started every morning and even the windshield washers worked. I bought it 270 miles from my then-home, drove it back at spirited speeds, and commuted in LA traffic in it for months, before it went under the knife for an engine swap and chassis augmentation. It’s been sitting for 11 years. I’m a reasonably fit person, so when I push my Z, it develops maybe 1/3 hp. The original rating was what, something like 170 hp? So I spent $XX,XXX on losing 169.67 hp. How’s that for depreciation? But annualized over 11 years, that’s not so bad. Now suppose that instead of sinking the money into a hobby car, a conscientious fellow would have invested the money in the stock market. Let’s see, 11 years ago, the S&P 500 was sitting at 1500. Today it’s struggling to reach 1300. Meanwhile, cumulative inflation over the past 11 years has been around 30%. How’s that for an “investment� So therefore I say, the wise man was the fellow who spent $50/week on food and alcohol. He was sated and at least moderately cheerful, on a recurring bases. At least, when you spend money on things that you put into your body, you don’t worry about selling the byproducts for a profit.
All things automotive are astonishingly more expensive overseas than in the U.S… car purchase price, registration, maintenance, gasoline, and so forth. Exhibit A is Singapore. They have a sort of lottery and waiting list for the privilege of being allowed to operate a car on public roads. The price of that “registration stamp†fluctuates with the economy, and since their economy is doing well, that stamp is now astronomically expensive. One of my hosts was driving a Lexus RX350 (the Camry-based SUV)… which cost him $150K Sing (about $110K USD). But incomes, for comparable work, really are not any higher in Singapore than the are in the U.S. Exhibit B is the UK. New cars retail for roughly twice as much as in the U.S. – and that’s after the British Pound declined from $2 USD to its current level of around $1.55 USD. And their gasoline is around 1 Pound per liter….which works out to around $6 at the present exchange rates, with the strong dollar. I am ceaselessly amazed in my travels, how in most of the developed world outside of the US, people earn less money, pay higher taxes, pay more for the same products than we do – and yet, they’re not really in debt and appear to enjoy a reasonable standard of living. How does the arithmetic work out?
