I know nobody has mentioned this, but looking at the settings you're doing one squirt per cycle. I had no luck getting my setup to start on that and had to go to two squirts per cycle. Also I've read some people had trouble with alternating injection. I did notice a difference in idle between simultaneous and alternating. Alternating was rough. Switch to two squirts and try simultaneous injection.
Also check your plugs after trying to start it. If they're wet, you have way too much fuel. Look at your tables, cold start enrichment, etc...
If the plugs are dry with no deposits, see if your injectors are even firing. I had the two fuses on my injectors leads blow one time without me noticing. I never did figure out why but it never happened again. Get an extra set of plugs and a spark plug cleaner from Harbor Freight. It'll save you a lot of time and money. Plugs tend to foul real easy when trying to get this thing started.
Turn off and remove your wideband! At least until you get it running. You wouldn't want to damage the sensor just trying to get it started. You need to get it to at least idle on solid tables and maps then add the wideband back in.
Another thing that threw me. I was using a GM idle air control and it wasn't working (seems that happens a lot) I had to remove it and just set the idle screw on the throttle body to hold the plate open enough to get it started and idling.
Looks through everything. I think your maps are rich too, but that's just from memory (which is very foggy right now).
Oh and I don't know about EDIS, but I know a typical setup would never run 0.0 trigger offset.
