Outcome was a bit of a mixed bag... It would creep out 250-300 feet before I could build any boost, then launch violently.
The car starts building over 5 psi of boost finally around 5000rpm's. I get full boost closer to 5700 RPM's. My stall is WAY too low for the power band (4200, but footbraking closer to 3500), so it is useless. I will need something in the 5000+ stall range to make this combo work without spraying. I am concerned about tranny temps on a long highway run (like to Reynolds) that the heat caused by the converter slip could have me going through trannys. The other option is spraying it out of the hole from 3000 rpm's or so, to spool the turbo and bump me up into my power band.
I'll figure something out.
Mike
On a positive note, I guess, when the boost came on, Holy Cow!! Now I come to yet another dilemma... tires ... My 255/50/16 drag radials which have worked pretty well up to now, were going away on the top end. Both passes I made at 24-25 psi would just kill the DR's after the 1/8 mile and the car would get loose. I HAVE TO get something stickier or wider or both.
