calvin280zxt
Everything posted by calvin280zxt
  1. No smoke, didnt start again exept for the 100 rpm sputtering. Im thinking timing chain
  2. Just insured my car and drove for like 15 minutes then all of a sudden a big backfire out the exhaust and its dead. Havent had time to diagnose much yet, has gas, fuel pump runs, injectors fire and it has spark. Stock turbo 82 just did hei conversion since it broke down last time. Any ideas? It sort of fires as if the ignition is super retarded ran at like 100 rpm. Any ideas?
  3. Mine does that, runs fine at Operating temp and when cold, boggs in between. It comes on/off like a light switch
  4. My parts car my fenders flew up like wings on the highway
  5. I would run it for a week or two then change it and run a little bit in with each oil change 1/4 jug or so, 15-50 might be a liitle thick at startup contributing to the problem, i havent run any thicker oils though so im no expert
  6. That is 99% a bad lifter/s try running a quart of ATF in the oil, sludge etc can cause this and atf Has a lot of detergents in it. If that doesnt work you need to find some lifters or a solid p90 head. I have cured 2 cars start up knocks with atf. Usually a day or two and its fixed
  7. They are barely drivable with no turbo from my experience
  8. I converted mine to 5 speed literally bolt in job did it in a weekend
  9. Maybe brake stands are a canadian thing
  10. Bought an 82 s130 na 5 speed flintstone mobile for 100 bucks when i was 17, knew nothing about it. I actually bought it to crash up in the woods ended up loving it but it was so far gone. Can see all tires from inside the cab! Sold it for 400 bucks. Then bought it back a couple years later and drove it till tje shock towers poped through the hood! Always said id get another one if i found one and a couple years later i traded my car for an 82 turbo which i converted to a 5 speed and am in the process of restoring and making it fast
  11. Those symptom sound like theres no vacuum id start under the hood, the manual has diagrams. The originals are color coded so you want to map it out and get it working then change the rotten lines out. Its pretty confusing but once you decide which part the "vacuum transducer" etc etc is its not to bad
  12. Rotten vac lines Just fixed my own, except my cruise is only good for cold days now.. Heat goes higher the more gas it gives
  13. Some have a power passenger side lock. When you unlock the drivers side ( with the key) the other side unlocks
  14. Its going to rub any corosion Off of the 20+ pins that go to the ecu on this 30+ year old computer. Worked for me and lots of other people. Thats what
  15. Had mine on the road for a while, until it broke down. Fixed a lot of rust not all but i lowered it so its out of sight lol. Just fixed it by doing an hei swap 1/10 the price of oem
  16. Service manual is a good place to start
