seattlejester
    21
  1. If I eventually make enough mistakes, I think my car will finally be sorted. One of the things not on the list, but very apparent was a large dead zone in the brake pedal. Turns out you can't just play legos with these cars. I was able to source and have rebuilt a 15/16th master a long time ago, and threw it onto the replacement early booster I bought. Turns out in 73 and later, they started using a longer cap/bolt on the pushrod on the engine bay side of the booster that sticks above the surface. So my 280zx 15/16 master was never going to work well with the shorter setup. Taking it off I found there is a fair amount of adjustment and adjusted it to match a 280z booster I picked up from the parts store. Turns out that one was poorly adjusted as well. I tested the brakes with the wheels in the air and made sure they released, but I'm guessing the booster has to see vacuum in order to be in its functioning state. I drove down a small street with no problems, then when I got on the freeway with the vacuum going suddenly the brakes gradually came on harder and harder until the car would not accelerate. I was able to dial back the cap a few mm on the side of the road luckily being able to pull over in an extra wide shoulder and drive home without much issue, but please learn from my error. If you have this wonky combo, test your setup with the car running, and make sure you get some vacuum built up whether it is going down a hill or engine braking.
  2. Ok lessons learned. The 43 mm clevis from mcmaster car is roughly 6mm longer than the stock one so it is good for a quarter inch or so more length if needed. Decided to grab a new 280z booster for the correct push rod. Might as well get the bigger booster I figured. Turns out, not the same bolt pattern in the early Z cars. https://www.oreillyauto.com/detail/b/brakebest-brakes-4474/brake-systems-16456/brake-hydraulics-16513/power-brake-booster-11301/69bab478e25a/brakebest-power-brake-booster-remanufactured/535104/4566962/1976/nissan/280z?q=brake+booster&pos=1 Plus the interior side push rod that the clevis screws onto looked to be a 10mm thread. The engine bay side push rods are indeed markedly different between the early years and the later years The 280z ones seem to have almost 10mm of additional height on the rod cap/bolt. The one from the store sat with the tip protruding past the surface 22 or so mm. I played with the cap/bolt on mine (71 240z) and was surprised to find there was almost a solid inch of adjustment. The spacer on the booster that I believe comes with the master cylinder is roughly 9mm And I set my nut to sit above the spacer another 13mm It takes a 7mm socket to undo and a pair of vice grips to hold the push rod which you can pull out a good deal. I believe pulling this can result in the reaction disc falling off in older boosters so be careful. Leaving the adjustment out and not bottomed out also requires a lock nut so be advised. I set mine to match the store bought booster, which showed 22mm above the face of the booster. I figured this was pretty close to the 10mm number I read with the 10mm spacer that the master cylinder sits on, so I adjusted mine to the same. I then checked with the wheels jacked up to make sure they were rotating and grabbing when I applied the brake. With the correct adjustment on the engine side push rod I actually had to shorten the overall length of the interior push rod where the clevis is to make sure the car was releasing the brakes, so no long clevis required. Just an adjustment to the engine side booster push rod. However be very careful about the adjustment. Make sure you run the car with the vacuum port hooked up and take all the tools to adjust it with you. (7mm socket and a vice grip in my case). If you have some room in your master cylyinder lines you can pull the master, pull the push rod and adjust it with a 7mm wrench or a socket with it hanging out a bit. I found this out on the side of the freeway. Make sure to check that the brakes are completely releasing. Even the slightly upgraded brakes on my car was enough to completely keep the car from moving, and if this happened dialing back the interior clevis rod end does not do anything, you will have to pull the master off the booster and shorten the engine side push rod. I'll have to go back and check, but pretty sure I ended up somewhere in the middle from my initial adjustment, there definitely is some tuning you can do here and it will give you a really really solid pedal with almost no dead zone if you get it right, get it wrong and you will either have your brakes solidly locked up or a huge dead pedal.
  3. Strut bars Tubular frame rails Fender bars or front strut tower reinforcement Front sway bar reinforcement Granted if you plan on putting around and your stock floors and rails are good as Jmortensen says you could get away with quite a few off the shelf options. Once you start launching the car and moving to stickier tires and putting on harder suspension is when weaknesses are going to show.
  4. Ah, I see. The bracket goes to the side and bottom and you added the plate on top. I’m pretty sure I mentioned the faults with this in the for sale thread now that I think about it, lol. If you want to repair it completely, drilling out the spot welds hammering it back and welding it would be the solution.
  5. The frame rail is a C channel so tightening them like that will cause them to crush and pull on the spot welds on the wheel wells. You need bedding posts or sleeves as rturbo has said if you are set on that style. The mounts of the style it looks like you are trying to emulate usually require a 90 degree piece that is welded all the way around the frame, it acts to beef up that section and spread the load. Beta's for example actually avoids the top of the rail and uses the bottom and the side to prevent the crushing force it instead pulls vertically down on the spot welds which they can resist quite well and the side to side is basically buffeted between the rails. I think adapting off the factory mounting location is a lot better. The design isn't too radical, similar to the CX ones although I wouldn't recommend those ones as they have a weird offset and height to them.
  6. Sure, as long as you aren't somewhere terribly isolated lol. I'd love to see that manifold complete. Send me the link to whichever one fits your fancy.
  7. Howdy, Looks like you made a couple errors that are not playing nice with the forum at the moment. 1. You posted in the FAQ section which does not allow replies 2. You used a symbol in the title of your post which prevents the link from completing. I've gone ahead and merged the posts together, changed the title, and moved it into the correct area. These are pretty generic questions, but it is about a specific wheel so you may find some guidance. Good luck!
  8. Man that looks really good pretty good priority as well. They want $350 in shipping alone? If that is what you want I'll ship it up to you for what it costs at the local shipping place. Or perhaps you can try eBay? I know some shipping calculators freak out when you input other countries.
  9. Depends on your tolerance level. I'd say the folding ones on eBay are super unsafe, you could buckle them if you try. A solid bucket like that I'm not sure what to think without seeing the internal construction. I know the bride knockoffs were like hard plastic in some case. If it gets you moving on and you plan on replacing it then not much more to be said. If it saves it for more important things down the road, I can't argue with that either, I have a lot invested into suspension and drive train and very little in the interior so my attitude is pretty lax compared to others.
  10. I believe ours are 8mm thread? Maybe it could be used with one of these. http://www.linghunt.com/PartDOCS/B2409-X/B2409o14.html I wish there was an 8mm stand off which could save you the use of another lock nut. I suppose a tall nut (also found it mentioned as a studding nut) with all thread would be similar although it would require another lock compound on one side, maybe red locktite would do. Clevis female rod end is apparently the correct name according to mcmaster https://www.mcmaster.com/clevises 2448k48 seems like a longer variant of what I purchased before so it may be a viable commercial option.
  11. No, I've heard the pin called the clevis as well so I should have led with a picture of some sort. That is not a bad idea. My original thought was to weld one of those to the backside of the clevis U thing itself. I wonder if there is enough length for the appropriate locking hardware to keep that all from rattling loose. I'll check mcmaster's catalog as well. I remember when I did this a while ago I looked up the grainger catalog and only found 1 option, maybe things have gotten a little better since then.
  12. Just found this post. I am running the 15/16 on a 240z booster. Curious I don't recall which I set the booster to if it was the early or the later spec. I'll do some diving and maybe pull the booster and see what would be involved with swapping the external pushrod if the internal one is correctly set.
  13. Thanks for the link NewZed I'll have to dig through the parts diagram and see if Nissan has something, but I think my terminology may be incorrect? The clevis I am referring to is: https://zcardepot.com/collections/master-cylinder/products/copy-of-power-brake-booster-7-240z The U-shaped pivot point? I think the last time I found it they called it a threaded hitch or something at the local hardware store. After a lot of searching and for a ridiculous shipping charge I did find the clevis that looks identical to the Z car depot one a long time ago, but it was really short as in there was not very much room from the pivot to the thread, I think the brake was too thick for it to work in that application. I am being lazy here, I'll get under the dash and make some measurements, as miles says my current setup is maxed out with only one thread showing past the clevis and I have a good 2-3 inches of dead pedal before I get to the brakes which can be kind of alarming. The solution is to either extend the arms of the piece, add a coupler for more threads at the bottom like a hybrid of the z car item and the current one, or find a longer push rod if the brake booster can swap the push rods about.
  14. eBay seats will eventually show their colors. Either the material will fade, crack, fall apart, or it will rip if you look at it funny. I ripped the fabric in mine getting out of the car in an odd way. My low buck sparco's were sitting outside in a shed and all they needed was a bit of wiping to bring back. The factory seats I've seen in remarkable condition even almost 50 years on. By the time you have it reupholster with some decent foam you would be looking at the price of a good seat. I sold my last eBay set as office chairs as I didn't feel comfortable advertising them as car seats as the back had so much flex. Aesthetically it would pass as "period correct" to an untrained eye. Those breathers look like they would be cheese graters if you tried to slide into the seats. The old school rivet style seems like a better overall choice.
  15. Neat. I do feel like they are a one time type of thing unless you have a coating that lets all the oil bead up and fall down and the shape was concave or something.
  16. The 3 bolt has 1.5 or so of adjustment if I remember. It ships with the adjustment knob centered in the hole which is max negative. I have adjustable arms, but my jig was made off of a factory arm so pretty close to stock. I pushed the camber plate to max positive which brought the -4 down to -2.5. The shop I took it to then dialed out some more with the adjustable arms. You could get by with either a 4 bolt top, or camber bushings if you want it closer to -1 or 0.
  17. You may need some camber adjustment at least in the rear. I had -4* with the included camber tops, I dialed it out to something like -2.5*, but if you want less than that you will need some arms to bring it in or more adjustment in a different camber top.
  18. So I had this problem in the past, and I've just kind of ignored it. Time to finally address it. Has anyone found a source for the clevis for the brake pedal? I took one off of my clutch as the one I found and paid a lot for ended up being too short to reach around the metal plate of the pedal itself and I foolishly left it attached on my booster when I traded it in. I'm hoping for something a bit longer as well as there is a lot of slack before the brakes engage and I can't dial in the preload as it is maxed out on the threads. If a source isn't available does anyone have recommendations on how to lengthen the clevis correctly? Should I lengthen the arms? Or should I weld on a coupler to the threaded side to extend the clevis length?
  19. Getting the motor in physically won't be too difficult. If I recall you have to keep the mounts on the engine side from the current motor in your car. Wiring isn't too difficult to sort through once you have the motor as the wiring is a little different between the years. With a 2+2 you may run into issues with the drive shaft length if you plan on running the T5 transmission. If you plan on keeping the 5 speed you have now it won't be a problem, but it will be a weaker setup if you decide to up the power down the line. If you are looking for a shop I think Z-sport up north in Everett or Fairlady Motors/U.P. garage down in Tacoma are the only specialist, not that you would really particularly need one, a competent shop should be able to tackle it. I think the only person I know that does private work is Dave up in Marysville. If you are looking for input/advice, there are quite a few local guys around who have done it. @Boog has one in his car, @TheFairlady went through a few in his. @AlbatrossCafe is also sporting one if I'm not mistaken, you may be able to pick their brains about questions.
  20. I was talking to a friend about it, he was going over the math involved for assisted mechanisms and it was quite complex so I imagine the little box has a lot to figure out especially without speed input involved.
  21. You are right, I imagine that would come in on freeway driving in a straight line, minute corrections could mean you are hunting for a straight line, I was thinking more long sweeping turns and such. That is one of the downfalls of the E-steering setup. It usually needs to sense a force to begin applying the force which can come across as play or delay. The beauty of the bruno setup is that you can turn it off for most of the time other than when you are at low speeds where the assist would be appreciated. The other downfall while we are at it would be a general numbness that can be attributed from too much assist, which also could be toned down with a knob versus a feedback. I was really really really into having power steering, even built my own setup following another member's build. I have about half an hour more work to install it, but I really can't seem to be bothered. I went auto crossing which should have been a workout in theory, but it never even occurred to me that I was missing out on the assist. I can definitely feel for people running more than my measly 225 width tires, or if they have tight parking spots to navigate, but short of perpendicular spots, parallel parking, or meaty tires I haven't found a necessity to finish. Edit: also people with shoulder or joint issues, I'm sure could benefit as well.
  22. Not recommended for anything more than casual driving. By relying on the force input there is a delay before it assists, so slightly difficult to suddenly easy, hard to do precision maneuvers, but perfectly adequate for say parking or moving down a freeway. I guess it depends on your usage. I only really wanted it for low speed, so I thought that might be useful, but I believe he recommended for any automotive events you don't use it.
  23. Interesting, maybe they stripped them down like how we have stripped down models domestically. Reminder to take another look at the TC bushings.
  24. Budget and rebello usually don't go hand in hand especially if you are planning on boring up there will be work that needs to go into it. Low budget would be a stock rebuild, with another good donor block, for 60 more hp an L28ET seems to be a good choice with a bit of a boost up you should be in that ball park. Staying NA and trying to squeeze more out would be quite a bit more in the long run depending on where the rebello kit puts you.
  25. An S2k would just be a better platform almost all around. Plenty light, double wishbone, LSD, CV axles, etc etc. Plenty of people have done the F20C or F22C, but putting a 4 cylinder in the car seems to be a bit backwards in that they usually have pretty low torque values without power adders. The VQ swap have been done on a few occasions, they have kits for the swap available. JZ swaps have also been done and kits are available as well. They are all very different motors, high revving NA 4 cylinder, mid bore NA V6, turbo inline 6, all this from someone who was looking at swapping their current V8 to another V8. Makes me think you aren't really decided or are willing to take whatever is handed to you? That is not a really good recipe for loving the project, swaps can be fairly involved so it best be something you can justify down the road as you dig into it, like the all mighty JZ has its own set of faults, some potentially catastrophic, will learning of that make you wish you never got started?
