CamH
Everything posted by CamH
I didn't realize this site even existed. You're awesome. Thanks!
Hey guys, It's 2013, and most of the information on the site concerning CV conversions is no longer useful due to lack of parts. The two manufacturers of CV adapters that I'm ware of, both Modern Motorsports and M2 Differentials, are no longer in business. I was looking forward to throwing on my set of 280ZX Turbo CV shafts in the coming weeks, but it appears that 280ZX Turbo shafts may no longer be an option, unless there are other companies building adapters. It seems to me that we now have three options for CV shafts on our S30 Z cars: Custom CV shafts like these: http://www.driveshaftshop.com/datsun-510-240z-c-v-conversion-kit-with-108mm-flanges http://www.wolfcreekracing.com/index.php?option=com_content&view=article&id=72&Itemid=61 OR Custom 280ZX Turbo CV adapter such as: http://www.pape.ws/allan_and_rosanne/Z-Car_Stuff/Modifications/CV%20Halfshaft%20(280ZX%20Turbo)%20Conversion%20for%20late%20260Z-280Z.htm OR crazy Z32 R200/R230 VLSD conversion (seems way over the top for my car): https://technotoytuning.com/nissan/280z/complete-r200-r230-rear-end-conversion-z-car Does anyone else have any thoughts on this issue?
Modern Motorsports doesn't want to do business anymore, so I was wondering if anyone has a set of 280ZX Turbo CV adapters for my 240Z.
Sounds excellent should I send the paypal to that address?
Yes the 27 spline ones are what I'm looking for. I'm doing a 280ZXT CV shaft conversion. But you only have one? I'm trying to get a set
No, sorry, I am looking for the stub axle, like this:
As seen in thread title, I'm looking to buy a set of OEM 280Z stub axles. Let me know what you've got and we'll make a deal!
The mitsubishi turbocharger should be flanged improperly for use on a normal L28ET manifold.
I've heard about some electrical noise issues when grounding your MS and LC1 in the same spot. I was having issues with my LC1 resetting and then never coming back (simply flashing its lowest value forever), and I regrounded separately from the MegaSquirt, and don't seem to be having the issue anymore, but I've only got maybe an hour of driving on it since moving the ground.
Finally got my turbo swap started, Need some help diagnosing problems
CamH replied to Fuzzydicerule's topic in MegaSquirt
Yes, but I am saying the MegaSquirt PWM is fine. People claim that it is weak, but there really isn't much evidence to support that. With the mod I outlined above, and the PWM set up correctly in the injector characteristics menu, there is no reason that MegaSquirt can't drive 6 or more low impedance injectors without needing resistor packs. -
There are some guys on the MSEFI and MSExtra running 6, 8 and 12 cylinders with low impedance injectors without injector overheat issues, so I'm not sure that's a problem. I've never read about anyone overheating their injectors anyways. -
I can help you with #4 as I just fixed this issue! It is correct that the MegaSquirt injector driver wasn't really made to handle 6 injectors -- it creates too much electrical noise for the MegaSquirt to handle. HOWEVER, before you go out and buy resistors to put in your system, there is an easier way! It is very simple to fix the MegaSquirt injector drivers to allow them to handle 6 low impedance injectors with ease, and it ends up getting less noise than installing resistor packs inline with the injectors! Run down to Radio Shack, and buy yourself a 47uf 35V capacitor. Now, take the case off of your MegaSquirt, and find the "boot" header on it. On the underside of the board, it should have the back side of the "boot" header pins sticking through. Solder your two 47uf 35V capacitor leads to the two "boot" header pins. Stick the case back on your MS, and bam! You're ready to go with your new, low noise setup. This may fix other problems you are having as well. For me, I had trouble getting the engine to rev over ~5k or so without having it cut out, and it would also cut out randomly while cruising. Both issues are completely gone. Edit: I also know 5, it should be 2 per cycle, alternating -
Shadow Logger - connect MegaSquirt to Android phones
CamH replied to Matt Cramer's topic in MegaSquirt
Will there be an iOS version? Actually, I feel like an iPad would be a good candidate for a FULL version of TunerStudio -
I guess you can put the lash pads 180 degrees different from one another, but I believe the bottoms are machined to be completely flat, so it really shouldn't matter. I've had 3 different cams in my car now, and have not worried about lash pad orientation, only proper thickness. No issues yet!
I'm not sure what the factory pinouts are like, but you may look into using one of these adapters from diyautotune: http://www.diyautotune.com/catalog/diybob-c-79.html My guess is that you could probably get it going for all factory sensors, ignore the AFM wires, and run only one vacuum line to the intake manifold to get it running properly.
I think there are some guys on the forums here running high 11's with only high 300 whp setups. Keep in mind, an L28ET that makes 350whp will probably have around 400ftlbs, or more...
Obviously, the S2000 and the E36 M3 are going to be much, much slower in a straight line than a Corvette, E46 M3, M Roadster, or M Coupe. There's about a ~90hp difference between the two groups, and it shows. Personally, my DD is a lightly modded E36 M3, and one of my very close friends DDs a lightly modded AP1 S2000, and I have a lot of time behind the wheel in that car as well. I've never been in either car at anything like an AutoX, though. I like my M3, but I know it's not the fastest car in the world, and would probably get shown up by a new Maxima, or something (same goes for the S2000.) The S2000 is pretty nice to drive as well, but only around town. They are wound up very, very tight on the freeway, and it can be very obnoxious. The S2000 makes you wish that they had a 7 speed transmission, or a sane 6th gear ratio. I think the AP2 is slightly better in this regard. Really, all the cars that you listed are pretty fun, good looking, "cool" cars, and you'd probably enjoy any of them. I'd personally buy the M Coupe if given the choice. What a beautiful car! That's my 2 cents.
Rota RB-Rs and Suspensions
CamH replied to Sideways's topic in Brakes, Wheels, Suspension and Chassis
I run front bolt in camber plates, no camber plates in the rear. I believe my springs are 225 F and 200 R. I run Tokico Illuminas on 4 setting front, 3 setting rear. Ride is quite harsh but the handling is very confident. -
I'm running the 17x9 and 17x9.5 Rotas on my car with coilovers, suspension techniques front 1 1/8" sway bar, and a whole lot of fender cut away. I run 245x45x17 front and 275x40x17 rear tires. No clearance issues with the tires, even if I drop the car another inch (then I just scrape on everything). -
Here's a pic of some member's Turbo Tom setup: This is a suck through setup, but you get the idea
I believe this is how old school Turbo Tom turbo kits were. Blow through Holleys. I don't think you'll be able to run into 11s on a 50 trim T3/T4 without a lot of boost and some healthy traction. Does this car still have an L26 in it?
That looks like a Z out of a junk yard.
Wow! Your Camaro is beautiful! Very nice work!
Those CCW's look excellent! So does your Z! I've always said I'd like to ditch my Rotas for a set of CCW's. Maybe in a few more years...
