Daz
Everything posted by Daz
  1. Thats cool then. Why not get a known good gauge from someone selling parts or take a chance with a junkyard gauge ? Plugging a gauge into the radiator does not tell you what temp the engine is. It will only read the temp of the fluid in the radiator.
  2. Why not swap out the gauge for something more modern ? I was going to use Prosport Evo Digital gauges(look them up) but decided to go with deporacing digital gauges.
  3. I like your radiator placement(I will be stealing that idea, thank you) and your plumbing is clean, great job !
  4. Daz
    Speedhut GPS gauge
    I put the wrong P/N for the speedo. I want the GR4-SPEEDO-06T instead in Black dial/ Red Fonts and Text "DATSUN". I has to be moved under the turn signals. SpeedHut list this one at $219.95 +$10 for text. I can't figure out how to send you a pic. Everytime I save it and try to post it it comes up as just the ring Bezel and blank in the center. Let me know, I'll get the speedo first if I don't have enough funds for the tach too.
  5. Daz
    Speedhut GPS gauge
    Try this :http://www.speedhut.com/gauge/GR4-TACH-02/1/Tachometer-Gauge-8K-RPM-Shift-light & this :http://www.speedhut.com/gauge/GRM4-SPEEDO-01T/1/Speedometer-Gauge-200km-h-Metric-programmable--(w--turn-signal-and-high-beam) I want both in Black Dial/Red Font P/N GRM4-SPEEDO-01T, custom text : LSX P/N GR4-TACH-02, custom text : Datsun(top line), 260z(bottom line)
  6. Daz
    Speedhut GPS gauge
    Not too many tunnels in my area, maybe in the L.A. area but its more overpasses then anything !
  7. Daz
    Speedhut GPS gauge
    How much is a steal ? This is exactly what I want: http://www.speedhut.com/customizer.i?clid=279520 and http://www.speedhut.com/customizer.i?clid=279522 ! $421 shipped as it stands unless I get the speedo without the turn signals and H-beam .
  8. Daz
    Speedhut GPS gauge
    I'm sure you will be done with your build before me so I'd like to know how they work especially the gps speedo !
  9. Daz
    Speedhut GPS gauge
    I guess I'm liking the idea of less wiring ! The price is right for a electronic gauge compared to Autometer and I get to customize it with wording !
  10. Anyone have any experience with the GPS speedometer's ? I'm thinking about getting one along with a tach to use on my turbo LS1 build. http://www.speedhut.com/gauge/GR4-SPEEDO-06/1/Speedometer-Gauge-200mph-programmable
  11. I think I might try this route ! Anyone have any info ?
  12. So no leg room for a passenger ? Where in SoCal are you ?
  13. The stock battery area seems to be the best location for me too. Any issues with water or heat in that area ? 280ZCAR, your location is NICE ! I wish my harness would allow me to put mine inside at that location !
  14. Where did you guys mount your pcm and fuse box ? Pics would be nice if you have them. I just need idea's, my battery(braille type) will be mounted behind the passenger seat and I was thinking of putting the pcm where the stock battery goes mounted on the fire wall. Any help would is deeply appreciated.
  15. Pics of the rear end and axle set please ?
  16. I've been looking for the axles for a while, if you decide to separate I'd be interested in just the axles. I already have the VLSD installed in my longnose R200 and the "shiro" axles make thing so much easier. I wouldn't have to make hybrid axles.
  17. I currently have VLSD carrier from a z32 NA installed in my R200 housing. I have the 5bolt stub axles installed but the shorter stub axle has to be shortened a little and a groove for the snap ring reground because it doesn't seat all the way because the carrier seats slight to the left inside the carrier with the spacers installed.
  18. Thanks man ! I'll be getting it soon after I get all my idler pulley's. You car is awesome !
  19. What is the accessory drive belt part # ? My will be basically the same ! Where did you get it ?
  20. Daz
    STI R180 LSD ?
    I'm thinking I'll have to run a shortnose R200 or R230 ! I have a VLSD carrier from a shortnose in a longnose right now but I'm seriously thinking of scrapping it ang going with the shortnose and just buy the mount(I'll have to change my mustache again). But then I'm back to finding axles that will be strong enough and just pay the price for the hardened shafts.
  21. Daz
    STI R180 LSD ?
    Your right ! I had a STi and I would at times dump the clutch at 4-5K rpms, but like you said its split. The front axles I believe plug right into the tranny itself !
  22. Daz
    STI R180 LSD ?
    Thanks for the info guys, keep it coming ! I am most concerned about axles they can handle the power I will produce(550whp+) with a turbo LS1(Sunny Z has broken stuff with his NA LS1). I don't want to pay $1200 for axles but I know If I want to play I gotta pay.
  23. Daz
    STI R180 LSD ?
    I must be mistaken about the Suby CV then, I thought they plugged into the diff like the z31t do. That way I would still have cv's. Even with that I know they probably would not hold up to my Turbo LS 4.8 that I have for my 260z.
  24. Daz
    STI R180 LSD ?
    I wanted to ask the Diff guru's a question ! If I bought a Sti Diff with axles is it possibble to make hybrid CV axles by mating either the STi input shaft(plug into the Diff side) to a Z31t axle(or any other axle) or vice versa ? I don't know the specs of a STi axle but I do know the diff's are pretty strong. All this is just a thought !
