72zcar
Everything posted by 72zcar
  1. same prob with tokico "lowering springs" bought at msa. eneded up cutting 2 coils off front, 2 off the passanger side rear and 1 1/2 off driver side rear. (for some reason z always sat higher on the passanger side rear)... so this was my plan to even everything up.. even all right, perfect in the front but now the rear is tooo low. should have took off 1 coil driver and 1 1/2 passanger in the rear... crap. so now i swap in some 280z top perch part in the rear...bamm perfect. so the there u go if any of that makes sence
  2. 15 too young, 36 too old, 24 just right counter clockwise
  3. Thanks ecp48 for the info. You did not mention the front bar, will this fit my 73?
  4. sorry if it sounded bad, i was just trying to be funny I wish they would fit, the sway bars and springs are only about a year old bought at msa. I already got a full body kit from this guy. front rear and side skirts for 150.
  5. The only way to make a 280zx look like a 240 is to sell it and but a early z...
  6. hmmm, i see your answer is bias... 100 bucks for front and rear with end links. springs 50 bucks. anyone else have an opinion?
  7. bump...anyone have a clue. I want to jump on these if they will fit before someone else does, he has the part car in the local autoshopper here.
  8. I have a chance to buy front and rear MSA sway bars ( 1 inch front and 7/8 rear) and a set of msa lowering springs that are on a 78 this guy is parting out because he could not get it to pass smog. Will these parts fit my 73 240z?
  9. zmann280, Are you taking abot the rubber lines or the steel lines?
  10. 70-73 looking at the msa catalog. 74-76 is a different part number
  11. that really blows! I will keep an eye out, I'm down here in monterey not far from you. Whats the plate number?
  12. http://www.zcarparts.com/store/merchant.mvc?Screen=PROD&Product_Code=50-1409&Category_Code=7AD1 this will fit on all zs 70-78. I have seen 280zs with this air dam and I thought it was a 240 till i looked at the dash and the rear lights... then for the back maybe this http://www.zcarparts.com/store/merchant.mvc?Screen=PROD&Product_Code=50-1473&Category_Code=7RS It says 160 pounds but I can pick mine up with one finger
  13. sorry for stomping on your post...thought i was starting my own post
  14. Question is can I run a Magnum comp 270 cam with this motor and the stock heads? Can I install the cam without removing the motor from the car in my 72 I have a stock 92 goodwrench crate motor (maybe 20,000 miles) with the stock heads that came with it. shorty headers, street master edelbrock single plane, and 600 edelbrock. Hei, flame thrower and msd. TH-350 w/ b&m shift kit and stock converter.
  15. 72zcar
    Get This!!!!
    You still have not answered moridin2004 question
  16. 72zcar
    Get This!!!!
    yes, and since it says "or" she can also sell it without your signature or permission. So dont leave the title laying around.
  17. bought mine from kragen right off the shelf, looks a little different but works great. There are different plug types so watch for that.
  18. Don't do it!! I went with the th-350 because thats what came with the donor car but on the freeway its no good. You will be hating it. As soon as I can I am going with 700r4 or world class t-5.
  19. for instructions on msd http://www.msdignition.com/ and click on downloads then instructions...
  20. yep the wire from the carb is for the choke... i soldered mine to the fuse box on the top left (i think), the one labled air conditioning since it was not used anyhow and is operated on the switch. There is a drain plug on the bottom of the tank to make draining the tank easy as pie...
