240zip
Everything posted by 240zip
  1. try the search feature - this has been discussed a few million times.
  2. Taken from: http://www.teglerizer.com/dcoe/inglese/inglesetuning.htm Weber carburetors have been seen as standard equipment on the finest racing and street machinery to come out of Europe for over three decades. Maybe you've been lucky enough to get a ride in a Ferrari or a Weber carburetor 289 Cobra; if you have, chances are, it's a ride you've never forgotten! Weber-carburetor engines all have one thing in common: they assault the senses with a rush of torque and a brutal sense of urgency that is generally unmatched among carbureted engines (and they have a sound all their own...go to a Shelby American convention on Open Track day and you can pick out the Weber-carbureted Cobras just by their sound; there is no mistaking it!). The world's most beautiful, exotic and most powerful engines have traditionally been fed through Weber carburetors. But why Weber? For starters, it's a modular carburetor design. It is produced in a wide variety of styles which incorporate different features, enabling the user to select exactly the right design and size for the intended use. You can even change its CFM to suit your needs, which should begin to explain the Weber's superior adaptability for all kinds of applications. Now, if you're one of those people who has always had trouble accepting the idea that the Weber is a terrific street carburetor, consider it this way: Weber carburetion is like an expensive musical instrument. If it is not tuned properly, that instrument will never make beautiful music for you-no matter what! And therein, lies the secret of making beautiful music with Weber carburetors-initial preparation...... It's what "tuned induction" is all about! THE CONCEPT The Weber carburetor was designed to be totally adaptable to any size engine, for any purpose, at any altitude. There is no such thing as taking four of these out of their boxes and bolting them on to an intake manifold...it simply isn't done that way. This carburetor was intended for serious tuners and performance enthusiasts who want the most that their engine can give them. Welcome to the Big Time! TERMINOLOGY All Weber carburetors carry a basic model number which is stamped at the base of the carburetor on its mounting flange. The most well-known is the good-old "48 IDA", a masterpiece of design and a marvel of precision machining that has been around since the early 60's with only minor revisions. In this case, the number 48 indicates the carburetor's size. It tells us the carburetor has a bore diameter and throttle plate size of 48 millimeters (about 1 15/16"), while the IDA suffix tells us that it is a high performance downdraft carburetor. There is also a 40 & 46 IDA/3C. Again, a high performance downdraft, available in 40 and 46 mm sizes. The 3C means this one's a "3-choke" (the in-line three barrel). The 40, 42 and 44 DCNF's are compact twin-throats which feature a cold-start. As the prefix numbers indicate, they are available with bore diameters of 40, 42 and 44 mm. Then there are the sidedrafts - all Weber sidedraft carburetors carry the suffix DCOE, their prefix numbers (sizes) ranging from 38 mm all the way to 55 mm (that's close to 2 1/4"). So you see, all those numbers and letters really mean something. It's all pretty simple.....So, the next time someone mentions he's running Weber's, ask him whether he's running DCOE's or IDA's and pick up a few bench-racing pointers. THE VARIABLE CFM FEATURE Some where along the line, you can probably recall seeing four 48 IDA's on a big, nasty rat motor. You've also probably noticed that the same four 48 IDA setup is used on 289 Ford engines, as on the Cobras, for instance, You may have wondered how the same carburetor setup could work on two such vastly different engines. It seems that one engine would have to be either over or under carbureted, if we assume that the carburetion is "right" on one engine. Actually, this isn't true at all, because either engine is running the same set of carburetors as the other. Assuming the Webers are set up properly, the only thing the two systems will have in common is their outward appearance. The Weber's most interesting design feature is it's removable "choke" or venturi, allowing it to be instantly converted from a large-CFM carburetor to one of small CFM, or vice-versa. By installing a smaller choke, the carburetor is constricted and it flows less CFM, to make it perform in the midrange, or to make it suitable for use on a low-compression small block engine. Pull out those small chokes, drop in some large-diameter ones, which may be nothing more than thin-wall "sleeves", and you've got a set of 48 IDA's that will flow enough CFM to make a big block scream. But don't try putting those "big" carburetors on the small block motor! It will fall flat on it's face, lack throttle response and become a complete nightmare in traffic("....My buddy had a set of those Webers on his engine, and boy! did that car run badly!!!!!"). In order to get drivability, throttle response and lots of torque from the Weber-carbureted engine, the choke size, therefore, is the first consideration. How big is the motor, what's the compression ratio and what do you want to do with it, once the correct size choke has been selected for your application, the jetting for all the rest of the circuits can be established around that choke size. THREE CIRCUITS For the sake of simplicity, let's look at the Weber carburetor as having three basic circuits- the idle circuit, the accelerator pump circuit and the main circuit. The idle circuit is comprised of two components, the idle jet and the idle jet carrier. With these two pieces, the tuner can select exactly how much fuel and how much air he wants to provide the engine at idle and during the low rpm operation, while making very fine adjustments to either, if necessary. The idle mixture is delivered as a proportioned mixture whose total volume can be further regulated with the idle mixture screw, which is located on the lower part of each carburetor barrel. On a correctly-jetted idle circuit, the mixture screw on a 48 IDA is never more than 3/4 of a turn out. This will hold true 100% of the time, no matter what anyone else tells you. If you have to go more than that, you'd better heavy-up the idle jet. Even if you get it to idle, going more than 3/4 turn tells you the jet is lean and you're going to have other drivability problems, which brings us to the next part of the idle jet's function. The idle circuit in the Weber isn't just an idle circuit - it does more than that. It is actually the circuit which must carry the engine all the way up to about 2,800-3,000 rpm, where the transition to the main circuit take place. That means if you don't drive over 3,000 rpm, you're only running on the idle jets. After 3,000 rpm or so, the idle circuit is entirely bypassed and no longer has anything to announce. So, if you have a tuning problem that "goes away" after about 3,000 rpm, that tells you to play with the idle circuit. Or maybe the opposite is true. Either way, it's very cut and dried as far as the two circuits are concerned - so isolating the problem is a breeze. One the most frequently experienced "gremlins" with Weber carburetors is a seemingly incurable and very annoying flat spot which rears its ugly head at about 2,200-2,800 rpm. This condition is generally caused by one of two things - you either have the wrong emulsion tube in the carburetor, which is causing a rich stumble due to an under-emulsified mixture at that particular rpm range or the idle circuit is falling off too early to carry the engine up to the point where the main circuit can take over, leaving a "lean hole". In simple terms, the idle circuit is going lean too early. Either condition is easily rectified. In the case of the emulsion tube, there are really only a few which work really well for V8 applications; and if you aren't using one of them it is certainly a big part of the problem. If the flat spot is still there even with the correct emulsion tube, then you'll need to richen up the idle circuit. This is sometimes a tricky area, because the first thing you want to do is throw in a bigger idle jet, but sometimes playing with air bleeds, mixture screws, or choke sizes can accomplish the same thing while sticking with the original jet size. Seeking a little bit of sound advice here can save a lot of time and hassle. The point here is that these carburetors are designed to come off idle and run smoothly all the way up. Your problems can be solved with a little tuning on your own or by relating the symptoms to someone who is knowledgeable enough to help you. Remember, these carburetors will do just about anything you want them to, except maybe wash your socks. The accelerator pump circuit, just like on any carburetor, is responsible for eliminating "bog" and making a passing maneuver without a hesitation or stumble. The circuit also has two basic elements. These are the pump exhaust valve and the pump jet. The pump exhaust is nothing more than a bypass valve and this is located in the bottom of the float bowl. This is the piece that regulates how much fuel you want to make available when you need that pump shot. Putting a bigger bypass hole in the valve allows more fuel to bleed back into the float bowl instead of out of the shooters. The smaller the hole, the more fuel you're making available. You can even put in a "closed" bypass for drag racing, when you need all the juice you can get in order to get those slicks turning. Obviously, there is nothing complicated about a simple bypass system. The duration of the pump shot is varied by installing a larger or smaller pump jet (shooter). Larger pump jets give a heavy blast over a short period, while the smaller ones will give a finer, longer-duration shot. As long as you leave the bypass valve alone, you're still getting the same overall volume. In most cases, the stock pump jets can be left alone. The main circuit is the easy one. This is where you make your power. This circuit has three primary elements you should concern yourself with - the main jet itself, the emulsion tube and the air corrector. You're thinking that's a lot of pairs - usually, it's just a main jet. You know how to "read" what your Webers can tell you on a road test, you wouldn't have it any other way. The capability for fine adjustment is what you pay for. Let's take a look at this main circuit...... The main jet is stuck into the bottom of the emulsion tube and sits in fuel. As the carburetor begins to work, the main jet meters the amount of fuel allowed to pass through it and up into the "main well" around the emulsion tube. Air enters the top of the emulsion tube through the air corrector which meters the amount of air to be mixed with the fuel. The air blows out of the emulsion tube through a series of holes along its length and aerates the fuel that is rising up the well around the tube. This emulsified mixture is then sucked out of the main delivery nozzle as the "depression" in the carburetor increases to the point where it's strong enough to pull it out. This occurs by 3,000 rpm or so, and you're down the road like a shot. Tuning the main circuit for maximum power is something that can be done by a series of road tests and a handful of jets. The simple rule of thumb for jetting Weber carburetors is, if you want to implement a change over the entire rpm range, you play with the main jet. If you want to change the way the car feels at the high end, that's where the air corrector comes in. Also, you should keep in mind that the air corrector is a finer adjustment that the main jet. Example: One step upward in the main jet (richer) equals about the same as three steps down on the air (less air: richer). A change of air corrector would be appropriate; for instance, if the engine pulls strong to 5,000 rpm and then goes flat. This would mean she's going lean on you up top; drop the air corrector three sizes or so, and you'll probably be able to buzz that engine right up to 7,000 rpm. If the motor feels sour all the way up, go one or two sizes heavier on the mains only. No magic! So, tell me, what's so hard about jetting these Webers? STREETABILITY Most people don't realize that this carburetor, like all highly efficient items, is an extremely simple design with very few moving parts. There are no metering rods, power valves, rubber seals or plastic parts. The accelerator pump on the 48 IDA is a brass piston. The throttle shaft rides in a set of precision roller bearings. Webers use brass floats, which cannot become fuel-logged, and gradually sink with age. It is a superior example of precision machining and "beautifully-fitting" components...it's really very unlikely that one of these carburetors is going to "fail" and cause you to be stranded somewhere. That's another reason why they're well suited to street use and long-distance cruising - they are extremely reliable. With the infinite tune ability of Weber carburetors, there is no need to compromise the drivability or road manners of your car. If you know someone who suffers from drivability problems with such a nice carburetion system, he is doing so unnecessarily. A Weber unit should be crisp, responsive and smooth. If it is not, something is wrong - let's just say he's not through tuning it yet, that's all! The first thing most people notice when they go to Webers is an increased flexibility from the motor. There is a natural tendency for a Weber-carbureted engine to idle smoother, have a slicker "feel" to it a low speeds (particularly if a hot camshaft prevented that feeling before), and generally feel much more powerful throughout the entire rpm range. This is largely because they use an independent-runner manifold, which does not incorporate a plenum. In a typical four two-barrel Weber layout, there is one barrel directly feeding each cylinder without any intercommunication between barrels or cylinders. This totally "isolated runner" design ensures that each cylinder is fed exactly the same as the next, without any chance of charge-robbing or over-feeding. What you are doing, in effect, is separately tuning each cylinder. This results in a dramatic increase in horsepower output and torque in midrange, right where street engines spend 90% of their time, making this an ideal carburetion system for street use, where maximum flexibility creates greater driving enjoyment. The throttle response with an independent runner induction system is also a new experience, it's second to none. A Weber carburetion system will respond like a fuel injection unit, with which it shares some similarities: short runner length, isolated design and essentially a low fuel mass to move when you hit the throttle. (Remember, you're not asking that cylinder to gulp all the mixture from that big plenum area - that's a lot of mass, by comparison. The only mass to move is what's in that one short runner). The main difference between fuel injection and Weber carburetion is that one relies on fuel being injected under very high pressure, while the other responds to the needs of the engine via the depression principle. For street use, the Webers have the edge - it's what they were made for. In the mileage department, it really depends on the rest of the engine and your driving habits, but 16 to 18 mpg is not unusual on the highway. This is pretty respectable, when you stop to consider that the engine is fed by all eight barrels constantly. There is no such thing as a progressive system here. Another thing: Webers will run happily on regular gas. If you can run regular now, you can continue doing so after installing the Webers. This is purely a function of compression ratio and ignition timing, not induction. In fact, if you're running a 10.5:1 engine, you may find it's a little bit fussy about which brand of fuel it wants. giving you detonation at times. Generally speaking, the Weber carburetion will likely change this for the better, suppressing the tendency to "ping". One reason for this phenomenon is that the fuel distribution is now fully controlled, eliminating the "lean spots" which sometimes are present in conventional manifolds which distribute fuel from a central plenum. Lean cylinders run hot - excessive cylinder heat means detonation. TUNING AND MAINTENANCE A Weber carburetion system will not be right, unless it's synchronized to ensure that each carburetor is doing exactly the same as the next - the name of the game is perfect cylinder tuning. The synchronization procedure can either be a breeze or a nightmare, depending on whether you have a well-designed linkage system or not. The secret to a good linkage setup is that it must allow independent adjustment of each carburetor without affecting all the rest as you go through the procedure. Here again, if someone tells you they're absolutely impossible to synchronize, you might study his linkage. Chances are, it's incorrect and he's fighting himself. The right components are now available to take this out of the dark ages. The final idle mixture adjustment on each barrel is a simple adjustment which is performed by ear, but because there are four carburetors, a lot of guys feel intimidated. It's done the same way you do a single four barrel, except in this case, you can listen to each cylinder separately. It may take you four times longer, but it's no more difficult at all. Each mixture screw, as it is turned, will have a noticeable effect on engine rpm, as the wrong setting will cause the cylinder to "go away" - it's just like pulling a plug wire. No matter how hard you try, you can't mess this up if you remember one thing: always start from scratch at 3/4 turn out. From there, you go 1/8 of a turn either way and it's usually in, not out. This will get you out of the woods if you ever get lost. Once the unit is synchronized and the idle mixtures are dialed in to give you the smoothest possible idle, you can hang up your Unisyn and screwdriver til' next spring, because now it's set! And when it's set, it's set!! They will not suddenly "go out" on you and ruin your day at the picnic.
  3. did you get the DIY kit or has something changed ... meaning they're selling completed headers again.
  4. It would have been nice if Stahl had plans, drawings or other information to assist in this DIY approach. I know they have the jig.
  5. http://forums.hybridz.org/index.php/topic/65280-porterfield-r4-s-brake-pad/
  6. http://forums.hybridz.org/index.php/topic/69472-racing-pads-for-toyota-s12w-calipers/
  7. I actually have the Caswell triple chrome set-up. I've never purchased their Silva spray (extremely expensive) nor their copper spray. The real key is surface preparation. You need to put down a conductive layer then build-up the copper, then buff it to a mirror finish. Then you lay down the nickle and finally the chrome strike. It's honestly a pain and you're dealing with really toxic chemicals. Before I do chrome again I have to get a decent fume exhaust system for the garage. That's likely going to be this fall, but I'll give a shot at the middle chrome strips. Just haven't had the time. Once I have the set-up I'll be able to do those strips cheaply. We'll see how it goes.
  8. Well this is a follow-up to the whole gas smell issue. It was two eval hoses that were disconnected and stuffed above the mounted gas tank. Not to mentioned rotted hose gaskets. I replaced the gaskets, hoses, and no gas smell. Huge difference both in the car and when left in the garage. It was fortunate the gas sender was defective or else we would have never dropped the tank and found the problem.
  9. Thanks for finding that review. Buyer beware for sure.
  10. will it be difficult to weld these without a jig? also, I guess if you talked to Jere you know you'll have to fabricate the collector on your own? The price for the pieces sounds reasonable.
  11. I saw that Alsa has a Killer Chrome kit (three cans) for $115. Seems a tad steep for three cans of spray paint, but I was thinking of using it for a bunch of interior plastic pieces. Anyone use it? I was going to try it on the tail light chrome strip.
  12. I admire what you're doing, but I would have media blasted the car to bare metal before doing the welding and other repairs. It's all going to come back. And since you already bought the car I'm not going to bother with my opinion on whether you should purchase it or not. I'm not a fan of the rust converter. I believe in media blasting then treating the bare unrusted metal and using an epoxy-based primer. If you're going to just drive the car on the street, it's not a big deal, but if you're going to do any spirited driving I'm not sure that your car will be safe given the extent of the rust you've shown.
  13. Death Grip on the Wheel ... one lesson I learned is to not grip the wheel so hard. The stock 240Z-280Z is just too darn skinny for my hands. I ended up with a Momo wheel and adapter. Made a huge difference in terms of my hands cramping up. I suspect driving gloves would have helped.
  14. I see you're running SDS ... do you have the data logging feature?
  15. 1971 240Z, 1" lowering springs, 15" street tires, Tokico 5-way, Toyota 4x4 brakes and drilled rotors, 2.8L NA engine with triple webers, headers, E31 head with mild port work and street cam, 5 speed transmission from a 280ZX, R180 LSD (from Subaru STi), no roll cage. Would this land in B Street Prepared (BSP)? Do I need to get a roll cage, racing seat, harness, fire extinguisher, and window net? Is there a lower 'street' category that I could run in with my mods? I'm not looking to be competitive, just want to go out for PDX and then do laps on SCCA sponsored days. Basically to learn and improve driving skills.
  16. I talked with Judy, Stahl will still sell you the pieces for the L6 header for about $280. Some assembly required. You'd have to custom fabricate your own collector. If anyone gets a lead on the Trust brand header (like a URL link to what it looks like) I'd be interested.
  17. Talked with Stahl, they will piece together a kit. One odd thing, I always thought Stahl headers were stainless for the L6 engines, but Judy stated their mild steel.
  18. Oh, just thought about this ... those JDM headers are likely for RHD cars and thus there could be clearance issues with our LHD cars here in the States. I did a quick check on prices and surfer.tech was correct, those are the prices excluding shipping from Japan. Of course you can stuff them into TonyD's carry-on bags for a nominal fee.
  19. The prices quoted for the JDM headers (if they are indeed stainless ones like the Stahl) seem very low. It was my understanding that the prices were like 2X what you're showing.
  20. and there are none 'in-stock', left-on-the-shelf deals on these right John? I recall each on was custom-built based on the client's specifications. let me know there are any getting dusty somewhere ... btw just to let you know your R180 stub adapters worked great at the track this weekend!
  21. Just how many L28 headers did Stahl sell in a year? The MSA 6 into 2 with the ceramic coating worked fine for me, but I regret not getting a set from Stahl. They were the best USA-made ones commonly available.
  22. I'm impressed. There's a nice race track in Bahrain. I'm going to guess that having a 240Z in Bahrain is rather unusual.
  23. I spent a track day using a set of Dunlop Direzza Sport Z1 Star Spec (205/50/15). It was a fairly common tire at the track. I saw them on a number of makes and models (e.g. Audi S4, Lotus, and a ton of the Z's). One aspect not mentioned is camber. If you're set with factory (zero) camber then under aggressive driving you'll roll the outer edge and wear the tire in a non-uniform fashion. Going to negative 1.5 to 2.5 degrees of camber will make the car very nice for the track and help with tire wear. I found the Dunlop Direzza Sport Z1 Star Spec's to be a very nice tire. Unless you've already done extensive suspension modifications it doesn't make sense to go with race slicks. If you have LSD, coilovers, Techno Toy Tuning's adjustable control arms, and camber adjustment plates, then going the way of race slicks makes sense. For me personally, I have a ways to go before I switch what I have with racing tires. My set-up is a R180 STi LSD, 1" lower-than-stock suspension with Tokico Illuminas, HD linear rate springs strut bars, ST sway bars, and 15" rims. I'm not sure about race tires, but I suspect my tires would last perhaps 4 or 5 days at the track.
  24. We used an Innovate and got RPM, AFM, and MAP. We're going to tune the DCOE's with Jeff Winters and his dyno perhaps next week depending on our schedules. I figured 2 hours with Jeff would be like 2 weeks of me tinkering. He gave us some pointers at the track. Overall the car performed well. John Coffee's LSD mod for the R180 STi LSD worked very well. Everything on the car was well sorted. The biggest short coming on the car is really the nut behind the wheel. I'm a little bit concerned with brake fade but it wasn't that bad. We were running in both Notice and Intermediate class so we only had a 20 minute down time between laps ... which wasn't ideal. The car needs more camber or else my tires will be bald on the outside edges after two more track days.
