RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. You need to switch the type of hose to the braided kevlar or equivalent, and make the hose long enough to make a loop.
  2. Tec2 is a full function stand alone ECU. I can't see using both (if it's even possible) unless a function is fried on one.
  3. Yea you should..... come on back! We need your talents here again.
  4. We can see that you have, as Beaverton, Oregon is now shown in your profile Thank You
  5. That's a Pull type. R33/R34 trans. That will be harder to find compared to a Push fork. Do you have the rb25det trans already, that the push fork fits?
  6. I have one for you Rags. Just PM me your address and it's yours....
  7. OK, maybe I should have said "caused" by detonation......... I still believe it's detonation the OP/tuner heard,, and was the cause of the damage shown to that head. I can assure you the ring lands are collapsed to some degree on at least one of those pistons. Edit: After looking at the pics enlarged, it appears to be pieces of valve guides, and ring lands / rings scattered around the chambers. Post those pics up on the Australia RB sites and see what they have to offer. I'm sure that is a image that has been seen often.
  8. Yep... that's called MAJOR detonation... Same thing on this first 26 I bought. I got another one to use.
  9. I really like the color change. Also, it's good to see a pair of side skirts that look nice too. I have a pair I've been waiting to install, and now I'm not so skerrd to give it a go... Nice job deja!!
  10. This (CLICK) regulator is the one I'm using. You can run any sizes you want with this bad boy....
  11. Search some of "stony's" threads. I think I remember some pics being shown.There are a couple others that may show their pics also.
  12. Turned out nice don't you think! Packaging twins is pretty difficult in our tight constraints using the rb motor, even going top mount... You made it look easy.
  13. Or you can do it like this guy did....
  14. Looks much better than it was I'm sure. I put one just like that on my orig. '74 wheel, and it looked better as it got used and wore in.
  15. Sorry, can't help but can you tell me what that has to do with HybridZ.org? Are you planing to put that in a Z car?
