slownrusty
    12
Everything posted by slownrusty
  1. Guys - I am going to run the BMW 735i635i535i TB. It is actually 67mm in diameter. It looks like this: Compared to the lovely 50mm OEM L28ET TB This TB has no taper so its 67mm all the way through...look at the TPS same Bosch Style set-up as our L28EL28ET cars - bonus!!!! Will require new holes drilled in the intake or an aluminum adapter and of course some messing with the linkage, but heck worth it!!! Not quite as huge as the 70mm Mustang units, but will flow more than enough air for in excess of 500whp. Yasin
  2. Slowdown and put your seat belt on...! Sorry if this offends. Not for the weak...pg 14 is absolute GORE....trust me on that. In the Murcialego on page 1 Czech super-model Renáta Vaculčíková was also burnt alive... http://www.tuning-forum.org/viewtopic.php?t=37656&start=0 Yasin
  3. I have Corbeaus in mine and bought their slidersmounts..installation was easy peasy breezy, next to old heavy (40+lbs) 300ZX Turbo seats that I made mounts and had in my car: Yasin
  4. This is HOT....especially if the spokes were gun metal....WOW Yasin
  5. Mine can be temporarily mounted. Like so: Yasin
  6. How will you make it work? Easy.... By going stand alone engine management.
  7. Congrats! Well deserved Austin (they have some beautiful angles on Austin's car) they have some neat cars, good articles and great photography on there and of course the girls are steaming... Yasin
  8. Clifton - I think you just nailed it, I never thought about shiming up the driver side motor mount for more clearance....that will probably do it (plus another spacer on the turbo flange on the manifold) Thanks - I will let you know guys know. Regards - Yasin
  9. Guys - I am not about to cut up that manifold...and move the turbo flange back, I have waaay too much $$ and time into it plus I need some space for my TiAL wastegate to be mounted. I will see if I add yet another 1/2" steel spacer on the turbo manifold flange if that might solve my issue at this point, I'll try anything! Hopefully that does not bring the turbo too close to the strut tower and hence no room for my IC piping. If you notice in my pics I have already welded a 1/2" steel spacer on the turbo flange. We'll see....more trial fitting. Any more ideas? Yasin
  10. I know this sounds like a funny Title...but my T57/T04 Turbo does not fit...sob...the compressor housing is so large in O.D that it is hitting the steering linkage....can anyone make any recommendations, in terms of what I can do to this turbo or select a new that will fit. I wanted a T3/T4 hybrid, but may have to settle for a T3 that can handle 400whp...please help guys! Here are the pics of this morning's mock-up: The white arrow shows where the bottom of the compressor housing is just resting on the steering linkage. Thanks in advance. Yasin
  11. Nothing like reviving an old thread....for what its worth...I did manage to remove my pan, after jacking up the engine as much as it would go on the passenger side and then sliding it out. A big job for us ZX owners much easier job for the S30 owners. Yasin
  12. Looking great bro....! Keep it coming and put Grey to work!
  13. Looks rich, but reading spark plugs is a science. EGT gauge or an AFR gauge is the only real way to know. when I was running sidedrafts I installed an EGT gauge for tunning purposes. If you run down the 'Springs we can do runs and log it on my LM1, if you like. Yasin
  14. Looks really great!!! I did the something similar but went the cheaper route and sand blasted and then rubberized paint primer and regular paint after that...from this heap: to this: Yasin
  15. Grey - I vaguely remember you...my memory is slipping! Pardon me! Anyhoo...awesome set-up. I really like the T25 and your 190whp seems to be spot on. Starion IC is also a nice piece as well. Great set-up. So are you running the GZE AFM? Whats new over at club4ag these days, I have not been there in ages. Yasin
  16. Nope never seen that...I bet its JDM only. Cool though...
  17. And this is where Yasin "Failed".....wanted to have my cake and eat it too. To bad as my ex was a simply stunning woman...understatement....: ( Yasin
  18. Wow beautiful AE86...there is car that is truly miss...I built some wicked ones in my time and this is THE first time in over 10years I do not have an AE86...someone give me a hug...here is my last sweetiepie (I know shameless plug)... BTW grey_turboae86 - Do we know each other and any specs you can share on your beautiful car? Yasin
  19. Wow hard hit, I saw the tree you hit over on zcar.com.... I would not even pull it...I would be taking my Sawzall to the scrap-yard...nothing like doing it properly and then maybe finishing it with a thin lick of Bondo. Yasin
