Everything posted by Jwink25
A small block Ford has a better weight ratio. The 5.0 engine has tons of cheap power adders out there. Don't be so qucik to dis Ford. The 5.0 can be a very fun engine. If you want to do the Chevy swap there are places that sell conversion kits. So, if you have basic automotive skills, I would think that you would be able to do it. Give JRT a call, they sell the swap kits and have a manuel on how to do it. Good luck. I was going to do the small block Ford swap but am going turbo for now. Once I get my 240Z running I will look for another Z car to do the small block Ford swap. Jason
I was thinking about building a fuel rail as well. But, I am not really sure how to go about it. I was thinking of buying that $12 a foot fuel rail and drilling and tapping for the fittings and everything. But, I have a few questions. Where do I put the fuel regulator? The stock one bolts to the fuel rail, right? Can I unbolt it and just add it right before the new fuel rail? Or, do I put at the end of the fuel rail right before the return line? These might sound like dumb questions but, I am still learning how to hot rod fuel injected cars. I just want to go to battle with as much info as possible. Thanks, Jason
Gotta a 280ZXT engine and a couple of questions.
Jwink25 replied to Jwink25's topic in Turbo / Supercharger
My engine is from an 82...that means no dropping resistor I guess. That's good! One less part to worry about. -
Thanks for the info. I thought there was a dropping resistor. What years of intake did not have an EGR setup? Did all 280Z not have them? Thanks, Jason -
280ZXT engine going into a 240Z and I got a couple of questions. I want to make my own downpipe and was wondering if the metal pipe from the EGR valve to the downpipe is needed? Can I get rid of it? Will this effect performance any? Also, things like the dropping resistor...do I need this? Or will my injectors fry? (I am not sure I have one) It might just be easier to tell me what has to be hooked up, sensor wise. I thought someone put up a list here but, I could not find it. Any info on this guys? Thanks! Jason
I am going to take a sledgehammer to my cursed motor!
Jwink25 replied to alsil's topic in Ford V8Z Tech Board
Sorry I can't answer any of your questions Alsil. But, I hope everything works out for you. I torn into my 280ZXT engine to find a crack in the head by the timing chain. I was hoping for a quick rebuild but,I need a turbo rebuild as well,so I can see the $$$ starting to add up. You might try picking up a Mustang 5.0 mag. They have lots of crate engines in them. Good luck! Jason -
LMAO...that is so funny! Good one.
So, with a 5.75 BS and a 1/2 inch spacer...that would be like a 5.25 inch BS? I have a 5 inch BS. Would 245/40 still fit without rolling the fender lip? Also, got any pics? Jason
What size rims are those? And, what is the backspacing? I just got my 17x8 Centerline Pintails with 5 inch Backspacing in, and was wondering what tire size would look good. I will also have coilovers. Thanks, Jason
Has some one been to TOOHIGHPSI.com. Great site on twin turbo fords.
That's a heart warming story. It's great to know that there are still decent people in this world gone crazy. A big to you both. Jason
Hearing all that...he is a real ass. Just build your engine then whoop is ass, on the streets/track or in the classroom...which ever you perfer.
I kinda think he might be an a$$ but, there might be another side to the coin. Sounds like he doesn't have a lot of money. He might be acting the way he is because he sees you throwing away parts that are still good, "in his mind". And he sees it as a waste. I don't know. Maybe he is just an ass? You might try and give him a second chance. You never know...you could find another friend. If he still proves to be an a$$, you can always laugh all the way to the finish line. And him still at the tree with a broken motor.
Mysterious running lights, headlights, oil/water guage......
Jwink25 replied to fl327's topic in Miscellaneous Tech
My first car was a Maverick and I had the same problem with the lights and the heater blower. The light problem was fixed by checking all the grounds and cleaning the rust off of them. I also had to replace a couple of the light sockets. The heater kept blowing fuses because the blower motor was bad and shorting out. I hope this helps you out. Good luck. Oh, my friends old 66 Ford truck is doing the same thing but I think he needs to replace the fuse block in it. Jason -
Just wondering...is the 300ZX tranny stronger?
The info in my book didn't say anything about having an overdrive. The book I had covered years 79-83 280ZX. Again, this was taken out of a Haynes Manuel. I have that Turbo tranny in storage. My offer still stands. Thanks, Jason
Cool car but the price is...
Hey Tony, here is all the info I can find about the 280ZX auto tranny. This info comes from a Haynes manuel. Model.............................3N71B Code number Non-Turbo...................... X2707 Turbo............................. X2770 Torque convertor code Non-Turbo...................... G Turbo............................. A Small torque ratio............ 2.0:1 Gear ratios 1st.................................. 2.458 2nd................................. 1.458 3rd.................................. 1.000 Reverse........................... 2.182 Seems like the gear ratios are the same but the torque convertors are different. The trannys have a different code number as well. My thoughts are; the Turbo auto tranny might have slighty stronger parts in it or different shift points. Since it has a differnt code for the convertor I would think that it has a slightly higher stall to it. If this is true, then I think that Nissan would have, beefed some of the internals up. Higher stall would make for a harder engagement of the tranny. So, I would think that the drum clutch packs and carrier bearings would be stronger than a non-turbo model. Might be other small changes as well. I know something about auto trannys...I rebuilt and tested Chrysler automatic trannys for a while. But, I am not 100% sure of the differences in Nissan trannys. I hope this helps some.
Those are some beefy tires Dan. I ordered some 17 inch Pintails from Centerline. I want to put 245/50s on them. I think thats about as big as I can go. Thanks for all the info. about the sump. As soon as I can come up with the cash or the parts he needs I'll get it. I have so many other Z parts I need to get. The upgraded turbo is next. Lots of money going into this car, but I know it will be worth it.
So, if I can come up with a M-bar that is from any 280Z that has a R200 in it, you'll trade me for a sump straight across. I have one but am going to use it myself. I can get another one maybe. I'll have to check my sources and see if I can get another one. You are talking about just the rear bar that goes behind the diff right? I want to make sure I get the right part. There was a list of years and car models that had R200s in them...do you know which 280Z cars had R200s in them and what years. I think the 80-83 5 speeds all had them. Do you know for sure? I know where some auto cars are, I am jsut not sure they had R200s
I have lots of extra 240Z and 260Z parts. I might even have a few things from a 280ZXT. I got an extra AMF and some other engine parts. I got some S.U. carbs laying around. What do you mean buy an M-bar? I also have an extra cross member laying around. Lots of stuff. Also, I got another question. If I do not want to put all the extra hoses and that metal vent tank back into the car that come off the gas tank...can I just add like a roll over vent valve on to the stock gas tank?
When I am ready for the sump I'll get ahold of you. Does the $60 include shipping? Thanks, Jason
