Geno750
Everything posted by Geno750
If you don't care about weight get steel lug nuts. Aluminum ones will have issues over time and nothing is more frustrating than having the threads on your aluminum lug nut strip. Muteki and Gorilla are easy to find in multiple colors and are made of steel. Personally I'd avoid red anodized ones, they turn pink after some time in the sun.
There's a pretty good write up someone did with a vintage air unit. Personally I'd buy that unit and have the lines made to go from your RB compressor to it. http://xenonzcar.com/s30/files/DatsunZ_Vintage_Air_1000.pdf
Electric Power Steering Information Compiled
Geno750 replied to seattlejester's topic in Fabrication / Welding
You just don't run the PS pump until you've got a rack to connect it to. Poke around in the engine sub forums and you'll get a pretty good idea of what people are doing. -
For me to go hydro it's literally just a matter of add rack and you're good to go. Making the lines is easy and my motor came with a pump. That's the biggest factor. Those of us with motor swaps can usually clear the PS pump hurdle automatically. -
I really hate you for posting this, and I hate myself for clicking on the thread. I've started assembling the parts I need for hydro, but now I'm calling around sourcing the parts for electric. Thanks for making it a bit easier/harder to choose. 🙄 -
Gearbox fun continues. Removed the stock transmission mounts on the car. Need to at least buy the correct shift rod. The current one is too long to let the Magnum housing seat all the way. So no test fitting for a bit.
- 53 replies
- infinity 6
- aem
(and 7 more)
Tagged with:
The Suprastore manifold is basically a copy of what I'm using with the option to use whatever wastegate you want, or none if going with an EFR turbo.
- 53 replies
- infinity 6
- aem
(and 7 more)
Tagged with:
Greddy large runner manifold from their T88 turbo kit. I cut the 4 bolt wastegate flange off and welded a 50mm v-band on it.
- 53 replies
- infinity 6
- aem
(and 7 more)
Tagged with:
More progress on this stupid gear box. Finally found a shop that can help, they're quite unsurprisingly in Australia. They hooked me up with an input shaft which I'll have in my hands sometime next week. Also, after more comparing, my tail housing, per Tick Performance, is one they've never seen before, but all the castings on the Magnum when it comes to where stuff goes, lines up with what I've got. The only exception being the shifter rail, due to the better for me shifter placement. The TUET7270C gear box has an almost identical mainshaft, it's a tad under 20mm longer. Which matters not one bit, because you need a custom driveshaft when using one of these in a Datsun anyway. Here's a better set of pictures explaining why I think OverkillZ's picking up the late John C's mount is helpful. I'm running an almost bigboy turbo, and you can see the issues I'll run into as I start the downpipe and inlet for the turbo. The motor needs to lean towards the driver side if it's going to lean at all, and needs to shift more towards the driver's side.
- 53 replies
- infinity 6
- aem
(and 7 more)
Tagged with:
When these guys were first starting to offer a kit they sold a few plates on their own - https://www.inductionperformance.com/products/induction-performance-ign1a-coil-kit I had to source my own coils, hardware to mount the plate to the valve covers, and my own spark plug wires.
I ran into it on a different engine. Bought a hks DLI and that solved it. For these cars though it could be due to cracks in the boot on the coil, or just an old worn out coil. Could also be too much spark plug gap. If it's none of the above and you're shopping for coils there are a ton of aftermarket solutions for people on stand alone ecu's. Everything from R35 GTR coils to GM truck coils, even Mercury Marine coils have been used on these motors.
I'm on a 1JZ block, but the way I have the WG done there's ample space there. I need to move the motor towards the driver side for more compressor housing space, it's very close to the shock tower, making the inlet pipe clearance a bit of a problem.
- 53 replies
- infinity 6
- aem
(and 7 more)
Tagged with:
So I've been doing more work on the drivetrain end of things and this Ford falcon transmission is more of an oddball than I thought. It uses a Magnum XL tail housing to allow for direct shifts and places the shifter further back than you'd want in our cars. Solution, buy a $250 take off from a T56 Magnum and swap it over. Only, life isn't that easy, you also need a main shaft too, and that's another $300. Good news is I'm still under $2k. Bad news is I get to swap main shafts on a transmission I've never worked on before.
- 53 replies
- infinity 6
- aem
(and 7 more)
Tagged with:
You mentioned the rear conversion you did in another thread, got pictures?
- 90 replies
- suspension
- 240z
- (and 5 more)
Measurements for CD009 and R154 and trans tunnel
Geno750 replied to seattlejester's topic in Toyota L6 Forum
Moving the giant pig of an engine we have that far forward to facilitate easier shifter location will be at the detriment to handling. You want the motor as far back as possible. -
I BOUGHT THE John Coffeys 2JZ/1JZ ENGINE MOUNT JIG
Geno750 replied to OverkillZ's topic in Toyota L6 Forum
IIRC, these use the newer version of the mk4 Supra mounts. Not just any mount will work correctly. Is this accurate?- 5 replies
- betamotorsports
- 2jz
(and 5 more)
Tagged with:
I've driven a car with the endurance disc and unless you need the extra torque holding ability, I'd go for the full faced disc. It'll do better in traffic.
Yeah, that means you'll be stuck with single plate 350Z clutch discs. This would probably be the one I went with: NSK1000-SS-O. It's good for about 550ft/lb of torque.
Which version of the kit, if it's the one that runs a J1/J2 Bell housing you've got good options. If you have the older kit that requires the custom flywheel it's more limiting.
Sell both systems, get a TR6060. That's what I ended up doing. Stronger, more shifter and part options, way more clutch options.
I'm using a 3/32 tungsten. I haven't really welded anything really thick yet so I can't say. I'd imagine thicker stuff is easier with the right settings. I think I did that piece at 60 amps
Fwiw, here's one of mine.
