Partially correct, for polyester resin anyway. If using polyester resin, on your last coat, you need to add a Surface agent to the resin/hardener mix (a styrene wax solution used to cause polyester, and vinyl ester resin and gel coats to cure tack free). If you don't add this to your final resin coat, it will not fully cure, and will remain tacky, and won't be sandable. If you are using an epoxy resin system, then there is no need for a surface agent, as it will fully cure on its own. I prefer epoxy because it doesn't stink as bad, and it is stronger.
