You still don't need to take it apart. Just clean it with solvent and blow with compressed air. If you drill out the rivets, you will need to replace them. Not sure what the rivet size is, but if you try to install the gasket without rivets holding the layers together, the layers are bound to shift when you try and torque it. The uncompressed 2mm gasket is about the same height at the head locator dowels, so it is a little tricky even with the rivets in place.
Just another note: are you running crazy amounts of boost where you need a metal gasket? Are you 100% sure about your tune where you will not have any detonation? Stock head gaskets can easily handle 15psi, and act as a nice safety fuse if you detonate. I would rather swap a gasket, than a crank, rods and pistons if my tune is on the edge or I get some bad gas.
Just an FYI....
