HowlerMonkey
RB20 maybe?
The aladdin came out in 1929. I can actually cover holes up to 1/4 inch without filling them using the aluminum brazing rod from harbor freight........which is a probably a chinese copy......but it works fine. Just make sure the surface is clean. I've also repaired nicks in props with it.
That dent in the front for sway bar clearance is in the exact same place as where the sway bar sits on a R30 or R31......maybe some other cars as well.
Any of you guys tried the aluminum brazing rod(aladdin rod)? I will try it later this week.
That's from the oil and it was probably pretty new oil.
I raise you a Mitsubishi 3000gt vr-4 I wonder if Bob Lentz still has his GT2 inline 6s now that he went to a VQ in his GT2 car. The guys who used to run Datsun Dynamics might have a line on engines already built or can build a gt2 engine. Thier current enterprise is auto expectations in sterling, VA. http://www.facebook.com/pages/Auto-Expectations/10150113583150347?sk=wall&filter=12
Stall / Dying While turning or launching
HowlerMonkey replied to Jamasaurusrex's topic in S30 Series - 240z, 260z, 280z
Maybe the positive terminal of the battery is momentarily contacting the body during launches or a corner. -
At our local U-pull yesterday, I saw 2 acura 3.5tl engines, 2x H22s, 1x L-26, 5x vg32de, 4x vh45de, 2x lincoln markVIII engines, a billion vg30s, 3 2jzge, 5 LS400 engines, and about 11 northstar motors that looked untouched. Engines are now $250.00 complete rather than the lower price of just the long block. Not a single LSx engine has even been spotted at these yards but tons of LT-1 are there. Of course condition means almost more than the engine type.
What would california say to a 1991 Infiniti M30 with a L28et?.........if it passes the sniffer? Engine management is currently the 1991 system the car came with.
Nobody specifying whether single chamber or dual chamber mufflers? One is more than twice as loud than the other.
I'm pretty sure getting rid of all chevy luminas would do more toward cleaning up the air than most anything else. I see more luminas running around on 5 or less cylinders than any other car.
How does a 1987 supra turbo compare to a 1984 300zx turbo?
HowlerMonkey replied to Okay Z's topic in Nissan V6 Forum
In GTU trim, the 7m made 300hp which is what we made at z shop of miami for our GTU car.........with a L28 based engine. In GTP and GTO, toyota went with 4 cylinder engines. -
All engines here are $150 and I got a L28e from a 83zx with alternator, flywheel, pressure plate, a/c compressor.
260hp acura TL and CL engines are all over the u-pull yards here in west palm beach.
Farthest driven,Longest road trip anyone's done?
HowlerMonkey replied to Hi Def's topic in S130 Series - 280ZX
I pulled a u-haul trailer from front royal virginia to Orlando.....then back up to virginia empty for another trip down to orlando in 3 days..........paying only the one way trip from front royal to orlando. Good thing I was in front royal where they were too lazy to even watch me hook up or Uhaul would never have allowed a 280zx to connect up a trailer this size. I built a large receiver type hitch which used the bumper shock bolts in addition to bumper mounting but was short enough such that I didn't worry about something pushing the assembly into the fuel tank if I got hit or hit something. I packed a few rubber dogbones in the rear springs to limit the down travel of the suspension and carefully loaded the trailer to keep tongue weights managable and the car drove perfectly level and smooth. Of course, the turbo seized only 200 miles into the trip so I cut a thin piece of stainless from a floppy disc, undid the two bolts on the turbo drain, slid the metal in to block the turbo drain, replaced the "T" on the oil supply with the gauge sender, and disconnected the wastegate actuator to keep the gate open. Then I drove around a large tire tread from a truck on the highway and it clipped one of the long tire valve stems and cracked it such that centrifugal force would only cause leaking when the car was going fast. I noticed it when I was filling the tire and found a very short flat head wood screw and used it as a buttress to keep the valve from being pulled by the forces at speed......but not before using ultra black to seal it. 10 miles later, I got my second flat tire in 23 years but I happened to have a zx turbo swastica wheel and tire I was transporting so I used that as the spare congratulating myself on fixing the other tire instead of swapping the spare at that time. I drove on that tire and seized turbo for 6 months. I later towed a 1984 maxima with a car dolly using the 280zx. Great car for towing as long as you only brake in a straight line and don't even attempt it if the zx has bad rear shocks. -
Please post ECU pin output pictures
HowlerMonkey replied to UH-60ZX's topic in Ignition and Electrical
Battery connected backwards fusing the injector driver/s. Only takes a second. -
Took a bit longer than I expected. It seems to be relatively unworn for the high mileage but it only did duty on a 1984 maxima with an automatic transmission. The cv type axles butt against the spider gear pin which has a flattened section on each side. This is what you see inside the axle hole. Here's an impression on the ring gear if the detail is not enough on the photo.
These roads here will have 5 inches or more from trough to peak on a washboard surface one day and be dead smooth the next. I'm sure grumpyvette knows what I am talking about and that the amount of energy that the shocks are being asked to absorb is pretty intense. It's an extreme situation but I endure it every day and I would rather my shocks not be insulated by an air gap from any cooling I can get. I'll try to measure the heat next time I have to endure it.
It only takes one ride down a washboard dirt road here in west palm beach to heat them to unbelievable temperatures. Some of us have no choice but to drive them.
I just populated the ecu connector with the missing wires when I made a ECU testing harness for this. Blue Streak electronics had harnesses and wiring diagrams for all of the nissan engine management computers. I probably could have skipped making a harness for this ecu but the orders came from the canadian facility.
I usually fill the space with something that will best conduct the heat generated by the shock to the surface of the strut housing so it has a better chance of not overheating during hard use.
SU swap, now hits wall at 5k in gear
HowlerMonkey replied to PurePontiacKid's topic in Trouble Shooting / General Engine
You guote a statement made from 25 years experience and observation and try to call it a question? There are plenty of other threads in which you can do this. This is not one of them. -
It was good for 500hp over a non power recovery Wright 3350.
For this setup, your basic need is an engine management system that you can select your spark timing. I'm running 8 pounds of boost on a f54/p90 setup on a unmodified factory M30 ecu that has crazy aggressive timing in stock form and it's close to being too much timing. Even a stock type ecu will work fine if it's either purposed for turbo use or the timing map has been optimized for boost. If you are able to pull timing, you should be able to get away with 10psi on 93 octane.
I pretty much only have the soundcards left of that setup and am looking for a newer motherboard that can fit them or a more modern card that uses PCI slots instead of the old ISA slot. When that workstation died, it had the awe32 card and two terratec ews88d cards used through a Vm200 digital mixer using adat inputs and outputs. Those old awe32s had a spdif digital output which was largely undocumented.........but sweet for avoiding any analog passes when mixing and recording either the onboard emu8000 synth. or using same to play samples. I haven't checked but technology surely has passed my by in the DJ industry but it seems latency is still an issue for many types of equipment.
