manninen
    6
Everything posted by manninen
  1. Did not pass MOT cause rear control arms, welded swaybar links were ok. But i have working ABS
  2. Yeah you´re right, looses grip before anything breaks. Motor mounts are well engineered
  3. Body twister, something is gonna break.
  4. I use noise cancelling bose headphones on longer trips. Lightweight and best sound for car
  5. 2+2 http://www.speedhunters.com/2015/08/1000hp-of-datsun-fury/ This is nice build 2+2.
  6. I can´t stand car not being driveable and i need clean to my garage anyway. being still one arm man all i could do is to assemble old rear axle parts together. Car is on it´s wheels tomorrow. More upgrades maybe next winter Wonder if i have working abs
  7. arm is getting better so i could file some holes. on frame those M10 which supposed to be 68mm spacing i got 67mm. i watercutted both spacing so i have to put them to frame and measure few things. maybe cannot perform that just yet. This part weights 1640g, mustache bar with bushings were 3.2kg. i dont know how much heavier this ends up when its finished.
  8. got this over month waiting, but snapped my arm today so maybe 2 month pause from everything.
  9. Yeah, doesnt help when large swaybar is hooked up those. Material needs to be chosen right at least
  10. Those pics i have seen before. Sure i believe you about those to be broken. Just wanted to see one, was it that 4mm transverse link plate to crack or 10mm bolts ripped thru from body?
  11. If one side goes other side will follow. Its possible if theres loose bolt some of those 8 bolts. Maybe if someone post picture broken one i lower my 100% it will last rate to 99% But yeah, im changing these
  12. That flex on rear might be from bushing, i dont think that moustache bar to transverse link support change a thing. Only helps if you drift mad with wide tyres. I have incoming watercut part which replaces transverse links and moustache bar to one part and uses same hooking points. Other post its said catastrofic failure, havent heard none of stock tranverselinks ripping out of body, even on 1000hp have been ok. I thought that front supports too but i have no room on front, 4" downpipe and gearbox blocks everything
  13. You can easily tune your air gap sensor like that. I got fixed air gap of 0.5mm. What is recommend air gap for sensor like that? Seems you have hall sensor, that is easy to check cause it just switches that in coming voltage, its not as strict to air gap like inductive is. If it switches it work. Inductive on abs case lits abs light if there is 0.5mm difference
  14. Havent heard whole aluminium case 188 but E46 E39 compact 188 is slightly lighter. Keski-korpi drifting team uses welded one on their drifter. Ripped of from subframe last season
  15. 3.45:1 168mm diameter ring gear blow up. usually its planetary which goes out. mine´s are 2.79:1 and 2.65:1 ratios. Wont´change to 188 cause 168 has been good, its lighter and less parasitic loss
  16. So no problem registering car with heim joints (T3 rear control arm) in switzerland?
  17. This type of parts looks best swap before changing whole rear axle to something else, S13 ,S14, R32 or even something else. My fragile parts has been fine cause automatic transmission, Small case bmw diff can be broke even stock 4-cylinder bmw engine with manual transmission. Started wiring abs so they are 80% done damn shieet, that barra looks similar to OM606. CLEAN!!
  18. I might not even have as much movement as this car has
  19. Ookkay... mod is done and what i´ve notice this link angle that turning wheel binds sway bar a little. Turning wheels right, right side tyre goes slightly up and left side goes slightly down (sway bar movement such as you´re cornering left) not 100% happy about it but glad it´s not other way around. But i don´t know what it does to steering, driving over bump it might give some steering input, dont know it yet. When putting car first time sideways i know if i have to put it back to stock or trying that shortened 18mm bar with better link angles
  20. https://engineswapdepot.com/?p=38918 Just searching how they do rear axle/diff on these monsters.
