proxlamus©
Everything posted by proxlamus©
  1. If you goof up on spraying the paint, nothing a bit of wet sanding won't fix Oh yeh. If you buy a compressor.. its all about the duty cycle and CFM. The gun requires the following : 12 CFM @ 43 PSI. If the compressor specs are greater then that, you should be fine. The compressor can be running non stop, as long as it provides a steady 12 cfm at 43 psi you should be fine.
  2. http://www.eastwood.com/internal-frame-coating-w-spray-nozzle.html Best bang for the buck I've found. Cheaper then the 3M product.
  3. Awesome! Thank you for sharing that info!! Awesome stuff!!
  4. Ill buy em! i'm about to invest in a 280yz kit
  5. http://www.jegs.com/i/Jegster/550/942703K/10002/-1?parentProductId=753931 << Funny, its the same cage but cheaper http://forums.hybridz.org/index.php/topic/85980-jegs-drag-style-roll-cage-installed/page__p__815294__hl__%2B+%2Bjegs+%2Broll+%2Bbar+%2B__fromsearch__1#entry815294 pics of one installed
  6. Everyone replying is giving you some excellent feedback, but your replies are very broad and are lacking detail. Have you tried anything that the experienced members have recommended? If yes or no, please respond in detail so we can better analyze and help you with your problem.
  7. John, that article was PERFECT! Rock solid answer to my question!! Thank you!
  8. Did I mention, that stripping a car is the worst thing I've ever done?! Prepping for seam welding is horrible. stripping paint on the inside of the car is horrible. sandblasting at home is horrible. Spend the money, tow it to a shop, let them blast it.
  9. I still keep seeing new diesel trucks with these on the tail pipe Look at the top left exhaust. Why is that "tip" shaped like a augmenter?! Why the spacers?
  10. JMortensen thank you for the info! You've made me decide to stick with the factory tank. I love you.
  11. Daniel, You can use garage door weather stripping to go under the spoiler to protect the paint. Obviously cut to size. People also use it for going under ZG flairs. Home Depot sells it. MD Building Products 2-5/8 in. x 18 ft. Vinyl Replacement for Garage Door Bottom $15.72
  12. I ran this camshaft for some time! I used diesal engine oil, due to the high levels of zinc to maintain the camshaft life. That's so bizarre that one lobe is messed up! How bad was the valve clearance?
  13. At least we know you use the search function eh?
  14. Neat! Wonder where he found out about this dual wastegate setup on a 4 cylinder?!
  15. Thank you, thank you, thank you! I noticed some of the cage/reinforcement passes though the firewall. Isn't that against the rules in today's sanctioned bodies?!
  16. Nice! Very clean install! I'm still watching this thread! FYI - Post #2,000 for me! yeppie
  17. MSA $139 http://www.thezstore.com/page/TZS/PROD/40-2860
  18. http://www.hrpworld.com/index.cfm?form_prod_id=5325&action=product 24" Wide Gold Heat Reflective Film - per linear foot HRP-GOLDFOIL 33.99 Gold Foil - Reflects Up to 750°F http://www.hrpworld.com/index.cfm?tpc=Aluminized-Heat-Barrier&form_prod_id=4252&action=product Aluminized Heat Barrier - 40"x 36" THT-14001 79.99
  19. cool! Mind sharing any pictures of that beast?! =)
