Evan Purple240zt
Everything posted by Evan Purple240zt
  1. I can't imagine he would be able to get over at that speed travelling down the middle of the road if he came upon traffic.
  2. Count your lucky stars you didn't crash your car because of the TC rod. Consider it a good day IMO.
  3. Is that an oil cooler behind the intercooler? Looks good! Evan
  4. Quick question, thumper got me thinking about this with his actuator question. I run 22+ psi on my motor. I am currently using a 7psi spring and regulating boost with my boost controller. Is there any advantage to using a 14psi spring? I never run under 14psi really.. Just curious! I have noticed boost falls off a psi or so on the top end. Thanks - Evan
  5. ^valid point^ especially since one is bent. BUT, if you can get a good rod for a reasonable price its surely cheaper then having someone straighten a bent one. Evan
  6. Buy a good used rod, should not cause you too many headaches that way. Evan
  7. JOANNE fabrics actually stocks some headliner material, along with some really nice black vinyl. Evan
  8. Having mig welded, I disagree. There is definitely enough slag to be concerned about others property. However, I do agree it is pretty minimal. All it takes is one spark to ruin your windshield. Evan
  9. I have had great luck cleaning pinch welds of rockers with a knotted wire brush mounted on a grinder. Made SUPER short work of the paint. WEAR GLASSES, the speed stuff wings off that wheel is scary. Evan
  10. Z32 tranny does NOT bolt up without either an RB25DET or an AWD bellhousing.
  11. This thread is hilarious, where did I miss the part where it says goldfish group buy? That said... lets do a goldfish group buy! Evan
  12. So your paying what for what? 6k sounds too cheap for a running RB26DETT swap completed IMO. If thats the case, thats a deal! Evan
  13. Mine was mounted like that about 8 years ago. Worked fine, but I had it closer to the core support. That mounting "style" is as old as time... or at least Scottie GNZ's car! lol
  14. Its not accurate throughout the RPM band. I could swap in a 300zx gauge to my cluster if I needed perfection. I dialed it in so rev limiter is at redline. I certainly don't need it to drive, so it does the trick. Evan
  15. Personally, I think it would be real rough on the water pump itself! Neat to know that you can use that pulley on there though. Evan
  16. No offense, but with these questions you seem very ill prepared. Converting your car to AWD is something that is based in fantasy land. I am not saying it can't be done... just that the time, money, R&D to make it work would not be worth it. It would be cheaper to swap your car, and buy a WRX imo. I won't even get into the transmissions. Do some searching. You won't be using the AWD trans unless you heavily modify it. Not worth it IMO. There is a writeup on using an RB bell on a Z32 trans. Read it. I am 99% sure there is no RWD 6 speed, or AWD 6 speed for that matter. Evan
  17. Don't forget ARP fasteners and forged pistons. Evan
  18. Wow, what a unique shot! Your fortunate the photographer got such good shots. Awesome.. Evan
  19. Thanks for the information guys, unfortunately it seems as if my boost controller finally died today. I can't get boost over spring pressure at all now. I bought it 10 years ago, used.... I think I got my money out of it. I think I am going to go profec B this time. Evan
  20. Headsup, even if they are bad I think Koni will rebuild them for a nominal fee. I know those shocks are at least 100/ea for my acura CL. Evan
  21. I didn't know there was a problem running an aftermarket tach on an RB. My stock 240sx tach works fine. Evan
  22. Alright guys, this is actually for my GF's 2.3cl. I put a full exhaust on it years ago thats 2.25" with a straight through can on the back. Its WAY too loud and annoying. I have already gotten a warning in WI for it. I want something that flows reasonably well and is quiet! It does not have to be flashy. If it looks stock-ish thats fine. I would prefer something thats not prone to rust. This is for a 2.3 liter motor FYI. Thanks a lot guys, I come to you for help!!! Evan
  23. I can get it at that price in 5 gallon increments. Its a place in northern IL if anyone is interested PM me and Ill try looking up the guys info. Evan
