calZ
    26
Everything posted by calZ
  1. I guess I could be mistaken, but aren't these R32s? https://i.ytimg.com/vi/obp91cGrO0E/hqdefault.jpg http://www.speedhunters.com/2010/02/readers_ride_gt_gt_skysuka/ https://c7.staticflickr.com/8/7214/7202592918_473e22010b.jpg https://jdymotorsport.files.wordpress.com/2010/10/sky3.jpg
  2. If you google image search "r32 two tone" there are a few different options that come up in the results.
  3. Not sure if you're still looking for a bearing or not, but I think this could work for you: https://www.thebigbearingstore.com/1-1-8-four-bolt-flange-bearing-ucf206-18/
  4. Unfortunately, yes http://www.tirebusiness.com/article/20160610/NEWS/160619999/calif-emissions-test-bill-fails-to-meet-passage-deadline
  5. Which tab? The one that supports the nut? I hope you're not saying the transmission crossmember is supported by JB weld.
  6. And your control arms are at a negative angle, which is not how the suspension was designed to run. Like 260DET said, getting it on and functional and having a grafted suspension that's in its proper ride height range are two very different things.
  7. Are those Recaro LS-Bs recovered in falsa blankets? That's really cool
  8. If it's about making a Z into an EV, I would suggest putting it in the Other Engines forum. If it's not related to Zs at all, Non-technical seems to be the "off topic" forum.
  9. I would just put a surge tank in. Since the Chump rules don't let you modify stock fuel tanks you can't legally do anything like a Hydramat or a cage.
  10. So this will include just the bracket and e-brake cable, correct? I am interested
  11. You have to donate money once to the site to start a new topic in the For Sale area. It's to keep bots from spamming. http://forums.hybridz.org/topic/125970-diesel-l28-engine-value/ That's a different discussion where someone actually gives a value.
  12. I think Tony was just making a joke that flange on the collector side looks like a Batarang.
  13. That's very possible, but it wasn't how it was applied in this instance. It could have just been a tech inspector being extra picky or misinterpreting the requirement. I agree that it makes sense to keep the instructor or passenger just as protected as the driver.
  14. Similarly, there are some organizations that, if a car has a passenger seat, require the passenger harness to be the exact same as the driver harness. So if you have a $500 Schroth on the driver side, a $70 G-Force belt isn't sufficient for the passenger. If you go with the $70 belt on both sides, though, you're just peachy. It makes no sense at all.
  15. The usual places have "OEM" cables for $160+. Zcardepot also stocks a reproduction cable for $86.
  16. I'm not able to find the 4th edition through the normal sources. Where did you guys order from?
  17. If you jack the car up it's not too bad to get a long screwdriver or pry bar into the latch and just pry the release arm over. http://forums.hybridz.org/topic/107117-howto-release-a-240z-hood-when-cable-broken/
  18. Looks to me like he filled the cracks and repainted. It might be my imagination, but there seems to be remnants of the cracks over the center gauge cluster.
  19. Normally accessories like this that connect via wifi have their own network. Many action cameras sync with phones via wifi, and you can do that anywhere.
  20. Do you have one? I'm in LA and could use a clean hood.
