calZ
    26
Everything posted by calZ
  1. That's unfortunate. Glad to hear that the new shafts are better quality, though.
  2. Did T3 send you new shafts or did you order some from a different company?
  3. The location and cleanness of the break almost makes me think the heat treating of the splines made the axle brittle.
  4. Jesse is great to deal with. I second Duffy's recommendation.
  5. This is awesome! Do you mind if we share other places?
  6. This has the potential to be one of the best threads in this site's history. It would be awesome to end up with complete database of head flow for the different combos.
  7. The first ice cream trip is a great payoff for the hard work.
  8. $170 is a lot less than I would have guessed for shipping something that size across the ocean. I've paid half that or more for shoebox-sized boxes from Japan.
  9. You're getting this made in England? What's the shipping cost? It's not that hard to make polycarbonate windows using the glass as a pattern.
  10. That's the nicest looking floor I've ever seen. Incredible work.
  11. For me it works more often, and when it does work it's very snappy. When it's slow, I just hit refresh and go to a different tab for a moment and it'll be back by the time I return. It's still not perfect, but I think it's better than it was.
  12. Ferraris have louvers in the rear because that's the engine cover rather than the rear window. I guess it will be ok as long as it never rains. Hopefully it doesn't suck in too much exhaust.
  13. I agree. Are you sure the Prothane bushings don't use that outer sleeve? Most poly kits I've seen are like Mitchel said. You might want to see if the bushing slips in as it sits.
  14. Are you going to have to take the intake off whenever you want to open the hood?
  15. The "rumor" about Silvermine comes straight from the Z Power Steering site, but it isn't necessarily wrong. I believe Silvermine uses an EZ-Steer kit to make their units. Those are designed for ATVs that weigh more than most Zs and experience a lot rougher roads than a car does. They likely don't have the factor of safety of an OEM automotive unit like the ZPS, but it's up to you if that matters. I have seen multiple people who run the Silvermine kit on track and have never seen a complaint, and the EZ-steer kits get used on street rods a lot. If there were an issue with the SM units, I would have expected to see some firsthand accounts of failure online, but I've never even heard secondhand of one having issues. Here's a discussion we had years ago about delay with these units. Interestingly, the only complaints were about force-sensing units. The GPS is also only necessary if your car is stock without an electronic speed signal. I'm not sure how your car is setup, but with a VSS signal, there would be no chance for lag. If you have an aftermarket ECU, you could even setup a custom assist curve if you wanted.
  16. Are you going to remove the metal beneath the carbon skins?
  17. Flatout got a set of control arms that were made too narrow and don't fit. Apex seems to have been sending things very slowly lately and then having a low rate of good parts when they do send them.
  18. I've noticed that refreshing the page when it hangs seems to help. I can go down the main page and open new tabs with all the threads with updates, and some will load right away while others won't. I refresh the ones that don't load, and then they seem to come up. It isn't a 100% success rate because sometimes they fail to load again, but it's almost like some queries get lost and sending them again kicks the server into gear.
  19. Welcome! Always great to have a new member and another project. What kind of modifications are you planning?
  20. The tire temp data is great! That's high level race team stuff.
  21. Looks like around 2010 he was drag racing a Z. If I had to guess just based on how forums (especially this one) used to go, he probably shared some of his videos here and got flagged for that.
  22. It's doing it today. It's never been this bad for me before, but I see what you mean now.
