tube80z
Super Moderators-
31
Everything posted by tube80z
Looking for tips on air pressure for slicks
tube80z replied to heavy85's topic in Brakes, Wheels, Suspension and Chassis
I think a lot of it depends on tire construction. The FA tires I use on my car seem to work best for me at 18 PSI HOT. I generally start in the 16.5 to 17 range with them cold. I've never had a tire come off the bead but a few of the hoosiers had issues with not holding air. Well after that fact I heard they may have had a construction problem. A lot of this depends on how much your car weighs, etc. If you want to get real tricky you can play a couple of games with your tires. You can paint them with latex and put them on paper to look at how the contact patch changes with pressure, camber, etc. This is best done by using a modified press. Or if you need to see an actual pressure distribution you can use Fuji prescale pressure sensitive paper. Cary -
IR guns aren't very useful for tires. The surface temps drop too quickly and they have a tendency to even out before you see the real trends. They are very useful in taking track temp measurements. You really need a good probe pyrometer. Just remember for autox you'll never see the core temps that road racers speak about. If a hoosier R25A slick will show you core temps in the 100 to 125 range when it is working good. When you get over that you'll find they are getting greasy. When taking tire temps remember to take 5 tire readings. What I mean by this is start with one tire (always the same one and usually a front), work your way around the car, and then take the temp of the tire you started with. This will let you see how much temps are dropping as you go. You can use this to guage if a tire that you took the temp of later is actually hotter. In general, once I have established that I don't have an outside edge hotter than the middle or inner I will usually only look at the middle and inner for what needs to change. Remember toe-out heats the inside and toe-in heats the outside. This can mask how the tire is used. For autox pressure rise is a better indicator of how the tires are being used, IMHO. Work to get the front and rears to come up the same amount. You'll also have a target hot pressure that you'll find that works best. You'll need to adjust the starting temp based on ambient temp. Always use the driest air you can in tires. Any water that is condensed and turns to vapor will cause an abnormal amount of pressure rise. Adjust pressure in 20% increments to figure out what works best. That will quickly let you see what you need to do. Cary -
Progress on my front splitter
tube80z replied to 240hoke's topic in Brakes, Wheels, Suspension and Chassis
It would appear I lost most of my pics when I lost a hard drive last year. I do have some from when I started my experiments that would give you an idea of what I did. The u-shaped piece seen in the photo below had a top, which is in the second photo. Unfortunately I don't have anything close up or of the holes I put in the engine compartment. All I did there was put 3 inch holes in the inner fender in front of the strut (3 on each side) and flanged teh edges. Cary -
I just got a new book from Simon Mcbeath called competition car aerodynamics. You may want to get a copy before going too far. They did a number of CFD studies on a generic shape that's close to a Z on the front. It shows airdam, airdam with belly pan, splitter, and splitter with diffuser. They all work a little differently and change the flow around/under the car. Simon writes the aerobytes column in racecar engineering. This book is basically those columns expanded. I'm pretty sure all the Z's had a splash pan. I put holes in my inner fenders to help vent the engine compartment when I ran a belly pan. I then used gurneys on the front of the fenders to help create more of an extraction, which helped to lower the engine temp. I also created a simple diffuser in front of the radiator. That's another thing you can try to make things more efficient and make the entire openning smaller in the front. Cary -
Adjustable Rate Springs
tube80z replied to cygnusx1's topic in Brakes, Wheels, Suspension and Chassis
I'm not really sure what you're talking about on F1 cars. They all use torsion bars these days and you can't change the rate of those unless you change the bars. That said most can be pulled out in about 15 to 20 seconds and a new one installed. I'd be curious to see the pic if you can find it. Cary -
A few years back there was system that Eibach was using on a F3 car that allowed for adjustment by stacking to coils and usiing a special cylinder that put preload on one of the coils. Because the springs were stacked this is how the rate could be varied and it allowed it to be varied over a range if needed through having one of the coils stack solid. It's an intersting idea but I think it has some problems. From the drawing it looks like it is designed to screw up and down a spring. This will limit it to a certain rate as most springs have different pitches and diameter if wire. My second concern would be that this may cause the spring to put more side load on the shock since it isn't using the regular closed end. If you want to see what a coilspring does head over to hyperco and look at the video of their hydraulic spring seat in action. I think you may find it interesting to see how much the spring roates (it's basically a torsion bar). Cary -
Strengthening Front Anti Sway Bar Mounts
tube80z replied to 260DET's topic in Brakes, Wheels, Suspension and Chassis
Looks good to me. Just think even with a little boo boo it's much better than most of the bars people have on their cars. You saw how easy it is for a lot of this stuff to bind and you've taken the time to fix that. Cary -
It looks like you came up with a solution. I use 3.8 tap tube from coleman and left right taps for this. The taps weren't that bad and I've used them enough to pay for themselves. I also have the 5/8 and 3/4 tap tube for suspension bits. It's come in very handy over the years. Cary -
I can't say I can end this debate but I weighed a 280 motor (can't remember if it had a flywheel and clutch or not) but had most everything else. It was very close to 500 lbs (~227 Kg). I also had acess to a normal SR20 (not turbo) and that engine weighed 325 lbs (~147 Kg) and I can't remember if that had a flywheel and clutch either. Hope that helps, Cary
Does it bind from being too short? That's what I'm guessing. I'm also guessing that it's a lot easier to tell when it binds with your new setup. Cary -
So when this all started did you think you'd be building a trans-am car Cary -
Suspension hits frame/floor!
tube80z replied to JMortensen's topic in Brakes, Wheels, Suspension and Chassis
If you were to run the car in a way that you actually used the bumpstops as a tuning tool then I'd look into the late model VW stuff, which is pretty trick. It sounds like you'll only use them to keep the insert from self destructing and poly should be fine. When I went a lot stiffer with springs I quit touching the bumpstops and now I only have them in place to save the inserts. I shortenned mine up a bunch and if I were to hit them it would probably feel like they were solid steel. Cary -
Most of the race shops sell them. They aren't that hard to make if you have access to thin plastic sheeting. Truchoice has them in their catalog but they are very proud of them. C -
A packer is usually a small plastic bit you put around the shock shaft to change the spacing to the bumpstop. It looks like a C. The idea being if you couldn't find longer bumpstops you could use these as spacers. You can insert them through the springs with needle nose pliers to adjust when you hit the bumpstops. And speaking of bumpstops are you using something like the VW soft foam versions? Cary -
What about using packers? Cary -
Yep, and he's a bastard! Cary -
I think Vic's car was fast because he was the first guy to start playing with some stiffer rates and getting them to work. Locally we have a number of Zs that have copied this (including the red one in your earlier pic, which belongs to Dave Kipperman) and they have all responded very well. Before we started doing this we all got beat by Miatas, vettes, RX-7s, etc. You'll also notice Vic doesn't have any bumpsteer spacers and appears to be using an EVIL underground front RC, which I have found to work very well for me in autox. What isn't mentioned is when you hook the sway bar to the strut it acts like it is larger because of the reduced motion ratio. I think you'll find a 7/8 about equivalent to a 1 inch bar in the normal locations. Cary -
This should work fine. I agree you really want the lever on the sway bar to be at a 90 to the linkage that goes to the lower control arm. In your previous example the bar looked to have a falling rate. In the past I've made a few adjustable bars like this by grinding a falt along one side of the bar and then placing the 1/4 plate on this and welding along the edges and a few plug welds too. You can put build all the anlges you need into the plate. I hope that makes sense, or you'll force me to make some poor drawings too Cary -
You'll also be adding dive if you drop the front location down. Cary -
I was hiding in Mexico for the last week. Managed to get good and sick so I can't say it was a lot of fun. A couple of things I noticed on your pic with the heims hanging down. You have them screwed out quite a ways. On the TA cars they had them threaded in all the way and held with red loctite. I also noticed the ears have a bit of clearance for the heim, this can be taken down to almost touching and you could gain a little more clearance by thinning the section under the heim. You can also rotate the clamp, it doesn't have to be in a direct line, mine weren't. But you need to make sure things are clamped really tight. I think you'll find that if you rotate it up and move the heims in you'll have enough clearance. Cary -
8s would be a lot easier. But all this is in the stock location so I don't see the issue with interference. My tube was 6 inches long. You can't go too long and as you'll run into the curve on the bar itself. I think I only moved it about 2.5 to 3 inches total. Mostly I left it alone but I could brag it was adjustable and that was worth at least a half second For the spacer use one that presses in and then you can run one bolt size smaller and you don't have bits if spacer falling out, which I agree is a PITA. And for a bolt consider a pip pin. You can pull it with no tools if you want to disconnect the bar. I know a national level Miata driver that does this when it rains. Hope this helps, Cary -
For some reason when I wrote this I was thinking about the front swaybar and not thinking rear. I agree it's a lot easier to use the stock locations on the back. I ran a front bar like this wtih no problems. I milled a slot in the pipe and it had two bolts for a pinch clamp, which looked similar to a toe-rod adjuster you see on many trucks. The end was capped and a u-bracket welded to it to hold the heim. When tightened it seemed as stiff as the bar, never loosened, and allowed me to have a longer or shorter bar for very little $$$$ outlay. Make the lower mount double shear and weld it on if you can. That will be stiffer than a bolt-on mount. And as you have mentioned out some spacers on the rod ends to allow for a little more room. Cary -
Looking good Jon. About the only thing I would have done differently is use tubing where you used the flat pieces with bolts. Either should work fine. I've used the long mount on the control arms to keep the heims lined up. It worked and I didn't have any problems with it so I think it is a good solution. Have you looked at possibley hooking directly to the strut housing? Another low cost option is to use a mount similar to what you did for hooking the heims to make the sway bar adjustable. Simply cut off the forged or welded ends and make a split clamp you can loosen to slide back and forth for adjustment. As you mentioned water pipe works well for this. Keep posting pics and keeping the rest of us motivated Cary -
For a beginning autoxer the best thing to do is to walk the course with someone experienced and in a similar car/class if possible. Most of the time you'll be welcomed and the person will share information. Watch and ask questions about what line they would drive and ask why. Generally in a slow area you need to minimize the distance driven even if that means you do some weird unintuitive things as it waill almost always be faster. When you start driving you want to work on car placement first. Getting very close the the cones and being consistent for your runs. It's much better to come into the corners going too slow and then getting on the power early. Most beginners have a tendency to try and carry in too much speed and overslow the car at the apex and blow the exit. Another thing I see all the time is someone holding steering lock for too long, which slows the car down and often upsets it for the next transition. Generally, when I walk the course I'm looking at the spacing of objects (turns, gates, etc.) to see if they increase, decrease, or stay the same. I also pay a lot of attention to the pavement, just dragging your foot every now and then can tell you if there's more or less traction in a certain area (parking lots are notorious for getting polished areas). Does the pavement stay level, rise up, or fall away? Very important. That's usually what I'm looking for. Most clubs will have someone with a lot of experience or maybe a national level competitor. They will usually be willing to ride with you and give you pointers. Take every advantage of this you can. And if they are willing ride with them. And remember, this is supposed to be fun. If it's not you're trying to hard Hope that helps, Cary
