67
This 240Z was stored in a chicken coop since 1987
JMortensen replied to LS1240Z's topic in 6 Cylinder Z Forums
It's your damn car, do whatever you want to it. These cars aren't worth enough to justify getting a stick up your butt about modifying one. If anything you'd be driving the price up. The only car that I wouldn't modify would be a car that ALREADY has it's own history, like taking the Bob Sharp car and putting a 350 in it, or doing an RB swap in the #46, and even there, if it's your car it's still up to you... -
	I don't know about that. I've been running it for ~8 years and have no complaints about the lockup on decel. Might explain my rear toe-in preference though... I can tell you that the R200s have springs and the R180s don't. I don't know if the R180s are 2 way also, I would imagine they are, and that 4ag link seems to say that they are, along with R160s, TuRDs, pretty much anything made by Fuji. Lots of racers running around in Jap cars with Fuji LSDs... Here's the quote from the 4ag site:
	I was thinking that too in your case. In my case I could flip them around since I only have plates and no disks, but the more I think about it the more I think I don't want to. It would give more preload and more breakaway, but wouldn't increase the overall lockup, so it'd probably just make the car understeer worse and not have any benefit whatsoever. One idea I did have is I could get 2 friction disks and install one on each side and remove a spring plate from each side, that way I would have 2 plates, 2 disks, and the one spring all working as friction surfaces. That should decrease my preload and increase the total lockup. Still not wanting to spend $60 for 2 disks though. Seems like a waste. Wonder if anyone has some old ones laying around...
	Wow, that is weird. I honestly don't know what to think about yours or mine. They just don't follow the parts list from Nissan in either case. Thanks for the info Mat, and just for the record my clutch stacks measure 20.1mm thick total including the big fat washers. Another question for you Mat: on yours were the springs facing the same direction so that they got stacked like plates, or were they facing opposite so that they increased the preload? Mine were facing the same direction, so that when I got the screws out and undid the bolts, the two halves only separated by ~1/8" or ~3/16. I'm sure if I put them in opposing each other the case halves would be ~1/2" apart. I've seen ribbed clutches and wavy metal clutches in domestic LSDs, but this is the first Nissan unit I've had apart, so I was hoping to follow right along with the info that Nissan Comp sent me. Unfortunately nothing seems to be going to plan. I'd really rather see 8 clutches at work in the diff than 6, but I am thinking that the ribbed clutches are probably intended to be more aggressive than smooth clutches, which might explain why there are fewer. Probably one of those "use fewer and put a big spacer in to save money" things. Mine came out of an '87 300ZX Turbo and I got it from a jy, so I really don't have any history on mine, but it does have the numbers C4D4 stamped on the carrier itself. I'm not sure that any of this really matters so much. I wanted to shim it up a little tighter, nothing I've found would prevent me from continuing on with my plan. Would be nice if Nissan knew what was in these things though...
	Well I've been on this forum for awhile, and so far I've seen the most votes for Mike Kelly or John Coffey, and Tim240z kinda has a Nader-esque spoiler role. I think I lean a little more towards Coffey (6 cylinder AND faster).
	OK, finally got into the diff, and I have some unexpected stuff going on. The clutch parts don't fit the description of EITHER the 45 lb build or the 75 lb build. The number of clutches doesn't match either the 45 lb or the 75. The type of clutches doesn't match. The thickness of the clutch stacks doesn't match. Weird. So here's what I've got: Here is the entire clutch stack from one side gear Here is the drive clutch or the clutch disk in Nissan terms. Gets driven by the side gear. As you can see, only ONE per side... surprising. There are 2 of these driven clutches or clutch plates per side There are 2 of these spring plates per side And there is and "end plate" or an end washer that is over 3mm thick per side. Here's a picture of the LSD crosspin and case shape. It would appear that the Nissan LSD is a 2 way LSD. Compare the photo to this: http://www.club4ag.com/faq%20and%20tech_pages/limited_slips_differential_101.htm If you run a couple bolts through the carrier you can relieve the preload on the little phillips machine screws that hold it together. Once that is done it still takes an impact driver to remove the screws. I figured out that if you can get an extension on it, an impact GUN works a hell of a lot better than an impact driver for getting the little screws out. Everything looks peachy inside, no chipped teeth or worn gears or anything. The clutches don't look very worn either, surprisingly. So my plan is to lube and reassemble and test the breakaway and see where it is at now and shim if necessary. I don't think that the shim will hold up if I install it all the way against the side gear. I don't want to install it between the drive and driven clutches either. I could install it between the end washer and the spring plates, but I think it would wear out really fast. I'm thinking I'll put the shims between the case and the thick end washer. It will have the same effect and should be safer there. I can tell from the wear on the end washers that they did not move previously. Anyone have a reason not to do what I'm planning on doing? Thanks, that was a long haul. Jon
	This is the crux of my problem with politics in America. It's always billed as "help the homeless" or "every American DESERVES medical insurance" yadda yadda yadda. The fact of the matter is were the government a business it would have been out of business a long time ago. The country needs to act like a corporation and file bankruptcy for the failing arms of its business and return those things to the private sector. I think in a previous political discussion someone had mentioned that the govt spends $12000 per child on education in CA, and CA ranks 37th overall in the nation. Not very good. Private school costs (at least in this example) $7000, so why not remove the government from the equation and remove the extra $5000 tax burden while providing a school that is clean, maintained, has good supplies and provides a better education. That's just one example. Farm subsidies is another one. "It'll be the death of the small farm" is the battle cry here. SO WHAT. If we don't NEED them anymore for food production, then why should everyone pay higher taxes so that JimBob can work the same land that his great great grand-daddy did 150 years ago? It's a romantic notion, but how much should we pay for romance? These guys are buggywhip makers, they are the blacksmiths, they are the wheelwrights of our time. Like those other honorable professions, they just aren't needed anymore, and like those other professionals, they can find other jobs.
	Wow, how original. Sounds just like the completely full o' crap Bowling for Columbine. After I learned of all the "stretched truths" in that movie I felt violated. What's next? Is he going to make everyone afraid of cars by showing footage from horrible accidents. Oh, I think Nader already covered that one. People with black lung from tobacco. Hmm... that's been done too. Seems like scare tactics are quite popular (and effective) these days... I've said it before and I'll say it again, I don't see how anyone could consider taking over a country and occupying it for a year with 900 deaths a "failed military policy" or a "quagmire". This has been and continues to be the biggest ass whooping in human history. Has it been perfect? No. Were there mistakes? Sure. But it is still a royal ass whoopin. Here's something that you don't see on the news very often. According to http://www.iraqbodycount.com (seemingly very anti-war site) there have been approx 13,000 civilian deaths as a result of military intervention in Iraq since the war started. Saddam officially took power of Iraq on July 16, 1979. From the time he took power to the time we deposed him, he had killed approximately 300,000 people. That's in 25 years or 300 months. Do some simple division, that's 1,000 PEOPLE A MONTH!!! WITHOUT A WAR AT ALL! Also for comparison's sake in Desert Storm we lost 378 men in combat casualties, and the war spanned a month and 9 days. So that's an average of about 10 men a day, which in the case of the Iraqi Freedom would equate to about 4900 American combat casualties. Is this giving any perspective??? We are KICKING ASS over there. No two ways about it. I just don't buy the argument that we shouldn't have gone in, or we didn't have reason to go in, or we are "losing" or are "not winning". We are kicking ass by any military measurement of success, we are clearly NOT victimizing the citizenry of Iraq or exposing them to a situation worse than they lived under before. Regardless of WMDs Saddam didn't keep his end of the CEASE FIRE agreement at the end of the first Gulf War.
	Wasn't it Clinton who received a bunch of Chinese $$$ in his campaign in his last election? I thought that was more of a Democrat thing. Love these two! Some more (cause I live for this stuff): Democrats: You have to believe that outsourcing of jobs is killing the economy, point out that the TELEMARKETING for the Republicans is done from India, then when our economy rebounds, complain that the people getting jobs still aren't getting the good jobs they used to have--like...telemarketing. You have to believe that the only way to stop North Korea from getting nukes is to GIVE THEM A NUCLEAR REACTOR. You must believe in the power of words like God, Christ and pray to destroy the free will of our youth, but insist on the benevolence of words like bitch, ho, and gangsta and must fight the good fight to protect these constitutionally protected words for our childrens' sake. Republicans: You have to believe in the fight against abortion and then argue that an 8 year old should be charged as an adult to get the death penalty, and then argue that a 90 year old with cancer shouldn't have the right to euthanasia. You must believe that using fetuses for stem cell research is against God's will, clearly throwing them in the trash is favorable to God. You must believe that in order to protect our freedom the government needs to know EVERYTHING about EVERYONE.
	That reminds me of a challenge I made back in the early 90's. I had an funny open challenge to people in my school to race anyone with a slammed mini truck. We would race on Pearblossom Hwy outside of Palmdale to Victorville. Anyone who knows the road will get the humor.
	IMO, and it's just MO, drifting is about as entertaining as synchronized swimming. You know there's something sexy going on, but for some reason it's still not worth watching.
Lowering macpherson struts..
JMortensen replied to a topic in Brakes, Wheels, Suspension and Chassis
Check my new sig!!! -
	I actually watched a TV show on drifting night before last. I couldn't tell you who everyone was or how old the show was, but they were focusing on Rhys Millen trying to get his new GTO setup correctly if that helps. They were using an oval/road course. On the oval the cars were trying to get as close to the wall as possible while making the turn. That is NOT the racing line. Then there was a left/right chicane, and the idea was to get as close to the retaining wall for the right hander as possible, basically sliding sideways right at the wall, then catching and missing the wall by inches. Again, WRONG line for racing. Big time. Like a ultra hyper early apex.
	A bigger wheel is good to a point. When you exceed the "good" size, then you start raising the car with the wheel diameter and running out of suspension trying to get the body of the car low enough for the wheels to look right. Unless major $$$ is spent on ultra light wheels you'll also get slower acceleration and deceleration, and potentially worse handling due to increased unsprung and rotating weight. You also lose some of the ability to use the tire as a spring, because it becomes necessary to run really high pressures to keep the rim from getting damaged when running a 35 series tire. 20s would look fine on a car designed for 20s. A newer car with a high waistline might be tall enough in the body so that you could fit a 20 on there and not have the ground clearance of a 4x4. Unfortunately despite the looks you still have to turn that big heavy 20. The two pics you've got there are perfect examples RCNSC. They show new cars with big wheels that aren't jacked up due to the wheel diameter. Compare those to some pics of Zs on big wheels and you'll see what I'm talking about. My feeling is that some designer came around about 10 years ago and decided that there needed to be very little gap between the tire and the fender, and that has now turned into a nearly universal design feature of all new cars. The wheels got larger, the waistlines got higher, and the style got more and more popular. Tire and wheel manufacturers pushed the trend no doubt, and just like the fart can exhaust manufacturers, they're getting rich off of the fad. My $.02, Jon
my dream car! I pick it up next week, tell me what you think
JMortensen replied to Sparky's topic in Non Tech Board
Do those guys install small brake kits or is Cadillac still putting on such small brakes that a 13" rim fits over it? -
	I'm a little late on this one as I haven't been following this thread, but I'm confused by the above statement. I would be curious to find out what exactly would be considered "ricey" Dorifto. My definition of rice was always form over function on a japanese car, and nothing says "I prefer form" more than the stretched tire look (not good for handling) with 5* of neg camber (not good for handling) on a street car that is 4" off the ground (not good for handling and have fun patching your fiberglass). Isn't drifting the ultimate form over function motorsport? You aren't trying to get there the fastest, you're trying to make the most smoke and put on the best show, get closest to the wall, drive the worst line possible, etc. If there were ever a "ricey" form of motorsports, it would seem that drifting would be it. Maybe you could argue that a hydraulics competition where they're spinning the bed of the truck around might be more form over function, but for actual driving of a vehicle it's gotta be drifting. Please understand that I'm not saying that the drivers aren't skilled, or that there are no redeeming qualities to the cars, just that they are built to make a show rather than go as fast as they possibly can. Is my definition of ricey just completely wrong?
Yep. You really don't want Zs too low. You can move the front control arm pivots up to counteract the roll center problem and/or use bumpsteer spacers, and you can section the struts so that you don't lose as much travel by lowering the car. Also by installing camber plates you get rid of the tall rubber insulators that are on top of the springs, which lowers the car a bunch with no ill effects other than a harsher ride. It is possible to lower a Z a significant amount using a combination of these things without having any negative effects. Without any of these things, if you lower the car more than about 2" you're asking for trouble. Here's some links to get you started on the suspension stuff: http://www.betamotorsports.com http://www.modern-motorsports.com http://www.arizonazcar.com http://www.motorsportauto.com Use the search function. If you have a question about bumpsteer or camber or caster, whatever, it's probably been dealt with before. Happy searching! Jon -
What do you think of these Ebay rotors?
JMortensen replied to zguy95135's topic in Brakes, Wheels, Suspension and Chassis
They have the same picture for all of their rotors if you look at the bottom of the auction. You can slot solid rotors or drill them or both. I can't say enough good things about the PowerStop rotors that I got from NOPI. They were crossdrilled Brembos and they went through hell on my car and never warped. Not sure what that ebay auction is for, but you may want to call NOPI and check prices, I seem to remember them being a lot cheaper than $85. -
	What are you trying to compensate for there, Science Guy???
	Top End Performance does this with Z flywheels, but I don't think they go under about 16 lbs with a stock flywheel. I think they have an exchange service for their lightened flywheels: http://www.racetep.com/flywheel.html You could get a Fidanza aluminum flywheel, I think they get down to about 11 lbs or so, and they're aluminum. Taking a cast iron flywheel down to 9 lbs is asking for trouble IMO.
	http://www.ztherapy.com
	Carrera makes strut inserts for Datsuns. You could have them made with whatever damping you want.
How can we stop HybridZ from turning into another Zcar.com ?
JMortensen replied to Forrest's topic in Site Support
I'm with Forrest. I have a couple of suggestions to possibly help cut back on useless/double posts. One big help would be to remove the Search box from the top right of the main page (and most other pages). It doesn't work, and I've seen several people say that they did search and nothing came up. Also when they do search they usually don't click the button so that the search goes for all search terms together instead of individually. If the search were defaulted to the ALL setting, I think that too would cut down on the problems. These things can only help the users here. The ones who do search will get a better answer, and the rest of us don't have to read the same post 500 times. As far as the inaccurate answers go, this is a public forum and all we can do is point out the inaccuracy, although I suppose the mods could delete bad posts if they were wrong and not challenged. Can't expect them to find everything though. -
	The ZX front disks won't work on your Z. Blueovalz worked out a way to use a 300ZX rotor with the ZX caliper, so that is an option, but they won't just bolt up. Neither will the rears, I think. You'd need a Maxima caliper bracket to bolt them up. Suspension and brakes are totally different, but the engine/trans/diff would work, and you could grab the CV axles and get an adapter from Ross and get those on.
