61
I think rags was asking if you had your manifold extrude honed, Cody. Extrude honing won't remove huge amounts of metal. You need to port the manifold with a die grinder, then extrude hone if you want the super polished effect. Jon
I agree with John C, Motul 600 or I've also used ATE Super Blue. Jon
I have taken my Arizona Z Car flywheel to 3 machinists now. Every one of them said "WOW! Do you have a scattershield?" No kidding. The same with all 3. It is THIN. The last one told me to use this dye on it. I can't remember the name of the stuff (chem-dye???), but I'm sure someone here will know what it is. Anyway, you put the dye on the metal surface, let it sit for so long, then clean it all off. Then you spray this white foam on the metal, and wherever there is a crack, the dye will wick out and you can see it. The flywheel passed the test, so I stuck it back in. I also made some small 1/4" plate guards that cover the driver's and passenger's feet. I talked to a long time drag racer, and he said that a kevlar tranny blanket would work to control the flywheel. I called Summit and they said no, so I don't know what to think. Certainly it wouldn't hurt. There has to be a good option for those of us who still use Nissan trannies. Anyone else have a good idea, or an opinion on the kevlar blanket??? Jon
I adapted the Mikuni linkage to my Cannon manifold and had a set of 3/4" velocity stacks made because the 3" stacks won't fit inside the fender on the long manifold. Jon
You can measure the current draw with a voltmeter (on milliamps) as Moby said, then pull fuses one at a time. When you pull a fuse and the draw goes away, then you know which circuit is causing the draw. Then you just figure out what is on that circuit and where the problem is. FWIW, I hate trying to track stuff like that down. NEVER A FUN JOB I'm no electrical whiz either though... Jon
Too late for that! Kitchak probably wishes he had that matress there at Sears Point a year or two ago when he DID flip it. Into a wall on the roof as I recall... Where has all the road racing gone? All I can find is NASCAR on Speed these days Jon
Need Mandrel bent stainless intercooler tubing
JMortensen replied to rags's topic in Turbo / Supercharger
I don't know if you can use stainless exhaust tubing or if you need something thicker. Closer to the bottom of the page... http://www.jcwhitney.com/catsubpic.jhtml;$sessionid$M3APMNIAABJQUQSNDV0SFE0CJUOXKIV0?CATID=3170&BQ=jcw2 Jon -
This one looks pretty close... http://www.pegasusautoracing.com/pdfs/025.pdf Jon
I want one that says Practice random acts of getting the f*&!@ off my @$$! Jon
This may be a dumb question but...
JMortensen replied to HIWAY ONE's topic in Brakes, Wheels, Suspension and Chassis
My understanding is that the top half of the spring is sprung weight, and the bottom is unsprung weight. You would want the tighter coils of a progressive spring to be at the top to increase the sprung and decrease the unsprung. This makes such a small difference that you would never know, but that's the deal. Jon -
Rear Camber Kit for '79-'83 ZX?
JMortensen replied to jhaag's topic in Brakes, Wheels, Suspension and Chassis
Why don't you just adjust it back? All you did was add adjustment. How you choose to align the car is up to you... Jon -
Isn't Magnaflow made by Dynomax??? Jon
somebody help me please!! BRAKE LINES!!
JMortensen replied to a topic in Brakes, Wheels, Suspension and Chassis
Yep, you can make whatever you want. Put that prop valve where you can reach it, make brake line sculptures that pass thru the cabin, whatever. My advice would be to buy a tubing bender as well, as it is pretty easy to kink the tube if you are trying to do a really sharp bend. The key for me was chamfering the end of the tube. I kept trying and trying,then I READ THE DIRECTIONS on the tool, and after chamfering the end, I couldn't go wrong. I used a drill bit for that, BTW. Jon -
The later 280ZX style has the module bolted to the side of the dizzy, which some people dislike but I prefer. The modules are expensive to replace but I never had one go bad before I used MSD by itself, and I've got 3 spares that I picked up for next to nothing. If you don't want to use that module you can run MSD or something similar. The benefit of this distributor is the trigger wheel has 6 prongs, and the stator has 6 prongs. All 6 have to line up for a spark to occur, should theortetically be more accurate than the 280Z unit. If you get one from a junkyard here's a link to a page that discusses checking bushings and replacing if necessary. This helped me out a lot and JD was very cool to me, so I keep posting the link on this forum from time to time. http://www.physics.ohio-state.edu/~jrdemers/280ZX/distributor/distributor.html Jon
The Motorsport kit doesn't contain bushings. It is just a set of slotted washers and a set of eccentric washers. It would be a very good idea to do both at the same time, since you'll already have the semi-trailing arms off the car. The kit is only $40 + $40 if you don't already have the hole saw. I still don't understand how the washers attach to the subframe, but if it works it would enable you to fix the camber and toe problem. I say go for both and let us know how you like the kit. Worse case scenario the kit sucks and you return it to MSA. Still no one knows if it works for 510s??? Bummer... Jon -
Cody - What you've got pictured is for a 300ZX front upper control arm (I think) and it just lengthens and shortens the upper control arm to control camber. The slot is where the bushing at the front of the control arm attaches to the subframe. You can lift the inner pivot for camber and use the eccentric they provide for the rear to control toe. Changing toe changes camber slightly, so you have to keep adjusting one, then the other, then the other, until it is right. No prob Afshin, I've stuck my foot in my mouth a few times on this board too. Jon -
Anyone else want to weigh in? I don't want to be disrespectful but I am convinced that I'm right. One guy I know runs old Camaro shocks in the rear of his 510. I've worked on 510s, and pulled parts from a 280ZX, but never actually done an alignment on either. Done lots of 911 alignments... Also, I have a friend who is slotting his 510 crossmember in the next week or two. Anyone know if this kit works for the 510? Jon -
I think I hear a ticking sound???
JMortensen replied to 80LS1T's topic in Gen I & II Chevy V8 Tech Board
Go get a mechanics stethoscope (sp?). Then you can place the probe around the block and head and maybe figure it out. Alternatively get a broom handle and put that up to your ear to listen. Jon -
How about a light flywheel? Stock turbo flywheel is what 25 lbs??? You can have a stock one turned down to ~15, but that always seemed like a lot for a cast iron flywheel. Don't know if there is an aftermarket available for turbo. Check with the guy on Ebay who sells Fidanza. He could tell you if they are available. Centerforce aluminum flywheels are not that light if I recall correctly... Jon
Boring an L24 that far would leave very little cylinder wall. Get an F54 "turbo" block and do the stroker buildup. It has a brace in the water jacket about 1/2 way up the cylinder wall to prevent the cylinders expanding under pressure. I haven't heard anyone talk about this here, but I know of a guy who built a stroker out of a 280Z block (not braced) and he got about 5K miles before it started smoking really badly. Turns out the high compression and thin cyl wall actually warped the cylinders so badly that he had to replace the block. I think he had actually damaged the pistons by the time he got to fixing it. Jon
I was doing an alignment on a 911 and I had made my own adjuster, which was about a 1 1/2 inch long section of 10mm allen that I had cut off of an allen wrench. The adjusters have a lot of friction, so I had a 10mm on the adjuster, and a 12mm on the 10mm, double wrenched. I kept adjusting, and was looking at the alignment machine computer screen from under the car. I turned to look back at the adjuster just as the 10mm slipped off my allen tool. The 10mm flung off the adjuster and the open end hit me right on the bridge of the nose, hard enough to break skin and cause a huge lump. Bled pretty good too from 2 nicely spaced spots on either side. I saw stars for a few. My boss thought it was pretty funny, said it looked like I had put my sunglasses on too fast. Jon
If you were messing with the clutch slave (especially if you were working from the top of the car rather than underneath), did you possibly disconnect the fusible link that goes to the starter? I've bumped mine and disconnected it accidentally because the connector was old and loose. Jon
One more thing, I am 99.99999% sure you need an N/A distributor. I've bought a couple from the junkyard now for ~$50 with the module. You can use the stock module or run MSD. Jon
Putting the E31 on a block with dished pistons yields an 8.56:1 compression ratio, and makes the quench area almost nil. Not exactly high performance oriented. Flat tops make about 10.2:1. Bore .40 over and you get 10.5:1 approximately. This is with a standard thickness head gasket. If you use a 2mm head gasket, your quench area will also be useless, because the pistons and head need to be within .045 or so to make effective quench, but your compression drops to 9.63:1. All of these compression ratios were figured using the Nissan L6 Engine Builder program which I got from an internet site. I tried the URL they list, and it is no longer there, but its a useful program if you can find it. I can't remember which other Z site I saw it on recently. FWIW, I have a F54 flat top block and E31 with 44 Mikunis, and I have had problems running pump gas. I had to run very little advance with 92 octane, and that is not good because it puts a lot of heat into the exhaust manifold and exhaust valves, and the motor made no power and wouldn't rev. I have figured out that I need about 96 octane to stop pinging, and so I've been cutting my fuel with Tolulene, 5 gallons gas and 1 gallon Tolulene, or lately been running 1/2 92 octane, 1/2 100 octane leaded AVgas, which is very illegal on the street. Tolulene is about $10/gal from the paint supply store, and is 114 octane. It is a very strong solvent, and it is already in the gas you get from the pump, and is also usually the main ingredient in most octane boosters (which are a serious ripoff BTW). From what I've read, you can run up to 30% tolulene (aka toluol) with no ill effects. I've had no problems so far. My first motor was a dished L28 block bored .020 over and supposedly had dished pistons that were only 1/2 as deep as the standard dish. Since I had that motor built I found that the machinist who ordered the pistons was a complete hack and totally screwed me on the buildup, so I now think that they were your usual dished pistons and I was running 8.5 compression. It was a good motor, and I could run 87 in it all day long. With 96 octane, flat tops, and the timing appropriately advanced the car is pretty damn fast, much more so than the old motor. Jon
I think this kit allows you to move the pivots on the trailing arm, allowing Porsche style adjustment of toe and camber. 510 guys slot the crossmember all the time, and this kit looks like it does the same thing. I am also guessing, but I feel pretty confident when looking at the parts in the MSA catalog that I'm right. Moving the top of the shock would have no effect on camber in this type of suspension, because it uses shocks and not struts, and they are just dampers, not locaters for the suspension. You have to move the pivots on the trailing arm to change camber and toe. Jon
