Mike kZ
Super Moderators
Everything posted by Mike kZ
  1. The Red Green show is great!! Love the power window for his van!
  2. Oh man, that's scary! Time to carry a bigger gun!
  3. You're welcome! If anyone needs either the 240z or 280z white face for all your gauges in MPH, just PM me with which set you need, and an email to send it too.
  4. I would go with the flange tool. Are you going to replace the whole quarter panel, or splice in part of one? You can use the tool to punch holes along the edge for the whole panel, or flange to splice one on.
  5. You need to search a little: http://forums.hybridz.org/showthread.php?t=127605
  6. That will look great! Nice job!!
  7. Most napa, and car quest auto parts stores can make up or order you a custom made cable. Also: http://www.speedometer.org http://www.speedometersolutions.com/speedometer_cable.htm http://www.speedometerplus.com/quote_new.htm These are just some I found.
  8. Very nice! Hope you enjoy it...but of coarse!
  9. I just bought one of these: http://cgi.ebay.com/ebaymotors/14-LED-Car-Rear-Brake-Stop-12V-Warning-Light-Lamp-Red_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem3a50f74bb2QQitemZ250466487218QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories They come in different lengths, and just stick to the back window with extremely sticky tape. They are shipped from Hong Kong. I got mine in about 5 days.
  10. Are you sure the distributor is stabbed into the right position? A popping noise could be the distributor being off, or maybe the timing.
  11. I have seen sparks that look weak, but the engine runs fine. Give it try and see what happens.
  12. Mike kZ
    Nullbound's 510
    Ernie's Cookout
  13. Based out of Atlanta? Are you working here?
  14. Do you have a Duraspark distributor? That article says you need one. The voltage dropping while cranking is normal. Does the engine block have a good ground to the frame or battery?
  15. It looks like something is missing. I would either add louvers, or maybe cover part of the window with sheet metel to make the window the same shape and size of an early Z.
  16. Did you by-pass the ballast resistor? You need 12 volts at the + side of the coil, with key on, and when cranking.
  17. I would make a template of what you want first to see if you like it before removing the window.
  18. Here is a pic I saw one of these driving down 985 once ( north of Atlanta )
