I think I am past the mechanical issues now. Took it out for a spin, and it needs some tuning work for sure.
It does idle now, timing on 20 BTDC, cam dialed in according to the card, but still very low vacuum. I did a warm dry compression test and it's quite low but even. I got 85-90 across all cylinders where typically I get about 110-115 psi on a stock L28ET at this elevation. I attribute the low compression to the camshaft, I suspect it is not well suited to the low compression turbo engine although it has next to no overlap at 0.050" valve lift.
It hesitates and misfires under light load. Of course my plugs are completely sooty, maybe I'm starting to foul them. I posted my configuration and datalog on the MS3 forums --
http://msextra.com/forums/viewtopic.php?f=131&t=46951
I'd appreciate any insights, I'm still on a huge learning curve with this.
