Mayolives
    6
Everything posted by Mayolives
  1. I am not a cage designer. RTR Motorsports designed and installed my cage and did not add the long bars from the top of the hoop to the rear of the body like you have shown in the pictures. My concern for you would be what could happen if you car was impacted from the rear end and those long bars would push the cage forward and into the driver. Perhaps you should redesign with a "crush zone" at the rear. There are many more talented cage designers here at Hybrid that could chime in and offer advice if you should desire more input on your design.
  2. " We all know what kind of members are on that site!" The "ricers" that you refer to who hang at the "other" sites and annoy you are the next generation of gear of heads. Let's cut them some slack, and when possible, lend a hand and offer some advice. Your perch on the "high horse" is precarious at best!
  3. I purchasd the system several months ago but we are still in the build stage. Hopefully it will come alive for tuning before the end of this year. I'll keep you posted.
  4. My 82 ZXT is sooooo quiet, except for the noise from air coming through the "track less" windows. The only solution, IMHO, would be to replace the rubber seals but they are super expensive.
  5. There is another clutch bleeder located under the hood near the power steering/hycis (spelling??) pump on the passenger side. It must be bleed. There is a pedal adjustment under the dash that usually must be adjusted when a clutch has been replaced. Check out TwinTurbo.net. You will find lots of good info there for the Z32.
  6. I installed Cusco strut bars on my 82 ZXT. The quality and fitment was excellent. The front fit without issues. Some trimming, of the rear interior panels where the original cover for the struts were located, was needed and these small covers can no longer be used without modifications. Cusco's center adjustment was also very solid and well made. Good luck with your selection.
  7. I will agree with Gollum. If the car is mechanically sound and the body is as good as you have indicated, 2k is a reasonable price. Have you looked closely at the underside of the car and inspected it for rust? Finding a decent first generation body at a fare price is becoming harder by the day. Good luck with your search.
  8. John, I hope to be on route from Atlanta to Myrtle Bch. next Saturday morning and will stop at Kershaw to see that white monster fly....mayolives
  9. JTI...............I almost agree with you except that the suspension should be for two months.
  10. I purchased this setup from Dave but have not completed the build/install yet. I will say that all the parts are really fine. If quality and goods looks will stop my track car, this brake kit is worth all the tea in China.
  11. I really got a big Ha Ha from that. What a trip....But should I be laughing??? I'm not sure.
  12. Thanks for the suggestion but If I had just paid attention to the FSM and removed the "o" ring, I would not have had to ask for help. The older I get and the longer I work on stuff, the "stupider" I get.
  13. The strut is not bent. I moves freely in and out but will not come all the way out of the outer tube. I stated that it would only come out about 5 " but it really moves about 10".
  14. I need some advice. I'm installing Eibach springs and Tokico HP struts on my 82 zxt. The rears were a piece of cake but now I attempting to install the fronts. I have removed the complete assembly from the car, removed the spring, insulator, dust seal etc, and also removed the wheel hub to make things easier to handle. Perhaps brain death has set in because I have read and re-read the FSM but I can't figure out how to remove the strut from the outer tube.(The one that contains the oil.) I have removed the gland nut and the strut will only pull out about 5 inches or so but will not come out of the tube. What am I missing? What do I need to do? Thanks for your advice, I'm stumped. mayolives
  15. My buddy has shaved the molding on his 240 and at really look "clean". IMHO, the function of this molding was to prevent water from entering into the car when it was in motion, with the window down. Water does blow into his car now that the strip has been removed but only with the window down. Not a big deal, but you ask.
  16. Yes you are correct, olives don't grow in Myrtle Beach, but my father's name was Mayo and Mayo lives within me, thus my screen name; mayolives.
  17. I contacted Koni today and was told that they do not offer springs for the ZX. Can anyone tell me if Koni ever made springs for the ZX? The Koni rep could not answer this question. Thanks for your input, mayolives.
  18. Great..........We all should get one!
  19. I purchased a BHJ damper, trigger wheel and mount for the sensor from Rebello Racing. Are parts are really nice.
  20. ........."Good stuff! That boggled my mind faster than a Grumpyvette post!" Yes Grumpyvette, sometimes your posts are a bit mind boggling to us neophytes, but after reading them several times, I can usually glean a few tidbits of knowledge that is priceless. Please don't give up on those of us on the lower rungs of zdom. Thank you!.....mayolives
  21. Yes, it is an easy fix. We cut a portion out of my 78 and replaced it with a "flatter" one. You could take a hammer to it, if you can live with the results.
  22. Is there a member here that has an active way to check these two VIN #s for me? Thanks for your help, mayolives. (mayolives@aol.com) JN1CZ04S3CX628972 JN1HZ04S2DX566441
  23. Dave at Arizona Z Car has said that he intends to offer a custom, billet, cnc machined, aluminum brace that would allow 1st generation z owners to use the finned, LSD differential cover with larger oil capacity. I have communicated with several members here in the past that have expressed an interest in this brace. Perhaps Dave would be more inclined to start production on this piece if he had some idea of our interest in buying it. If you are interested in having one, please respond to this post and email Dave. His address is dave@arizonazcar.com
