loy
Everything posted by loy
  1. I think they said it dynoed around 580ish? Correct me if I'm wrong
  2. Could use some oracal 8300 film. They come in light and dark smoke.
  3. There are blitz knock offs. I've only seen the older SS and DD models. I have not seen a VD yet. Yours looks pretty good, most likely authentic.
  4. I bought a kit back in the day, Precision I believe. Not too sure on what Black dragon uses. The door seals and hatch seals aren't the greatest but everything else fit pretty good. I've replaced the doors with kia sportage ones. I've still get a different hatch one.
  5. These appear to be made by Vildini Motorsports. They are known for their Sr240z.
  6. Most PDRs will try to "massage" it out. If doing body work, you can hammer and dolly it or stud welder and slide hammer.
  7. One bolt up top and one on the bottom I believe.
  8. Post hires pics of the board.
  9. I looked on ebay and found universal kits, in the size I needed, with a few 90,45,30,0 degree bends. Also might need different couplers. Yes, some cutting was required but turned out pretty good.
  10. Worst case is would be you need to get a different collar length to fit the pressure plate. I do see now that centerforce does have a seperate bearing for 70-74(probably compensates for the height difference), but it really depends on the collar length you have.
  11. It's more so about different collars and pressure plates then the bearing itself. The collars are interchangable.
  12. Could try advance auto parts. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Brake-Master-Cylinder-Cardone_5804256-P_230_R%7CGRPBRHYAMS_727899857___
  13. So did this happen out of the blue or did it always do this? Could be the ka tps as the L tps is a throttle position switch not a sensor. Also if the harness is a 81 with a resistor pack and you're using an 82-83 ecu with resistors built in, it could cause problems.
  14. Does the flap in the Afm move freely assuming you still have stock electronics. Don't know how far you are on the z31 ecu swap.
  15. Seen quite a few, all had low quality foam and cheap construction (rear portion of the seats bend easily ).
  16. http://atlanticz.ca/zclub/techtips/wiringdiagrams/75_280z_wiring.pdf
  17. Is it possible to add gas to it? Sounds like it can added on.
  18. http://forums.hybridz.org/index.php/topic/93740-official-order-list-for-hybridz-projector-headlights/page__p__883678__hl__projector__fromsearch__1#entry883678
  19. Another idea could be close off the upper triangular portion, than have the doors open up like a mouth. The upper portion could be gas shock supported and open upwards and the lower portion could be "rampish" when lowered.
