loy
Everything posted by loy
  1. So any update on your situation?
  2. When I did my L28et swap earlier this year, I also had the problem of no spark. It turned out that I had wired an incorrect switched power, "acc" instead of an "ign" , wire to the ign wire on the efi relay. Hope it'll help. Which wiring did you follow? My ecu is sitting on my floor as well.
  3. http://carscoop.blogspot.com/2008/11/insider-toyota-to-bring-subaru-co.html
  4. Most likly the problem is that the battery is dead. Try jumping it..
  5. Is it carbed? What octane of gas are you using? What temp is your engine during shut off?
  6. When I swapped the l28et into my 260z, I had the problem of no spark, the problem was due to powering the efi relay with an acc power instead of "on" power. If you wire the relay with an acc power it will cut power while cranking. As for the injectors, did you pull the dropping resistor with the harness? The dropping resistor are in series with your injectors, without them the injectors won't fire.
  7. Check out the right side of C14 on the diagram, there is a + showing how to install the cap.
  8. Resistors are non polar(can be installed either way). What board version do you have?
  9. Here is a link to a dipole one http://cgi.ebay.com/ebaymotors/MARINE-AM-FM-ANTENNA-Waterproof-Dipole-Hideaway-45-inch_W0QQitemZ330259236466QQihZ014QQcategoryZ26451QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  10. I've seen a couple of antennas for this purpose. One is a wire dipole antenna. The other is a power amplified one that could be found in any part store.
  11. Only in Australia unfortunately...
  12. This thread might help. http://forums.hybridz.org/showthread.php?p=695787
  13. We're talking about the brake mc correct? The clutch mc is just a few bolts, line and the pin holding it to the pedal.
  14. Just wondering is the 2j usdm or jdm?
  15. Did you figure it out yet? It should look somthing like this when you bolt the hub spacer and rotor.
  16. Projectors are recommended. You can, but it is not recommended due to producing alot of unwanted glare.
  17. EvilC, in the picture of your parts, is that just the lense or the whole projector? Just a heads up, the last time I tried to retrofit into some cheap 7" ebay housing, the glass doesn't come off easily and cracks, it could have just been me.
  18. I'd check out the replicas in person before buying... the padding and feel of a replica, not from this particular vendor, was really bad compared to the real thing.
  19. You could also try the cheaper dc2 recaros they are very similar.
  20. You could try playing around with setting up resistors in parallel, just gotta figure out the correct one with the formula. I can't remember if the running lights stay on when the brake lights are applied.
  21. http://www.boostlogic.com/parts/supra/info_supra_TH400.html http://www.manictechracing.com/1jthadandflk.html
  22. Yeah theres not much in our area on craigs...
  23. I seen similar style of mirrors on ebay as "M3 style" mirrors.
  24. There are some headlight housings made for hid, like the is300 headlights, which has no projector.
