loy
Everything posted by loy
  1. Sounds like if you get it running pretty good, this would be a pretty decent base map for users who which from stock ecu to megasquirt with little to no mods.
  2. Did you get the PWM values from here? http://forums.hybridz.org/index.php/topic/55910-injector-opening-times-spread-sheet/
  3. Put in google docs and put a link.
  4. Also figure out what hubs you are using 240z ones or the 280z ones different thickness is needed.
  5. Yeah, best way to use Google to search the site is use "site:Hybridz.org search term" .
  6. I'm back. Good to hear that it works. There are pictures of what the transmissions look like, but the bearing should be the same.
  7. This thread might help you. http://forums.hybridz.org/index.php/topic/100100-tps-rotate-for-240sx-60mm-tb-general-info/
  8. I really like how the newer mustang gt grill fits as seen here. http://forums.hybridz.org/index.php/topic/107307-mustang-gt-grille/
  9. Did you see the part on using a 82-83 harness? http://forums.hybridz.org/index.php/topic/109476-l28et-harness-question/page__p__1023298#entry1023298
  10. I believe it's a custom one of a kind item. Should be able to find a used factory set for much cheaper.
  11. You can also use a 82-83 turbo harness you just need to splice in the resistors. What happened to the megasquirt? Going to stock efi?
  12. I'd check fuel pressure as you're boosting.
  13. Wish I could help but I'm in Seattle for the week. If you still haven't fixed it I could look at it when i get back.
  14. Is it a turbo ecu or N/A?. Vacuum is what you're in before boost. I highly doubt it will ever run perfect without the correct injectors.
  15. Running stock ecu? If yes. Were the injectors from before also not meant for the motor? The fuel pressure is really low. It runs fine throughout vacuum?
  16. I made my own it was pretty easy, not a complicated part. If you are looking for premade ones http://www.zccjdm.com/ has the carbon inspection lids and ebay has the carbon cowl. Sorry I don't know any sources for just fiberglass.
  17. A better keyword for you searchs is front turn signals.
  18. Just take some flat stock and make L shape like bracket. I bolted it to the car first then bent to where it needed to be
  19. I have done it before. Wasn't really year specific. I believe i used this one BECK/ARNLEY Part # 1580642 from rock auto.
  20. The automatic one with two connectors(external and on unit itself) will work with stock ecu.
