Everything posted by 2126
  1. Or, find or build a garage!!! I feel for you buddy!
  2. When I did my conversion (R200 into early 240), I ran into the same issue of the strap not fitting however, it was really close! What I mean is, that the strap prevented the diff from being lifted enough to install and bolt the mount in place. OH. what to do? After looking closely at the problem I discovered that if I removed the steel sleeves on the strap mounting bolts, it allowed just enough room to complete the task. I did have to use a floor jack to apply force. Now the strap is relatively tight and have had no ill side effects from doing this mod. This worked for me anyway! Probably not the best method for someone with high HP.
  3. Dave, Now thats what I call customer service!!!! Someday I may step-up to your brakes when $$$ allows it.
  4. 2126
    Oh Boy
    My guess is, the Porsche headlights have got to be the most valuable thing on the car! Yeh, you gotta hand it to the builder for at least using their imagination! Personally, its not a car I would want or drive.
  5. Ahhhhhhhhh, does it have gas in it?
  6. OK, I quess that means you drive it like a 911 style Porsche!? In easy on the apex and out hard? In any event, its got to be a monster! Pretty cool car however.
  7. 2126
    plug wires
    All I'll say is, MAGNACORE....KV85's
  8. Do ya think it might be a bit nose heavy? Man, if you could get that thing to hook-up, it would fly! Maybe a driving class taken on how to drive on ice would help!
  9. Come on now Jon, I didn't mean to get ya going on the spacer deal! I just wanted to let guys know that Precision Gear themselves told me this when I asked them the question.....just passing along some info.
  10. Since the Washtenaw Community College crew stuck it on the modified 500!
  11. Nice street tires for sure! Been running them on my 240 since their release and love'm
  12. 2126
    My 79 Spyder ZXT
    One of the best looking ZXs I've seen.....nicely done!!!
  13. 2126
    silenbcer
    The Feds should like this photo!!! You might want to check the law regarding silencers.
  14. Just a note regarding the spacers to fill the gap when installing R200 ring gear with 12mm through hole and using the 10mm bolts. Give Precision gear a call, as I did, and they will tell you they are not necessary and have customers who race off road who have no issues by not using these spacers. Basically, if you are worried about the ring gear slipping against the LSD carrier, them you have not torqued the bolts properly. Also, if by chance you fabricate spacers that happen to be a tiny bit too long, the bolts will not clap the ring gear properly and you WILL then have a problem. Don't trust my post, call Precision Gear! I've got one of their R200 LSD and it works perfectly and it cost under $500.00.
  15. First thought.....Now thats a real Ford! Second thought.......way too cool, it will never happen!!! Shoot, I'd even trade my Z for that baby!
  16. 2126
    My Z project...
    Buy yourself a good service manual and learn to use the search function. Alot better than waiting for a reply to be posted!
  17. Like I said earlier.....scientist used to think the earth was flat too!!! Probably pretty good spectulation though!
  18. IIRC, the recommended fuel pressure for the SUs is 4 to 4.5 psi. With new needles and seats in the carbs you can get away with a bit more. Anything over what you've mentioned is asking for trouble.
  19. olderthanme, If you haven't checked, you can buy new entry level race seats for about $200.00 each! I would imagine these would be less $$$ than the time and materials it will take to fab and recover customized stock seats......and with no warranty to boot! Just a thought.
  20. Thanks for the heads up Jon.......I certainly wasn't thinking of the 4 cylinder with the light flywheel!
  21. Correct me if I'm wrong here but, I believe there is a rear sump pan assembly that was used on a Bronco or some model truck....can't remember! Another option would be to fab up a custom rear sump pan and oil pick-up tube.
