stony
Super Moderators
    10
Everything posted by stony
  1. you will know in less then 10 hours hitting the road to the track now.
  2. email the pics top me and i will post them in this thread
  3. pz130.. what the heck is that? i guess if it had the rb20 in it the mounts will work. i was unaware of any other z having an rb in it other then the z31 300 zr
  4. i think the autometer electronic speedo should wire up to the r33 electronic sender on the tranny. it has two wires... the autometer speedo has 2 wires. and its calibrated by driving on the raod a certain distance. i will eventually do this but im holding off right now as its kind expensive and im toying with going to an automatic. if i do and cable type speedo will work ;>
  5. stony
    rb26 sds fuel map
    this one is manifold pressure (booste) fuel curve this one is rpm fuel curve ignition curve ignition retard (booste) curve. if you save the pics on your computer and open them they will be a little bigger and clearer
  6. stony
    rb26 sds fuel map
    if you want to see it i have it in an excel doc with graphs now. maybe some can post it somewhere
  7. yes it is. i would like to be able to look at it in an excel sheet while on the dyno to see where changes can be made or just compare maps with motec users ect ect
  8. i was thinking that but im a dumbass when it comes to stuff like that.... care to setup a couple tables for me? to see a graph of fuel curves and ignition curves ect ect and maybe somehow overlay them all. kinda like a dyno graph would
  9. it dosnt fit unless it has a custom bell housing and i know of nowhere that sells one.
  10. stony
    map
    email me if you want the sds map fro a rb26 with 680 cc injectors
  11. hey does anyone know how to input sds setting into a graph so it reads like a motec printout?
  12. anyone ever price one yet? curious how much a crate motor is ;>
  13. Yes ladies and gentlemen i finally stopped being a cheap ass and bought a HKS GD MAX twin plate clutch. This bad boy will not slip... its sequential so there is not a on off engagement. when fully engaged it will hold 700+ FT lBS or torque anyways its installed and working. so i never had a slave or master cylinder problem it was the fact the clutch came apart and jammed peices in the Pressure plate
  14. Yes.... call me when you have the motor ;> J/K
  15. im over it he is too afraid to even come back online what a puss :>
  16. aircraft stresses and car stresses are completly different. the thickness of those mounts will make them in detructable in a car. give me a break... there is now way in hell even a hi HP rb will break those
  17. what do you need... where was Okinawa motorsports at? the name sounds familiar. i can get stuff from a guy in japan (Motorworx)
