stony
Super Moderators
    7
Everything posted by stony
  1. sleeperz is correct they are not for sale yet ;> a couple of trips to the track will tell if i break another axle then a nine inch is in line. If so i will sell the entire rear suspension ;>
  2. oh yea i forgot to say the only reason i did this was because i got the entire suspension from a z31 turbo (LSD MODEL) for 200 bucks. The axles are shortened chomoly versions of the stock z31 axle. So the next thing to break will be the diff, tranny, cv joint or driveshaft... any bets on what it will be
  3. oh yea i just noticed this is probably in the wrong section anyone feel like moving it to the drivetrain section And yes that is a wrench taped to the brake line its holding the old soon to be removed rubber line
  4. ok here are pics of teh axles and z31 brakes on the rear. i need a small metal line to connect the z32 steel braided lines to teh calipers but its pretty much done. All i have to do now is take everything apart make it pretty and locktight and cotter pin everything.
  5. last tie on the dyno it was 392 to teh wheels at 15 psi. bfg drag radials 275 50 15 on a r-200 lsd 3.90 gears
  6. yes but unless you get an entire z31 suspension fro free its prabablu too costly compared to other mods.
  7. ok it has happened 3 more times. Let me clarify its not popup adds its popup windows with hybridz in the address bar. I have figured out that if i control alt delete IE it stops it but i still have to go back and close 40-70 windows????????? no one else has had this happen?
  8. stony
    Z with AWD
    get a gtr front clip and rear frame member and graft it into the z. if i were to do it i would build a tube frame and pickup all the mount points. i said it once ill say it again. if your not an engineer dont do it.
  9. i hear ya. im hoping to be back in january 2005. Im also hoping my car will be a proven low 10sec car ;>
  10. actually its not custom but just big flares. I have a set of the rear ones sitting in my crawl space. 200 plus shipping there yours. I bought them new and had them painted to mach my car. they didnt look right with the smaller front flares so i took them off. the front flares look like they way be customized but over all those are available in japan
  11. hey corvette, you will beat 9 out of 10 Y plates but you may be surprised by some of the J plates ;>
  12. im running 11.1 @ 127 MPH on a stock rb26 with 680cc injectors and boostin 15PSI how fast do you want to go and how much money do you want to spend? you have to ask yourself these things before you start a project
  13. i dont know either just relaying what i was told
  14. are you going to put an additional fitting for the return. I know for sure the vent is mandatory. This is what i have decided to do also. The return line wiii have air in it and having it close to the return you run the risk of the pickup sucking air, and this kinda defeats the purpose of what im doing.
  15. thats what im doing i basically used the bottem half of the z31 strut and bolted z32 calipers up to it and welded teh top half of the s30 strut tube ... had to play with tierods and rack to get everything to fit. i pickup all my parts for prettty mu ch for free. i would go with a outlaw setup if i had to do it again.
  16. for those of you that havent seen what im doing maybe i should explain better;> im swapping to a z31 shortened axle and stub shafts. im hoping they will be alot stronger and handle 450+ RWHP
  17. Has anyone else experienced the popup crash? It has happened twice where i close internet explorer with hybridz open and popup hell starts. ive gotten to 60 windows before i power down. ???
  18. well the chromoly 3m axles are on the way, my strut housings will be picked up tomorro (I HOPE) will put together over the weekend. will post pics when its done
  19. ok cool i thought there might be another type of tank for FI IF i stay on schedule should be at the track in a month.
  20. not sure if so well i guess i wont be reacing in any nhra events ;<
  21. HMMMMM i dont know why i didnt ask about this BEFORE i ordered my cell.... but can you use one outlet for a supply and one for a return on a cell that has a sump? it has 2 -8an supply lines and a -6an vent. Im pretty sure you dont want to use the vernt as a return. Please respond ASAP so i can cancel my order and figure out what i have to do
