Cable
Everything posted by Cable
  1. Digging up an old topic, but does it matter if the studs are suppose to be from the front or rear from a RX-7? Thanks guys!!
  2. Being Centerlines I am sure they are around $275 a wheel.
  3. Here are a few pics of my little buddy, his name is 'Shorty'. He is 4 years old now.
  4. Great looking car dude. Are you running the 245/45/16's up front too? 5" of backspacing right? Are you running coil overs? Thanks dude.
  5. I haven't decided yet. It will be the last thing to do anyway. I am have a HUGE laundry list yet to do.... Hey guys, I am buying the Draglites BTW. What lug nuts do I need? Anyone know? I'd prefer just to order them from Summit along with the rims.
  6. Okay, I am about to order my Draglites for my 280z. I am going to run a 235/60/15 rear tire. I currently running stock suspension and I am prepared to roll the fender lips as needed. Draglites from Summit in 15x8 come in either 4.5" or 5.5" backspacing. Should I buy the 5.5" BS and space them out as needed or should I just stick with the 4.5" BS and play it safe? Thanks guys!!
  7. Bought Sportmax 002's in 16x8" 0 offset and 245/50/60 tires, can't wait to install them. I am also finally getting around to upgrading the front brakes w/MM 4x4 setup and then the rear to disc later (also MM kit). I have also just bought some fuel system upgrades to feed this beast. 1/2 or -8 AN line, looks like a garden hose!! Stay tuned guys!!
  8. I have a '75 280z coupe. Its mostly stock except a few things, oh and a BBC 454 thumpin' out 600HP/550TQ under the hood. The body is mostly stock though..... http://www.cardomain.com/ride/685533/1
  9. Scary is more like it.... TH350 is doing fine, a couple of leaks though... Its a basic rebuild with a few more clutches and a Trans-Go Stage II shift-kit. I have killed a torque converter though. Now I have a ATI unit that seems to be doing well. I am not sure what you mean by my Car Domain ID, could you re-phrase the question? Thanks!!
  10. I've seen the story before, but never cared for motor plates, or the tubbed/narrowed rear. That's one of proudest things is I was able to do the swap without cutting ANYTHING and could swap out the BBC for the stock L-series in an afternoon. Still, that car brings me back to the Pro-Street era of things.
  11. I've done all my swaps myself, usually without any help at all. The exhaust and engine/heads machine work is the only thing I can't/don't do 'in-house'.
  12. Before & after pics of my Z..... Before: New pics with my MSA front air dam in place, geez it really cleaned up that front end... So, what do you guys think?
  13. Before & after pics of my Z..... Before: New pics with my MSA front air dam in place, geez it really cleaned up that front end... So, what do you guys think?
  14. New pics with my MSA front air dam in place, geez it really cleaned up that front end...
  15. I want my 'iron cross' wheels to look like your old ones: How did you polish them? Mine are still factory painted black with polished edges. I was thinking of using chemical striper to remove the paint then start with a buffing wheel on my die-grinder and some polishing compound. I guess I'll see what happens....
  16. Is this something that you are building and selling? Also, is there a way to make it work with stock lower control arms? Thanks!!
  17. True, but my 4" cowl and my lopey cam normally gives it away that my little Z anything but stock. Regardless, I think I will be going with draglites anyway.
  18. I'll see about getting those measurements, but I think they are a bit thicker than .5" inch when made from aluminum. The steel ones are prob .5" thick. Here is a pic of the aluminum one for the R200 from Arizona Z Car:
  19. I would be extremely interested in that.
