That motor isn't a 98, its a 99+. All 97-98's had perimeter bolt valve covers. It also appears to have an LS6 intake on it? (if there is no EGR port hole directly behing the throttle body on top, its an LS6) - which would make me think its a 2001-2002, unless someone swapped intakes. Another thing, the wiring is slightly different from 99 and up - You might want to make sure that speartech isn't building you a 98 harness.
Also, not that its likely a concern to you... but; the NHRA won't let you run your fuel lines in the trans tunnel. Not that you probably intend on racing it. However, I just like to air on the side of caution in the event that you have a driveshaft failure.
And ONE more thing. the walbro pumps are a pusher, not a puller style pump. You'll have better luck mounting the pump as low  or lower than the tank outlet. Might work for you, or it might cavitate and cause issues   I would also STRONGLY recommend putting in a fuel shut-off valve, so you can pull the tank, or change filters without fuel gushing everywhere. I wish i'd done it.
Looking good. You'll enjoy it..... trust me.
