I figured I would give an update on what where doing now.
First of all, I ripped the motor apart about two weeks ago. Had a leak, that turned out to be a crack on the intake port of number 4 cylinder. Also had an oil leak between one of the thirds, and turned out to be that the gasket material (which remains un-spoken of right now), started "decomposing". So I made some new gaskets out of another material (which also remains unspoken of), to try out, which I know cant de-compose. I dont want to say what the materials are just as yet, as I want to try them out to prove them.
While I had the motor apart I sent the cams off to get re-ground. Stock they came out to be about 205 degrees at .05" and 320" of lift. Yea thats it, it made pretty good power for those cams I think. We came up with about .390" and 215 deg at .050" is what where going for on the intake, and .360" and 210 deg at .050". I did not want to go to large on the ex, so I dont bleed off too much cylinder pressure, during split over lap.
I also am trying a different set of turbos now as well. I bought some new cheap turbos, actually spent about 400.00 on two new ones. They are .48 compressor housings, and 63 ex housings. THe stock T3's would not make anymore power difference from 20 psi compared to 25 psi, so the back pressure had to of been to high, and not been able to flow any more air then what 20psi would allow on the zx ex housings. SO I upgraded to bigger housings on the intake and ex. They also do have 360 degree thrust bearings also, and at 27 psi, they are still on the correct portion of the turbo map.
Anyways figured I would give everyone who is interested a update. Should get to 700+ rwhp with the new setup, as well as still be streetable.
Also, I was gonna link to the other post that I should of posted here in the first place so when someone searches (me haha) I can find all the info.
http://forums.hybridz.org/showthread.php?t=127559&highlight=dyno+twin+cam
Dyno run
Dyno chart at 17 psi and stock t3 turbos.
