assuming the check valve is before the canister? and synthtk clean out your pm's i have been trying to pm you for a few years i was thinking about using some 2.5" pipe about 8" long do you think that would be enough?
you put a urethane additive in the paint. if done right you should be able to bend it far without chipping the paint. i have seen bumpers folded in half (just about) and pop back without cracking the paint.
oh yea sorry, i have a single throttle body. i was thinking about putting the check valve as close to the intake manifold as i can so it would store some in the hose too. i dunno if that matters or not though. guess i need to wikipedia brake boosters
Hey guys, RB26 with a intake manifold. i have a 6an line tapped. can i run that stright to my booster with the oem 240z check valve? or do i need to build a vacuum canister? i have disk brakes in the rear and will be running azc 12.2 front kit at some point with the 81 280zx 15/16th master. (btw isnt this the same as the 280z master, my 280z says 15/16 on it...)
i have an aem ems s2, so far i am happy with it. i am by no means a tuner but it seems do have all the bells and whistles i could ask for. not familiar with the haltechs.
roughly 2" or so. Really the overall length of the tube is the important part because that is how the gland nut tighens down on the strut. cut it a big on the long side and just through a washer under it and your golden if you miss judge the cut, but mine were fine. pretty much follow johnc's writeup in the FAQ. you can get a cheap chopsaw at harbor freight... you get what you pay for but if you dont have a need for a good one it will still do the job.
ok, broke out the lathe on the suspension and i am glad i did, turned out great. more pics to come.
these are the lower perches that come with the ground control coilovers.... they made me laugh and reminded me of my hondas weaponR suspension...
so giving the middle finger to that i made these. hammer tight tolerances turned out perfect i must say
then i modified the top hats to fit inside the bearing like the oem perch...
got it lowered on the ground today and can push down own it my my scrawny self and one of my guys says "now thats a suspension" ahah love it..
throw a gusset on that thing, probably overkill but cant hurt im still messing with my angles, i need to learn new curse words cause nothing seems to be working.
i just did my suspension, sectioned the front struts, dude if i can do it anyone can. if you have a chopsaw there is no reason you cant. i used a big pipe cutter (like a tube cutter) and that was a pain in the ass, it wanting to walk up the pipe but i think a chopsaw would be easiser. then i used 2 pieces of 1.5" (maybe 2 but i think 1.5) angle aluminum and clamped the tube inside those and tacked it.... worked great. i do have a tig and a mig so i used thte tig to weld up up but you can grind down a mig...
im somewhat interested in upgrading my turbos too. I want to get it on the road as i have it now on the stock ones and see what happens, but i am thinking something more like the N1 spec turbos or something kinda to the small side. also questioning a small single to simplify the engine bay, but i dont know at this point. will the stock injectors feed 12psi on the stock turbos? 440cc
how many shims did you use? i have probably 3/8" or so on the drivers side. i currently am using 4.0 degrees down on the trans, 4.0 up on the diff, but still vibates like hell. (on the lift, no cv shafts, no wheels)
well i got the angles on the flanges right (equal degrees) but i have to move the diff down. i am going to have to redrill the t3 mustache bar i think, if it will work at all with the mckinney mounts. i have shimmed the bar down to the max(out of threads on the mustache mounting bolts), what a pain in the ass this has been.
my the angle is 3down and 3degrees up for the rear. but the driveshaft is pretty much level. i got a digial angle finder coming, hopefully be here friday. then i can get some consistency.
