grannyknot Posted June 19, 2020 Share Posted June 19, 2020 So when you brought the sending unit into the cab did you use its full range of swing to determine empty, 1/4 full, half full ...? When you had the programing done could you swing the float up and down and see the gauge react? Quote Link to comment Share on other sites More sharing options...
Derek Posted June 20, 2020 Share Posted June 20, 2020 1 hour ago, grannyknot said: So when you brought the sending unit into the cab did you use its full range of swing to determine empty, 1/4 full, half full ...? Yes. I did the coarse setting with the MM and then refined it with the gauge. 1 hour ago, grannyknot said: When you had the programing done could you swing the float up and down and see the gauge react? Yes. The needle moved slowly which gave me some hope. I then installed the sender and added gas at a known amount and checked the gauge to verify. It was very accurate without any other tweaking but I wanted to get it dialed in at the 3/4 mark since that is probably pretty close to the point where the tank narrows. The drive home went well and the needle was more stable than it has ever been. The real proof will be when it get's down a little past half. that is when I really noticed the massive swings. The needle would literally go from half a tank to empty. Quote Link to comment Share on other sites More sharing options...
grannyknot Posted June 20, 2020 Share Posted June 20, 2020 20 hours ago, Derek said: The needle would literally go from half a tank to empty. Oh I know all about that. This is great news, I think the Tanks Inc. MeterMatch is just the TechnovVersion unit with a different sticker on it, the price is all most identical. Quote Link to comment Share on other sites More sharing options...
Derek Posted June 20, 2020 Share Posted June 20, 2020 2 hours ago, grannyknot said: I think the Tanks Inc. MeterMatch is just the TechnovVersion unit with a different sticker on it, the price is all most identical. Yes but the owner of Technoversion drives a 240 so there is that to consider:) Went for about a 45 min drive today. Gage went down as expected and was rock steady the whole time. I do want to reiterate that I change my sender wire and installed the MM at the same time. I would do that first since old wire and connections are not a great combo for dependable ohm eadings Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted June 21, 2020 Share Posted June 21, 2020 Derek, this is great news and hoping when you drain it is within the 1/4 range as you were hoping for. Quote Link to comment Share on other sites More sharing options...
Derek Posted July 23, 2020 Share Posted July 23, 2020 So I finally had the right combination of events to where I ended up with 1/4 tank and the time to drain and measure. I used a 5 gallon gas jug and it was so close to 4 gallons that I'm calling it a winner. The needle does start to swing a bit down around 1/4 tank and I did have one scare. I was about 30 min from the shop and I was hovering around 1/4. I pulled up to a light that was on a bit of an incline and the needle bounced down to E for long enough for me to convince myself I was running out of fuel. I wasn't but without knowing for sure I threw in a few gallons. It is way better than it was before and I'll probably run it down to 1/8th and see where I'm at. As long as I can count on it to between 1/4 and 1/8th then I'm golden since that is usually as low as I run it. Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 24, 2020 Share Posted July 24, 2020 12 hours ago, Derek said: So I finally had the right combination of events to where I ended up with 1/4 tank and the time to drain and measure. I used a 5 gallon gas jug and it was so close to 4 gallons that I'm calling it a winner. The needle does start to swing a bit down around 1/4 tank and I did have one scare. I was about 30 min from the shop and I was hovering around 1/4. I pulled up to a light that was on a bit of an incline and the needle bounced down to E for long enough for me to convince myself I was running out of fuel. I wasn't but without knowing for sure I threw in a few gallons. It is way better than it was before and I'll probably run it down to 1/8th and see where I'm at. As long as I can count on it to between 1/4 and 1/8th then I'm golden since that is usually as low as I run it. Any numbers please ? Of course it probably won’t match mine , but hey- maybe it will. I’m fairly close but it still drops hard close to the quarter tank . love the GPS speedo and playing with the stop watch Quote Link to comment Share on other sites More sharing options...
Derek Posted July 24, 2020 Share Posted July 24, 2020 9 hours ago, madkaw said: Any numbers please ? Of course it probably won’t match mine , but hey- maybe it will. I’m fairly close but it still drops hard close to the quarter tank . love the GPS speedo and playing with the stop watch As in Ohm readings? No not really. Since I used the calibration feature of the MeterMatch as opposed to the pre configured method there isn't any way to know for sure. Quote Link to comment Share on other sites More sharing options...
madkaw Posted July 25, 2020 Share Posted July 25, 2020 Sorry - I forgot you said you used the meter match. I might go that route too Quote Link to comment Share on other sites More sharing options...
spoolinq Posted December 17, 2020 Share Posted December 17, 2020 Hi there, I just purchased my gauges from Steve. How did you guys wire the high beams? I have a 260z. I heard using a relay may be needed. Thoughts? Quote Link to comment Share on other sites More sharing options...
grannyknot Posted August 6, 2021 Share Posted August 6, 2021 On 7/24/2020 at 3:49 PM, Derek said: As in Ohm readings? No not really. Since I used the calibration feature of the MeterMatch as opposed to the pre configured method there isn't any way to know for sure. Only took a year to get around to it but I'm ready to install the MeterMatch to the Speedhut fuel gauge and the Datsun fuel level sender. I have a working 510 fuel sender unit on the shelf, to avoid having to drain the 240Z's gas tank, remove the sender unit and bring it into the cab to do the setup I'm wondering if I can just use the 510's sender to calibrate. To my eye they are the exact same unit with the only difference being the bend of the wire going to the float. What do you guys think? Thanks Quote Link to comment Share on other sites More sharing options...
brianZortiz Posted December 29, 2021 Share Posted December 29, 2021 (edited) . Edited December 30, 2021 by brianZortiz Quote Link to comment Share on other sites More sharing options...
Vandergriff84 Posted August 9, 2023 Share Posted August 9, 2023 (edited) Hey gang, I recently installed my Speedhut gauges and I noticed when I put my foot on the brake pedal the turn signal indicators and the back light for the odometer screen lights up. Upon further investigation I found that my turn signals and hazards don't work when the lights are one. The turn signal indicators are also constantly lit when the headlights are on. I had autometer gauges before and while I don't recall having this issue before so I can't necessarily say that this is specific to the speedhut gauges. I also recently replaced all the bulbs for LEDs. I am just curious if anyone else has had this problem before? Edited August 9, 2023 by Vandergriff84 Quote Link to comment Share on other sites More sharing options...
idiot280 Posted August 9, 2023 Share Posted August 9, 2023 2 hours ago, Vandergriff84 said: Hey gang, I recently installed my Speedhut gauges and I noticed when I put my foot on the brake pedal the turn signal indicators and the back light for the odometer screen lights up. Upon further investigation I found that my turn signals and hazards don't work when the lights are one. The turn signal indicators are also constantly lit when the headlights are on. I had autometer gauges before and while I don't recall having this issue before so I can't necessarily say that this is specific to the speedhut gauges. I also recently replaced all the bulbs for LEDs. I am just curious if anyone else has had this problem before? Start with the simplest solution and work your way through to more complicated answers. Change the bulbs back to halogen and see if it fixes it. If no, check wiring. Quote Link to comment Share on other sites More sharing options...
