Dat73z Posted August 3, 2023 Author Share Posted August 3, 2023 To get a better idea of what modifications may be required, I compared 2 spare mid/short runner manifolds I have. The vintage Mikuni which is the shortest to my knowledge may require modifying runners 3 and/or 4. The vintage FET is mid length and may have just enough rise and run to clear, but I'll need to see if it puts the surge tank into the shock tower. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 4, 2023 Author Share Posted August 4, 2023 More mockup work on the #s matching spare motor. From past measuring I know the Harada/Kameari, Nissan Comp, etc. long runner manifolds put the v2 surge tank into the s30 shock tower so those were non starters. The Mikuni short runner will definitely need to be modified to clear the PTZ manifold for runners 3&4. The FET mid runner clears all but may be right at the shock tower. Also exploring a custom CNC manifold option. This is probably super niche but maybe someone can find this useful, I know I could've used this info yrs ago Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 5, 2023 Author Share Posted August 5, 2023 More mockup work with the new turbo setup. It would be pretty sweet if I can run this FET manifold, the clearances are actually pretty good. Perhaps if I machined a bit off the DCOE flange side. The downside to this manifold is it's pretty thin walled, so porting for 50s may require welding. Either way I can already see I will need to cut and weld the inlet on the new G series like I did with the old hybrid turbo. Quote Link to comment Share on other sites More sharing options...
Zetsaz Posted August 7, 2023 Share Posted August 7, 2023 Clearance issues aside this is looking pretty sweet. You're one of the first I've seen running the newer G series turbo on an L engine, much less one with carbs. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted August 8, 2023 Share Posted August 8, 2023 Fet V1 for the win! Still waiting on mine Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 9, 2023 Author Share Posted August 9, 2023 On 8/7/2023 at 10:11 AM, Zetsaz said: Clearance issues aside this is looking pretty sweet. You're one of the first I've seen running the newer G series turbo on an L engine, much less one with carbs. Yeah I'm stoked to get this setup together! I suspect the 0.83ar will spool like the old .63 and provide a lot more. 8 hours ago, DuffyMahoney said: Fet V1 for the win! Still waiting on mine The v1 is really awesome. I wish there was a vintage option that checks all the boxes, but after some news today I may go with a custom billet cnc option. Mikuni length with proper clearance and porting for 50s. Quote Link to comment Share on other sites More sharing options...
DuffyMahoney Posted August 9, 2023 Share Posted August 9, 2023 14 hours ago, Dat73z said: Yeah I'm stoked to get this setup together! I suspect the 0.83ar will spool like the old .63 and provide a lot more. The v1 is really awesome. I wish there was a vintage option that checks all the boxes, but after some news today I may go with a custom billet cnc option. Mikuni length with proper clearance and porting for 50s. Will you keep the Mikuni step up? Quote Link to comment Share on other sites More sharing options...
rossman Posted August 9, 2023 Share Posted August 9, 2023 (edited) I'm looking forward to your feedback on the performance of the G series turbo. I am considering exact same one for my setup [edit: actually it is the G30-660 that I'm considering]. Looking at the compressor map it looks to be a great turbo for a decent flowing 3 liter L6. Edited August 11, 2023 by rossman Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted August 10, 2023 Share Posted August 10, 2023 Cool! I was looking at the G-25. It appears to have a remarkable 80% efficiency on the map I plotted on their website. I sent my protuners turbo manifold and down-pipe off to Swain along with my NA header for coating. This is for the street car, after the race car is finally running. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 10, 2023 Author Share Posted August 10, 2023 (edited) @DuffyMahoney yes the step up will be necessary to clear the turbo and manifold. I assume the HKS v2 surge tank was designed with the s130 in mind as fitting everything into the s30 poses some interesting challenges. Likely the cnc option would be between the Mik short runner and the FET mid, combining the best of both. @rossman after playing with boost adviser and staring at compressor maps for a while I narrowed it down to the g30-660 or 770. After discussing with ATP turbo I went with the g30-660, as it sounded like a good match we'll see how it goes. @AydinZ71 I looked at the g25 too but it seemed too small for the 3.2 8.5:1, perhaps it would be a good match for the l28ET. Post some pictures of the swain coating when you get it back, that sounds pretty sweet. I was considering that this time around but ATP inconel is on the table again as well. Edited August 10, 2023 by Dat73z Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted August 11, 2023 Share Posted August 11, 2023 Ah! Sorry, had not been following your build close enough 🤦🏽♂️. Ya G25 seems too small. I’d Go a size up, and it looks like max efficiency only drops by a handful of percentage points. Lead time is currently 10weeks, so il snap some pics when it comes back. Just FYI, the coating looks good initially but turns ugly pretty quickly with repeated heat cycling (just like the real stuff applied on nasa heat shields). I’m going to call them tomorrow and ask if it can be too-coated with high temp paint just to provide a consistent surface color. The Swain ends up with varying shades of yellow and light brown after moderate use. Quote Link to comment Share on other sites More sharing options...
rossman Posted August 11, 2023 Share Posted August 11, 2023 @Dat73z Aaah, you are correct!! I went back and looked at my calcs and realized that I remembered incorrectly, it's been a couple of years... It is in fact the G30-660 that I was looking at. I feel better too that ATP agreed with my independent assessment :). Quote Link to comment Share on other sites More sharing options...
Sean 83ZXT Posted August 11, 2023 Share Posted August 11, 2023 Wonder why ATP advised against the G30-770? I'm no expert, but I did a deep dive into the maps and they looked pretty good for a healthy L28ET. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 12, 2023 Author Share Posted August 12, 2023 @Sean 83ZXT for my setup, I wanted the highest response setup with a powerband between 3-7k running at 15-21psi (OER/SK carbs can do ~16psi constant and 21+psi intermittent). I had also looked at the g30-770 but the 660 won out for my goals. ATP advised that the newer aero on the G series turbine wheel will flow enough to keep backpressure in check on the large 3.2L up to 7K without choking up but the key is to mate it to the .83 A/R housing. Also noted that on the g30 the 660 comp wheel is the most boost responsive configuration that is capable of providing the right amount of airflow for those required boost levels. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted September 14, 2023 Author Share Posted September 14, 2023 Parts are still slowly trickling in. My ZCG Stoptech brake kit came in so I can hopefully finish reassembly of the new suspension and brakes. The first test print for the cnc 50 manifold came in as well. I'm really excited for this manifold project, I think it'll be the perfect high clearance dcoe manifold. Fortunately I have both a spare engine on the stand and also a blowthrough s30 to test real world clearances on 😁 Quote Link to comment Share on other sites More sharing options...
Dat73z Posted September 17, 2023 Author Share Posted September 17, 2023 Have a lot going on and I realize my workspace is an absolute mess. It's been a while and there are parts and tools scattered about so I think the strategy here is to clean everything up this next couple of weeks while doing these sidebar projects to get the car sorted. Quote Link to comment Share on other sites More sharing options...
Zetsaz Posted September 20, 2023 Share Posted September 20, 2023 Daaaaaaaaaamn, the KW bits look good! Getting your ZCG brakes is just motiving me to finally pay up for the upgrade. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted September 22, 2023 Author Share Posted September 22, 2023 Thanks @Zetsaz yeah it's been a long time coming, I really liked the feel driving the ZCG shop car over the t3 BBK setup personally with both the 1" and 15/16 MCs I had before. I'm downsizing everything but I think it'll be the right balance for my needs. More parts came in today including the t3 rack and high clearance tie rod ends. I owe a bunch of people measurements at this point to keep things moving forward on some design and machining work so that will be the priority this weekend. Quote Link to comment Share on other sites More sharing options...
Zetsaz Posted September 23, 2023 Share Posted September 23, 2023 (edited) That's my thought. General feedback I've gotten from people who actually drive their cars a lot is that the T3 or really anything by Wilwood is mostly just fine. I'm at a point where I'm okay spending a bit more for great instead of still paying a lot and potentially ending up dissatisfied. You're gonna be really happy with the T3 steering rack though. Best thing I've done so far for driveability. Edited September 25, 2023 by Zetsaz Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted September 24, 2023 Share Posted September 24, 2023 Follow-up from a few months ago. Swain confirmed their coating can, and is often top-coated. I bought some cerakote “glacier gold” and will spray the headers sometime in the coming week when the paint gets here. header is back, but leaving it in the box to keep it clean until I get it painted. Quote Link to comment Share on other sites More sharing options...
