datsun_dom Posted February 2, 2019 Share Posted February 2, 2019 Hey all. So I'm planning on turning my car into a drift car over the next few seasons. I am planning on doing a r200 swap down the road but I just plan on welding the r180 for now. My question is what is the torque limit of a welded diff. I know the first thing to go in the r180 is the spider gears so welding them should take care of them. Now what would be the next thing to go in the diff. And roughly at what point. I know this is all hypothetical but any help is appreciated Quote Link to comment Share on other sites More sharing options...
jhm Posted February 2, 2019 Share Posted February 2, 2019 Actually, the stub axles are often the weak link in the drive train vs the diff and half-shafts. I'd hesitate to give an actual number limit, because it depends on so many variables. If you can provide some specifics on your build and setup, might be able to better answer your question. Quote Link to comment Share on other sites More sharing options...
datsun_dom Posted February 2, 2019 Author Share Posted February 2, 2019 (edited) It's a l26 bored out 10 over with a comp stage 1 cam intake and exhaust ports matched to manifold MSD 6al Msa 6-2 headers stock 4 speed transmission rebuilt. I have a stock replacement exedy clutch but may upgrade to a different clutch for the drift setup. It's on CX racing weld on coilover and polyurethane bushing throughout My main concern is all the clutch kicking and load I will be spurring onto the drivetrain. Edited February 8, 2019 by datsun_dom Quote Link to comment Share on other sites More sharing options...
Gollum Posted February 2, 2019 Share Posted February 2, 2019 Jhm is right. The stub axles can go long before the diff. I'd also point out that driveline angle kills the stub axles in short order. The famous pic of jnjdragracing doing a wheel stand on a R200 is a bit misleading. If you dig through those posts you'll see that he was really peticular about making sure ride height was set properly so the car would squat to level axles under launch, and did a great job setting the car up. If you can minimize transient squat and lift by running stiff springs and don't lower the car much at all, you'll likely be okay for a long time. Otherwise you're better off finding a shop that can make you custom one piece CV shafts end to end to minimize chance of breakage, but that's certainly not a minimal cost. Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted February 2, 2019 Share Posted February 2, 2019 12 hours ago, Gollum said: If you can minimize transient squat and lift by running stiff springs and don't lower the car much at all, you'll likely be okay for a long time. Otherwise you're better off finding a shop that can make you custom one piece CV shafts end to end to minimize chance of breakage, but that's certainly not a minimal cost. Zcar Garage is now offering that at around $1600 http://www.zcarblog.com/2018/06/08/performance/parts-z-car-garage-cv-axles.html Quote Link to comment Share on other sites More sharing options...
NewZed Posted February 2, 2019 Share Posted February 2, 2019 If it's an early 260Z or a 240Z then the stub axles in the rear hubs might be the weak link. Theu-joint half shafts seem pretty tough, many guys keep them on their V8 swaps. But the side loads you'll put on the hub axles will be high. Don't the drifter guys run high air pressure on hard compound tires? It's not like you're maximizing traction for drag racing. When you weld the spider gears to the carrier you essentially make a solid axle. The things that used to spin and break don't spin any more. There are old threads about guys needing to modify the steering to drift. The Z's don't have much range lock-to-lock. They don't drift well. The diff is probably the least of your issues. Quote Link to comment Share on other sites More sharing options...
Gollum Posted February 2, 2019 Share Posted February 2, 2019 1 hour ago, Nelsonian said: Zcar Garage is now offering that at around $1600 http://www.zcarblog.com/2018/06/08/performance/parts-z-car-garage-cv-axles.html Yeah... that hilariously doesn't solve the main problem, which is the sub on the hub side. That's what people break. I actually don't know that I've ever see an axle that replaces break, though I don't pretend to be any authority on that. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 8, 2019 Share Posted February 8, 2019 Welding the diff puts more stress on the rest of the drivetrain of course, I thought that drifters used a specific clutch type limited slip diff. Going cheap usually does not work the best. Quote Link to comment Share on other sites More sharing options...
datsun_dom Posted February 8, 2019 Author Share Posted February 8, 2019 Drifters (who can afford it) use a 2 way lsd but I'm a drifter on a budget plus I'm a LEARNING drifter so I will save the pricey stuff for when I can use it to it's full potential. If I really wanted I could get a r200 spool which would be best scenario in my opinion. Quote Link to comment Share on other sites More sharing options...
seattlejester Posted March 18, 2019 Share Posted March 18, 2019 I'd echo the above, the stub axles would be my worry more so than the diff. I've tried drifting the Z in a formal setting and even in the hands of some experienced individuals it is a handful. Really short angle makes it hard to catch snap transitions. Not saying it isn't doable, a few people have done so, albeit usually with extensive modification, but it may be best to start or consider running more replaceable suspension if you are married to idea of Z drifting. That is convert to S chassis front suspension and consider a rear end swap either via TTT or a 8.8 conversion. Both options could be sorted on a budget with a lot of research and fabrication. Manual rack is going to be a bit trouble some on slow speed corners and when it snaps back in a Z it will be hard to catch and given where you sit (right in front of the rear wheels) it will also be disorienting. We stopped taking passengers real fast on the donut exercise, even the figure 8 was a bit much. Quote Link to comment Share on other sites More sharing options...
