280z - Hunt for the "CLUNK" with VIDEOS
p7x
Hey Everyone,
So I replaced my front diff mount with a solid unit and now the clunk in the car is louder more pronounced than before. Worn diff mount might have contributed but now with the solid mount its exacerbated the clunk. I'm new to the S30s so with all the experience on this forum I was hoping you all could help me in determining if there is too much play in the drive line and what might be the source of the "Clunk". Assuming the old rubber diff mount absorbed some of teh slack and now with a solid unit the play in the driveshaft is now more pronouced.
Videos below showing some play in the driveshaft U-Joints at the tranny and very little play in the U-Joints at the diff. Based on the last video I think the driveshaft -Joint at the tranny is potentially the source of the clunk.
***REPLACED:
1) transmission mount (oem replacement)
2) front differential mount (solid unit)
3) Half shafts checked and U Joints are in good shape
transmission to driveshaft play
Driveshaft to Diff play
Driveshaft twist and clunk
I'd appreciate your thoughts / advice
Edited by p7x
 I agree with you. U-joints sound like the source of the clunk. There should be absolutely NO perceptible movement in the u-joints in ANY direction. They will clunk when reversing or going forward and vibrate at high speed. Don't replace them with cheap ones. Nissan and Spicer are both good quality. I believe Nissan sells u-joint c-clips in different thicknesses to tighten up the slack I see in the 1st video.
Research tells me that you can't replace the U-joints or not easily anyways. Nissan changed them in 75 and it looks like if I were going down the route to fix it i'd have to replace the whole driveshaft...
This is interesting. I pulled the R200 and half shafts from a 78 280Z, replaced the U joints and installed the R200 and half shafts in my 240Z.
Are you perhaps thinking of the driveshaft?
Take the half shafts to a drive line shop.
Ya just to be clear I’m talking driveshaft(prop shaft) between the tranny and diff, not half shafts. From what I can find from multiple sources is after 75 you can’t replace the u-joints on the driveshaft easily.
In my hunt I’ll probably take the half shafts off as well to inspect them.
10 hours ago, bunkhouse said:
I forgot we working a 280. I was going back in my memory to my 240 days. I'd look into getting a repair quote from a drive shaft shop.
Ya there’s a good shop near by that I’m gonna call this week talk to them and see what they’ll charge. I feel I could do a driveshaft (prop) swap just no clue about the balancing of the driveshaft (prop)
If you're going to pay somebody to repair it, you should consider having one made that has U-joints that you can replace.  I can't imagine that it would be that much more than having it repaired.  Places like Hoke Performance are offering custom CD009 to LN diff for $400.  A shop is probably going to charge you 4 hours + parts.
New drive shaft (prop) is ordered and last night went through the whole back end and tightened everything to spec. Something I should of done from the beginning ... lesson learned. Pretty much everything was spec except the inner and outer lower control arm bolts those were pretty loose. gonna take the car out today to see if tightening things helped at all.
Once the new driveshaft is in I’ll update the thread.
  • 4 weeks later...
If the new Ujoints don't solve the problem, the next place to look is the mustache bar bushing and insulating rubber washers.  When they wear out they allow the mustache bar to slam up into the subframe, unfortunately the original rubber bushings are NLA so you are stuck with using Poly bushings which come with there own problems but they will fix the clunk.
So moving the car around  in the garage and
1) when  backing the car out of the garage and a full second of grinding coming from the rear end while in reverse. This metal grind and moaning noise happens at very slow starts in first as well but this was the loudest i've ever heard it.
2) forcing the clunk to happen in 1st gear and then shifted into reverse and the clunk happen with no power going through the driveline. WTF
I've check the bushing, mustache bar, bolts etc and things seem to be in good shape.
Honestly starting to worry that my tranny or diff are actually the issue.
I would agree with you and the others that the "clunk" appears to be the u-joints (or possibly even the diff itself....they are notorious for having a lot of slop in the backlash settings).
A grinding noise is completely different.  Put the car on jacks, run it in different gears (i.e. neutral, reverse, first, etc) and check the components individually with a stethoscope.  If you don't have ready access to a scope, a long metal rod does a good job transmitting internal noises (I often use a long screwdriver or ratchet extension)....just put one end on the component and the other end in your ear.  If you're hearing this noise while the car's in neutral, doesn't seem likely that it would be your differential.  Possibly tranny or clutch, as you suspect.
^^^^ Jebus!
Mine might not be that bad but maybe not far off. From the video below what to you guys think? I just installed the new driveshaft but haven't driven it yet. Regardless there's still a good amount of play in the diff but is it too much. The play is shown is the movement before the diff starts spinning the wheels.
I've been beating around the bush based on what ive read in the community but the bush (Diff) might 100% be the problem.
Edited by p7x
32 minutes ago, bunkhouse said:
 Take it out and drive it. Some (hopefully all) of the clunk should have gone away with the new u-joints.
Need to swap the dust cover / sleeve from the old to the new shaft to cover the exposed gap then I'll be driving it to see if there is any change in the clunk.
I have the same slop in my R200. Very loud clunking when driving. My issue is when swapping from the R180 I had to switch to poly bushings including the RT front mount. It is awful to drive is the poly is the issue.  I will be digging my R180 out to test for the same slip that is in your video. If that’s the case I guess it’s just the hard mount and bushings. I’ve swapped the carrier in the r200 to an obx and there was no change in slop (proper backlash).
Edited by HuD 91gt
Really?
I had clunking with the stock diff mount that was worn (thought that was the problem because the diff moved up and down) so I went to the solid mount and it actually made the clunking worse. which is starting to make a little more sense if the diff is the issue, bolting it down with a solid mount  would exacerbate the issue...more and more thinking its the diff itself.
Edited by p7x
