DAT240Z Posted January 31, 2020 Share Posted January 31, 2020 I'm looking for a plug and play wiring and harness for my LS1 5.7 swapped 240z. Looking for recommendations on what brand guys are using . I have T56 transmission and stock ECU. Thanks Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted February 1, 2020 Share Posted February 1, 2020 I used a PSI Conversion harness for my LS2 / T56 and I'm SO glad I did, and didn't use the stock and hacked up one that came with the motor. It looks extremely clean and all the connectors are cut to length so perfectly that there's really no guess work at all. The only real trickery was re-wiring the factory Z harness for the LS starter. Everything else was pretty much plug-and-play. I personally mounted my PCM above the passenger floor pan on the firewall and at least with my 240z. I can probably dig up some pics if it's interesting to you. Quote Link to comment Share on other sites More sharing options...
DAT240Z Posted February 1, 2020 Author Share Posted February 1, 2020 Yes please post pictures. Thanks Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted February 3, 2020 Share Posted February 3, 2020 I surprisingly couldn't find any good shots of just the PCM itself. When I'm up at the shop later this week I'll grab a couple. Is there anything in particular you're interested in seeing shots of? I'm running Speedhut gauges with my swap, using CAN-BUS from the OBD2 port on the ECU, but I believe that only works for 2006+ PCMs. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 7, 2020 Share Posted February 7, 2020 Haltech for one will give you what you need. Quote Link to comment Share on other sites More sharing options...
Richard Oben Posted February 7, 2020 Share Posted February 7, 2020 We used a dieted donor harness. Power, IGN power, Fuel pump, fan, ground and a few others like VSS and AC, in and out at my request. I know that is now what was asked for but it may help in decisions. Quote Link to comment Share on other sites More sharing options...
yiannit280z Posted February 16, 2020 Share Posted February 16, 2020 I would use wiring specialties harness https://www.wiringspecialties.com/unls1wihatup.html. Ive used them before and they work great. Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted February 18, 2020 Share Posted February 18, 2020 PSI LS2 T56. Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted February 20, 2020 Share Posted February 20, 2020 Also PSI also LS2 T56, basically same location choice as mrk3cobra Quote Link to comment Share on other sites More sharing options...
Yawannago2 Posted June 10, 2020 Share Posted June 10, 2020 BrandenZ You stated in the post above The only real trickery was re-wiring the factory Z harness for the LS starter. I am at that stage now, and could use some insight if you have a post or guidance. I have removed much of the unnecessary wiring in my body harness but am having trouble getting power to the components to generate the keyed ignition Power source the LS standalone harness . Quote Link to comment Share on other sites More sharing options...
DonH Posted June 10, 2020 Share Posted June 10, 2020 On 6/10/2020 at 5:21 PM, Yawannago2 said: BrandenZ You stated in the post above The only real trickery was re-wiring the factory Z harness for the LS starter. I am at that stage now, and could use some insight if you have a post or guidance. I have removed much of the unnecessary wiring in my body harness but am having trouble getting power to the components to generate the keyed ignition Power source the LS standalone harness . Expand Do you have a 240, 60 or 80? the 240 is much easier VS the tied in Interlock system on the 260Z... Quote Link to comment Share on other sites More sharing options...
Yawannago2 Posted June 11, 2020 Share Posted June 11, 2020 77 280z Quote Link to comment Share on other sites More sharing options...
trackzpeed Posted June 14, 2020 Share Posted June 14, 2020 I used wiring specialties. Great service and product. Jim Quote Link to comment Share on other sites More sharing options...
DonH Posted June 25, 2020 Share Posted June 25, 2020 Im going with a Holley Terminator X ... Any way you look at it you will save $$ long run by going with it - For $1000 you not only get the ECU AND Harness you get the added bonus of real time tuning... no more sending an ecu out and back etc. Also can get rid of a MAF tune and go with speed density cleaning up the engine bay. Really, with it you can fire an engine up with 5 connections! Unreal... I almost pulled the trigger on a BP automotive harness and do the stock ECU... Stock ECU plus tuning and a new harness if going with engine upgrades = $1400 and upward for dyno tuning Quote Link to comment Share on other sites More sharing options...
Dimebag Posted September 12, 2020 Share Posted September 12, 2020 Were you able to get your Holley Terminator X harness up and running? I am curious to see how you have in installed and which side you mounted and ran thru the firewall. Thanks. Alan Quote Link to comment Share on other sites More sharing options...
