fusion Posted August 4, 2021 Share Posted August 4, 2021 I need to convert to 5 lug setup for my front wheels. The rear is already taken care of with the super 8.8 kit. I am heavily leaning towards the Silvermine conversion hubs. But on to the brakes. I am not planning on tracking the car, but it will be a single turbo LS and need decent stopping power on the street. So I saw there is a conversion to run Toyota brakes. Looks fairly low cost. There are a lot of threads but most of the info is lost or broken links. I did find this link to a page about the swap: https://web.archive.org/web/20140110095234/http://drivendaily.org/s30-toyota-brake-upgrades/ My questions are: 1) is this swap still a decent option in 2021? 2) is the information in the page above still correct and relevant? 3) does this swap clear 15" wheels ( I will be running a spacer) 4) is buying a kit the way to go or is ordering parts from Rockauto better? Thanks for any input. Joe Quote Link to comment Share on other sites More sharing options...
Miles Posted August 4, 2021 Share Posted August 4, 2021 (edited) Can't recommend a front brake system without knowing the details for the rear brakes you have. Need to know what rotor size and calipers are on the car now. Yes, the information on the link for the Toyota swap is correct, but I do not recommend the Wilwood MC as I had three of them fail - two of which leaked internally right out of the box. My set up is: Front - Toyota calipers, solid rotors and Carbotech AX6 pads. Unless you are racing you do not need vented front calipers. Rear - 240SX calipers, 300zx rotors (non turbo) and Carbotech AX6 pads. Booster - 9 inch 280z Master cylinder - 15/16 280ZX purchased from Arizona Z Car. Tried the Wilwood 1 inch MC three times but they all failed. SS flex lines Brake bias calculations: Front - 60% Rear - 40% Toyota calipers clear my 15in Ansen slotted wheels. I have had this setup for 12 years and it works well for street driving. The only thing I don't like is that the pedal travel is a bit long. The Carbotech AX6 pads have the best cold bite of any pad I have ever used and the bite gets better when the pads heat up. These pads never fade. I have heated them up to smoking hot and there was no fade. Edited August 4, 2021 by Miles Quote Link to comment Share on other sites More sharing options...
fusion Posted August 4, 2021 Author Share Posted August 4, 2021 Thanks for your reply. I will be running stock 2015 mustang rear brakes which are 11.8" calipers Quote Link to comment Share on other sites More sharing options...
jhm Posted August 4, 2021 Share Posted August 4, 2021 As confirmed by @Miles, the Toyota front brake upgrade is still very much relevant and a popular swap. If you haven't seen the thread in the FAQ section, you can find it here (even though it was initiated in 2005, most of it is all still relevant and a wealth of information): https://forums.hybridz.org/topic/39435-help-what-brake-options-are-available-for-s30-z-cars/ Kit vs piece it together yourself: Several vendors offer a variety of kits, from mild to wild, and many of them offer individual pieces of their kits if you prefer to pick-n-choose. A few of these vendors include T3, ArizonaZCar, SilvermineMotors, ZCarDepot, ZCarGarage, Milkfab Engineering, MSA Auto, etc. I would check them all out before making any decisions. You can generally save a money by piecing things together yourself, but lots of folks would rather just buy the kit and get it installed asap....really boils down to your own preferences. On my current 260, I recently pieced together my own front brakes using universal Wilwood 4-pot aluminum calipers with 11.5" vented discs from a Saab 93....it involved a lot of research and some custom fab, but I'm an engineer by training and personally enjoy that process. Good luck with it. Quote Link to comment Share on other sites More sharing options...
Miles Posted August 4, 2021 Share Posted August 4, 2021 (edited) 5 hours ago, fusion said: Thanks for your reply. I will be running stock 2015 mustang rear brakes which are 11.8" calipers Factory brakes are designed as a system. Change one component and it has a domino affect. You will need to consider brake bias in your decision on matching front brakes to the Mustang brake you already have. I recommend that you read up on front to rear brake bias before making a decision on any front brake install. Brake bias is covered extensively in the Brake Forum. Edited August 5, 2021 by Miles 1 Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted August 5, 2021 Share Posted August 5, 2021 My experience: I have the 4X4 front calipers, and 300zx vented rotors on my street Z. Much larger and heavier than Stock. I find the setup adds too much weight up front and the car understeers worse than before. Next upgrade will involve reducing the rotor and caliper weight. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 5, 2021 Share Posted August 5, 2021 (edited) This was one of the few allowed brake upgrades in VARA racing 10 or so years ago and many people ran it. It's a huge increase in heat capacity over stock and very worthwhile if it's your only option. If you have other options, there are better, lighter BBKs out there - but they mostly require bigger than 15" wheels. And yes, matching front to rear and getting the bias right is important. Edited August 5, 2021 by JMortensen Quote Link to comment Share on other sites More sharing options...
fusion Posted August 5, 2021 Author Share Posted August 5, 2021 Thanks guys. I won't be tracking the car, but will have lots of power on tap so want to upgrade the stopping power. I understand I'll need to tune the brake bias. I am leaning towards the later model s12+8 calipers with vented 300zx rotors. I feel like that will be a good match with the mustang rear discs. Does anyone know if the front rotors from an 84-86 turbo 300zx will bolt right in to this setup? I will be using the Silvermine 5 lug hubs with a 5x103mm rotor bolt pattern. I think it works Quote Link to comment Share on other sites More sharing options...
jhm Posted August 5, 2021 Share Posted August 5, 2021 Yes, should work....provided offset is compatible (or can be made compatible with spacers). I'm assuming it is, as Edan seems to be producing those 5-lug hubs specifically for compatibility with the Z31 5-lug, if I read his literature correctly. I'm sorry I don't have first-hand experience with that swap to confirm 100%. I do, however, have the attached handy spreadsheet of tech data on Nissan rotors that I snatched off of one of the 510 forums I belong to -- may come in handy for you, or others, in the process of upgrading the stock brakes. Nissan Brake Rotors.xlsx Quote Link to comment Share on other sites More sharing options...
Michael Posted August 14, 2021 Share Posted August 14, 2021 (edited) The big challenge is not in making one or another individual choice, of this brake-kit or that, but in having the entire combination work as a system... brakes, wheel/tires, suspension and drivetrain. Larger brake rotors mean larger wheels, which often means conversion to 5-lug and/or the coilover mod to accept larger backspacing. 5-lugs means, in the rear, new stub axles, and that likely leads to new half-shafts and so on. The project snowballs. There is no obvious way to change one set of components, leaving the rest alone, without glaringly deleterious effects, like the rear brakes locking up first. Meanwhile, these various "upgrades" aren't necessarily useful for the street, but they are heavier, and thus sap acceleration. Should we just stay with stock components? Maybe, but how to find suitable tires for original rims? And what of brake components that are leaky, rusted, frozen? Is it really all that sensible to do a complete shop-manual-spec restoration, on 50 year old components? There doesn't seem to be a good solution. Thus the dilemma! Edited August 14, 2021 by Michael Quote Link to comment Share on other sites More sharing options...
Noll Posted August 14, 2021 Share Posted August 14, 2021 (edited) 1 hour ago, Michael said: The big challenge is not in making one or another individual choice, of this brake-kit or that, but in having the entire combination work as a system... brakes, wheel/tires, suspension and drivetrain. Larger brake rotors mean larger wheels, which often means conversion to 5-lug and/or the coilover mod to accept larger backspacing. 5-lugs means, in the rear, new stub axles, and that likely leads to new half-shafts and so on. The project snowballs. There is no obvious way to change one set of components, leaving the rest alone, without glaringly deleterious effects, like the rear brakes locking up first. Meanwhile, these various "upgrades" aren't necessarily useful for the street, but they are heavier, and thus sap acceleration. Should we just stay with stock components? Maybe, but how to find suitable tires for original rims? And what of brake components that are leaky, rusted, frozen? Is it really all that sensible to do a complete shop-manual-spec restoration, on 50 year old components? There doesn't seem to be a good solution. Thus the dilemma! In fairness, in that hypothetical situation (trying to just upgrade the brakes) none of the latter is required. 4 lug 15" wheels work just fine with the 4x4calipers/300zx rotors (14" might just fit depending on the wheel but no personal experience), and as mentioned above the bias works out nicely with 240sx calipers in the rear and deleting the stock drum brake bias block (or a aftermarket bias adjuster is really no biggie to add). No need for 5 lug, beefier axles, etc unless you're making way more hp than stock, and 5lug won't massively change backspacing unless you're completely replacing the rear suspension with something off another car. IIRC you can even fit 15x8 +0 wheels without coilovers (just) although I built my own coilovers for other reasons. Obviously not directly related to OP's needs here, just talking about the brake upgrade in general Source: my car . Edited August 14, 2021 by Noll Quote Link to comment Share on other sites More sharing options...
Michael Posted August 14, 2021 Share Posted August 14, 2021 While of course I can't speak for Fusion (or others), the rationale behind 5-lugs is that it allows for use of the standard drag-racing wheel choices, especially in 15" diameter. If easier/cheaper alternatives are forthcoming, then of course it would be silly to insist on an upgrade merely for upgrade's sake! But in my experience - broad, but shallow and unsophisticated - to find decently light/strong wheels in 15x8 in 4x114.3 has been problematic, to put it mildly. Noll - your photos are intriguing indeed. What wheels to you use, and where did you find them? What size are they, and how much do they weigh? Not to hijack Fusion's thread, but my vantage point is that of a car that's been sitting for decades. The tires and probably the brake-pads/shoes date from the Reagan administration. Now, attempting a return to serviceability, would be less daunting, if the task could be done incrementally. Fusion's question about old-school brake solutions tickled an itch. Quote Link to comment Share on other sites More sharing options...
Noll Posted August 14, 2021 Share Posted August 14, 2021 1 hour ago, Michael said: While of course I can't speak for Fusion (or others), the rationale behind 5-lugs is that it allows for use of the standard drag-racing wheel choices, especially in 15" diameter. If easier/cheaper alternatives are forthcoming, then of course it would be silly to insist on an upgrade merely for upgrade's sake! But in my experience - broad, but shallow and unsophisticated - to find decently light/strong wheels in 15x8 in 4x114.3 has been problematic, to put it mildly. Noll - your photos are intriguing indeed. What wheels to you use, and where did you find them? What size are they, and how much do they weigh? Not to hijack Fusion's thread, but my vantage point is that of a car that's been sitting for decades. The tires and probably the brake-pads/shoes date from the Reagan administration. Now, attempting a return to serviceability, would be less daunting, if the task could be done incrementally. Fusion's question about old-school brake solutions tickled an itch. Makes sense! All depends on what your goals with the car are. The wheels on my car are Rota Kyushas in 15x8+0, although there are a good few options in that size from various brands. Not sure on the weight unfortunately, but they didn't feel super heavy when I unboxed them. And yeah, I feel you on the serviceability front, my car had been sitting over a decade and was in terrible shape when I got it (no joke, the only exterior panel I haven't replaced is the roof, and have done floors, rockers, seatbelt mount areas, half the firewall, much of the engine bay, etc), so I was basically starting from scratch in regards to suspension/brakes/etc - all needed totally redone one way or another. Quote Link to comment Share on other sites More sharing options...
Michael Posted August 15, 2021 Share Posted August 15, 2021 (edited) According to this site: https://www.wheeltech360.com/ROTA-Wheel-Kyusha-15x8-4x11430mm-73mm-Hub_p_136.html , the Rota Kyusha 15x8 in 4x114.3 weigh 16.6 pounds. Not outrageous, but a bit on the heavy-side. A search for 15x8 wheels in suitable offset (+0; or was that -0? I'm so confused!!!) shows that many weigh around 16 pounds. Some months (years?) ago, I had a thread on Vors wheels (https://forums.hybridz.org/topic/132345-vors-wheels-specifically-tr3-opinions/), which were 2-3 pounds lighter. Next question is tires. As expected, choices in 15" are... limited. There's an OK selection in 225/50-15, but anything wider gets rare. Not having overdrive on my 5-speed, I'd really prefer a taller (and wider? maybe) tire. Options dwindle... it's not 1994 anymore. Darn. Options greatly increase if we go to 16" wheel diameter. But unfortunately tire weight (not to mention wheel weight) jumps... typical 225/50-15 tires goes from ~23 lb each, to ~29 lb. But perhaps I'm obsessing over the wrong thing? Edited August 15, 2021 by Michael Quote Link to comment Share on other sites More sharing options...
Ryanotown22 Posted September 6, 2021 Share Posted September 6, 2021 Anyone have to shave down the caliper fins? I have 15x7 konig rewind and the fin on those calipers are rubbing. I have 1989 Toyota 4Runner v6 calipers nugeon 9701550A (97-01550A) and 9701550B (97-01550B). I have the spacer in from zcardepot for this swap also. Quote Link to comment Share on other sites More sharing options...
Miles Posted September 6, 2021 Share Posted September 6, 2021 Yes, but not too much. After identifying the fin that was rubbing, I used a grinding wheel to remove enough material to stop the rubbing. Quote Link to comment Share on other sites More sharing options...
