jmark06 Posted April 28, 2006 Share Posted April 28, 2006 Has anyone tried this fan or have an opinion on it for a stock turbo radiator to fit ic piping? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=8058785556&sspagename=STRK%3AMEWA%3AIT Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted May 3, 2006 Share Posted May 3, 2006 At 35 bucks whats to lose buy that thing and sell it to me now Quote Link to comment Share on other sites More sharing options...
nienberg.11 Posted May 3, 2006 Share Posted May 3, 2006 I've never wanted to upgrade from the belt driven fan, but if something that cheap could do a better job, why not. Quote Link to comment Share on other sites More sharing options...
olie05 Posted May 3, 2006 Share Posted May 3, 2006 You won't find a better deal on a new fan. I picked mine up used, for less than half of what you're looking at. Mine is also smaller though. It will definitely be an upgrade from the stocker. Quote Link to comment Share on other sites More sharing options...
blake culp Posted May 3, 2006 Share Posted May 3, 2006 I have a 14" electric fan on mine and it sticks out about three inches, as far as IC piping the main thing is a electric fan removes the stock fan shroud , that really frees up a lot of space. Im sure that fan would work good. Blake Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted May 3, 2006 Share Posted May 3, 2006 I've got the 16", moves alot of air off the battery charger. Don't have a running car so I can't attest to the actual cooling abilities but it's cheap! Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted May 3, 2006 Share Posted May 3, 2006 How many amps do you guys think that draws? Quote Link to comment Share on other sites More sharing options...
Austenp405 Posted May 3, 2006 Share Posted May 3, 2006 I ordered one to replace mine that just went out. It should be here by Friday and I'll let you guys know how it goes. Quote Link to comment Share on other sites More sharing options...
dapiper Posted May 4, 2006 Share Posted May 4, 2006 My 16" Staul (??) pulls 18A. Quote Link to comment Share on other sites More sharing options...
Hugh Posted May 4, 2006 Share Posted May 4, 2006 Thats a darn good deal, and it looks about the same as the one I'm running in my car. I know mine was like ~$70 at the auto parts store. Can't beat $35! Quote Link to comment Share on other sites More sharing options...
Guest ZFury Posted May 12, 2006 Share Posted May 12, 2006 I have that same fan. It works great. Really is prolly' more than needed. It will pop 20a fuses from time to time, but not 30's. Will also melt average switches. My guess is that it is just below 20a when running. Here is an old pic of mine. Quote Link to comment Share on other sites More sharing options...
sims76 Posted May 12, 2006 Share Posted May 12, 2006 I also ordered one, thanks for the heads up. Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted May 15, 2006 Share Posted May 15, 2006 if you put a relay on the fan / switch that should solve any switch burning problems as well as fuse popping Issues. it looks like a decent fan. I run dual hayden 12" fans. through a relay and remote switch. They were great. Quote Link to comment Share on other sites More sharing options...
Guest ZFury Posted May 15, 2006 Share Posted May 15, 2006 Yeah... I just finally got a heavy duty switch, works fine now. Though I was thinking about using a relay. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 16, 2006 Share Posted May 16, 2006 I've got a VERY similar Mr. Gasket fan 16" on mine. I have Intercooler/OilCooler/AC Condenser/Radiator all stacked up front and the car tends to run cool even at 15psi boost and in traffic. That looks like a great deal since I paid $80 for mine. Mine came with an adjustable temperature fan controller and relay though. Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted May 18, 2006 Share Posted May 18, 2006 Well i Bought one to the other day. Man jmark that guy should of gave you a discount with all the business you gave him by posting lol. Quote Link to comment Share on other sites More sharing options...
sims76 Posted May 18, 2006 Share Posted May 18, 2006 I got the 16" one from this guy. I hotwired it to a battery just to test it out and it almost sucked my shirt off my chest into the fan. Yikes. These things move some air. Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted May 24, 2006 Share Posted May 24, 2006 Got the fan today. You were right i hooked it up to a battery box in the house and it almost knocked over a chair. Only bad thing mine got a crack right under one of the mounting holes. Since its a clean crack ill just use contact cement or something, not worth shipping it back. Quote Link to comment Share on other sites More sharing options...
Bartman Posted May 24, 2006 Share Posted May 24, 2006 Mine should be here next week. I was using a Taurus Fan, but now I need a little extra clearance and this one should give me what I need. If I still need more cooling power I'll add a couple of 12 inchers between the AC Condensor and the radiator. I wonder if fabbing up some type of shroud would make it work better? I know that a shroud forces air to be pulled through the radiator, but when the fan is mounted directly to the radiator is it necessary? There are a couple of posts where people talk about the Taurus Fans working better when the shrouds are sealed to the radiator. Quote Link to comment Share on other sites More sharing options...
Marc280 Posted May 31, 2006 Share Posted May 31, 2006 I've got one of those fans on my 280zx and it works great! Pulls a lot more air through the radiator than the stock setup and gets rid of that annoying noise when you give it a rev. I used a Davies Craig Thermatic Switch as well which means you can control exactly what temp you want it to come on and off at too. Would definitely reccomend it. Quote Link to comment Share on other sites More sharing options...
