Derek
Gauging interest in EDIS mounting parts
I've had a couple of requests to buy some of the parts I made for my EDIS install
http://forums.hybridz.org/showthread.php?t=140291
I'm trying to get a feel as to how much interest there is in purchasing the parts. I would sell everything individually. If there is enough interest I would also check into getting the 36-1 wheels laser cut as well.
Thanks
Derek
Share this post
Link to post
I am no where near ready, but I was also wondering if you'd consider making kits. Interest based on price of course.
I'd be looking for the sensor mount, wheel mount and coil mount.
If the wheel mount included a 36-1 wheel, great, but not required.
One thought on the wheel mount- If it had marks every 10 degrees,
it might aid tuning out a few degrees of error when phasing the
sensor/wheel
Share this post
Link to post
I like the coil bracket but plan to use the dodge pack :(
and I mounted my edis wheel ont he back of the crank pulley and clocked to to pickup on the driver side between the 2 bolts onthe drivers side of the timing cover
Well you could always switch over to the Ford pack!. When I get every thing priced up a bracket for the Dodge might not be a problem.
I thought about trying to mount the wheel on the inside but opted for the adapter instead. This way you can do the installation without removing the balancer.
Derek
Share this post
Link to post
Another upside to the wheel adapter is that you don't have to put an old damper through the fatigue of being on the lathe. I think the experience may have compromised mine as it has a low-speed wiggle that I don't remember being there before. The wheel runs perfectly true, though. I'd probably go for an adapter wheel so I don't have to abuse a replacement pulley when the time comes.
Share this post
Link to post
Can you make them that will work for a Tec-3 and a 60-2 wheel?
Sensor's like these:
Yes but you can't afford it!
Seriously though it shouldn't be too big a deal to make a clamp that holds the sensor and mounts to my mount.
Do you have a wheel or would you need that as well?
Derek
(Hey that's post # 200 for me !!!)
Share this post
Link to post
If you can make a 60-2 wheel to that would be cool to. What are tolerances on EDIS (Sensor distance to wheel). The Tec is very close:
However,
Typically, the easiest place to mount a trigger wheel is
on the harmonic damper or pulley. If it is mounted on a damper, it should be mounted on
the inner hub rather than the outer dampening ring. The damper/pulley should be keyed
to the crankshaft so that it cannot spin on the crankshaft, as this would cause an ignition
timing error. When using a damper that has bolt-on pulleys, the trigger wheel can usually
be mounted between the pulleys and the damper. However, the accessory pulleys will
need to be shimmed out by 1/8” (the thickness of the trigger wheel). A variety of
application-specific trigger wheels are available.
To choose the proper size trigger wheel, find the diameter of the pulley or damper
on which the wheel is to be mounted. The trigger wheel diameter should be about ½”
larger than this diameter. It should also be noted that the trigger wheel should be at least
¼” from any moving magnetic pieces, such as bolts or other fasteners, to avoid
interference and false triggering. It is important that the trigger wheel be perfectly
concentric with the crankshaft centerline. To achieve concentricity, a shallow cut can be
machined in the front or rear face of the damper to create a centering ledge, and a hole
can be created in the trigger wheel to match the ledge diameter. The trigger wheel can
then be drilled to bolt it to the damper.
See table below to determine the tolerances that must be maintained when
mounting the trigger wheel. These tolerances may require the use of a lathe to true the
trigger wheel with the crankshaft centerline, which can be accomplished by putting the
entire damper/trigger wheel assembly on the lathe. Note that the maximum out-of-round
is the distance between the lowest and highest teeth and the crank sensor. That is, if a
feeler gauge is used between the sensor and the wheel to measure the out-of-round, the
reading between the lowest and highest teeth should not exceed the guidelines in the
table.
Crank Trigger Specifications
Trigger Wheel Size Air Gap Maximum Out-of-Round
2.5" 0.025" max 0.002"
3.5" 0.035" max 0.003"
5" 0.050" max 0.005"
6" 0.060" max 0.006"
7.25" 0.070” max 0.007"
8.25" 0.080” max 0.008"
Share this post
Link to post
7.25" 0.070†max 0.007"
8.25" 0.080†max 0.008"
Well the beauty (warning sales pitch ahead) of my adapter is that it's really true. The crank bolt is what it is indexed off of and I machine the step for the wheel and the bore for the bolt in one op. I'm having the wheels laser cut but then I'm finish boring the centers concentric to outside diameter.
You see we take the guess work out out your edis installation allowing you time to pursue a life of meaningful fulfillment.... or sit around and drink beer.
Derek
Share this post
Link to post
If I had not already spent countless hours first putting a 36-1 timing wheel on the back side of the dampner, then moved it to the front and put the sensor next to the alternator but could not build a strong enough mount so I relocated it to the A/C side and still had a wobbly mount, so I got an A/C mounting bracket from a ZX with the two bolts in the front, mixed and matched the tensioner bracket to make the A/C work and then built two different versions of a VR sensor mount, I would certainly be interested in one of your mounts. :willy_nil
Share this post
Link to post
Well if it's any consolation pictures of your hub adapter is what got me going in that direction so I thank you for that!
Derek
Share this post
Link to post
Being able to switch dampers without machining was definitely on my mind.
One quick question prompted by Xnke's post. The photos in the other thread suggest that you alternator is in the stock position and the
pickup mount does not interfere with it. Is that the case, or would
the alternator need to be relocated?
It's a Maxima alternator but it's mounted in the stock position. There's enough clearance where I can still remove the belt without any problems.
the dodge coil pack allows you to use regular plug wires, thats why so many of us run them, easier than getting the special ford plug wires
I bought the edis stuff on ebay and it included the coil. originally I was going to switch out to the Dodge but started reading how important it was to run good wires with Megasquirt. Magnecore kept poping up so I called them and they had the Ford ends. The wires cost me $97.00 including shipping and were custom legnth.
I really don't see any problem makind a bracket for the Dodge though. I'll just need someone to send me a coil.
Derek
Share this post
Link to post
I like your parts but have already purchased a trigger wheel from DIYautotune.com. Depending on price I'd be interested in trigger mount and crank pulley bracket/wheel
Like I said... very depending on price. I like a clean setup but I already have 3/4 of the parts I need to finish up mine.
Can you send me a PM of a rough estimate of cost.
(I won't hold you to this price, just don't want to tell you I want one then turn away when I see the price)
-Ed
Share this post
Link to post
Really cool! I would be very interested in the sensor mount and wheel mount. I also have the Dodge Coil pack and would be interested in a mount for it as well.
Maybe you can make the mount for both the Ford and Dodge coils to cover all the folks:)
Thanks!
Share this post
Link to post
Alright here's the deal.
I'm going to do a run of 4 wheel adapters and 4 sensor mounts. I'll keep track of my time and materials. I'll then base the price on my shop rate.
If they're too expensive then I'll keep 1 set and throw the rest up on ebay and let the market set the price and that will be the end of it. If the price is right and people want them then I'll continue to produce them.
Thanks
Derek
Share this post
Link to post
