KUSTA Posted April 25, 2012 Share Posted April 25, 2012 Having some problems with my automatic so before a rebuild thought i would try your shiip kit. do you have this available? thanks Quote Link to comment Share on other sites More sharing options...
olderbutnowiser Posted May 4, 2012 Share Posted May 4, 2012 I am in the market for a Jatco shift kit if you still have them Quote Link to comment Share on other sites More sharing options...
bjp Posted November 1, 2012 Share Posted November 1, 2012 Hi, do you still have these kits available? Sounds like just what I need for my van (LD28 turboed) Quote Link to comment Share on other sites More sharing options...
RB30X Posted November 28, 2013 Author Share Posted November 28, 2013 Just a friendly reminder these shift kits are still available. Thanks Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted November 28, 2013 Share Posted November 28, 2013 I don't have an auto, nor do I drag race but it's great to see somebody catering to enthusiasts, even if it's a small market. Great work! Quote Link to comment Share on other sites More sharing options...
RB30X Posted November 28, 2013 Author Share Posted November 28, 2013 Thanks for the comment. Shift kits aren't just for drag racing, they just improve the overall performance of the transmission. It is a small market. I struggled initiatially to find anyone who actual knew how to modify the jatco box. B&M sell DIY shift kits for most GM and Ford model boxes so I thought I'd develop the same thing. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted November 30, 2013 Share Posted November 30, 2013 B&M used to make a "shift kit" for the 3n71b and I put it in my mazda RX5 cosmo. It didn't look like they spent much time on it and the included literature was sparse. This is totally sweet by comparison with nice photos of the process. NIce job RB30x!!!. Here in America, the best trans. to use as a starting point is from a RX-7 turbo, Z31 turbo, or Mitsubishi starion/conquest ESI/TSI and swap over a 1984 maxima bellhousing for the 4n71b or use the one from your Z for the 3n71b if you want to use it with the L28.........don't forget the proper flexplate and to do measuring of the torque convertors to guarantee fitment. Quote Link to comment Share on other sites More sharing options...
RB30X Posted June 18, 2014 Author Share Posted June 18, 2014 Bump Quote Link to comment Share on other sites More sharing options...
G-E Posted July 3, 2014 Share Posted July 3, 2014 http://www.redz31.net/zip/zautomatic.zip KEAS & level10 info... Quote Link to comment Share on other sites More sharing options...
RB30X Posted November 2, 2016 Author Share Posted November 2, 2016 Posted another kit to the US today and thought I'd put a reminder here. Kits still available. Thanks Quote Link to comment Share on other sites More sharing options...
260DET Posted November 4, 2016 Share Posted November 4, 2016 Time flys and ideas change. I now have a LS3 powered S130 with a 4L85E auto for circuit racing, also have a Z31 turbo auto box that looks way lighter than the big 85E. Any info around on the Z31 box as far as it's ability to handle power? Quote Link to comment Share on other sites More sharing options...
Bernardd Posted November 4, 2016 Share Posted November 4, 2016 The z31 auto is rated to 350rwkw with keas mods installed. I would also like to add that by using john deere hydraulic oil vs trans oil you will be adding considerable holding power to the trans. My 3 spd jatco withstood multiple back to back runs at the track with over 400whp for years. The weak point becomes the converter & input shaft. I twisted several input shafts and ballooned 2 converters getting into mid 1.5 60 ft times. Quote Link to comment Share on other sites More sharing options...
260DET Posted November 4, 2016 Share Posted November 4, 2016 Thanks for the info Bernardd, sorry for the thread hijack RB30X, to make amends I'll have to remember to give this a bump later. Quote Link to comment Share on other sites More sharing options...
260DET Posted April 10, 2017 Share Posted April 10, 2017 (edited) The z31 auto is rated to 350rwkw with keas mods installed. I would also like to add that by using john deere hydraulic oil vs trans oil you will be adding considerable holding power to the trans. My 3 spd jatco withstood multiple back to back runs at the track with over 400whp for years. The weak point becomes the converter & input shaft. I twisted several input shafts and ballooned 2 converters getting into mid 1.5 60 ft times. I see that Vasco input shafts are available, are those you the ones you twisted? I'm back investigating the viability of a E4N71B behind the LS3 for road racing, I have one from a '87 Z31 turbo. This will do for a bump, I assume the OP's kits are still available. Edited April 10, 2017 by 260DET Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted May 3, 2017 Share Posted May 3, 2017 used L4N71B on a for drag racing and went ~129mph in the 1/4. Tranny held find, but due to excessive pressure it pushed out the front seal so definitely needs some additional case breathing. Biggest issue was getting someone to build a good converter and options were few and far between. Here is a link to the valve body mods. http://www.eng.famu.fsu.edu/~jthagard/4n71b/ Quote Link to comment Share on other sites More sharing options...
jleekb310 Posted April 2, 2018 Share Posted April 2, 2018 Good day RB30X, I wanted to ask if this shift kit was still available...I'd like to know if it would work with my 1981 Datsun kb310 automatic transmission. It would have to be posted to the United States, Postal Code 06106. Thank you very much for your time and consideration. jlee Quote Link to comment Share on other sites More sharing options...
warriorjoe Posted September 16, 2019 Share Posted September 16, 2019 Why are the pictures so blurry?? Quote Link to comment Share on other sites More sharing options...
RB30X Posted September 16, 2019 Author Share Posted September 16, 2019 8 hours ago, warriorjoe said: Why are the pictures so blurry?? It might be the image hosting site. They were uploaded over ten years ago. Quote Link to comment Share on other sites More sharing options...
calZ Posted September 16, 2019 Share Posted September 16, 2019 8 hours ago, warriorjoe said: Why are the pictures so blurry?? Photobucket blurs images when they're embedded on a webpage. Click them and they'll open in full resolution. Quote Link to comment Share on other sites More sharing options...
hwvigo Posted September 20, 2019 Share Posted September 20, 2019 Kits still available? Would like to buy 2 please in Texas we do love our drag racing Quote Link to comment Share on other sites More sharing options...
