My 240 rb26 build
ZT-R
What do you guys think about tires. Should I go with Wide ZG and run a 315ish vs my current 295, or just put a DOT slick on my current wheels (11.5 wide), or slicks on wider rims and flares... I dont want thing car to look like one big ass tire, as its getting close now.
Maybe the rear suspension needs more work? My car had no traction problems with 360rwhp with 275 Nittos, my mates 500rwhp VQ30 powered S13 has a little less traction but that is only running 255s.
Well that's not encouraging. I have a build good for near 400hp and I'll only be running 245's......
cant throw down into any gear but 4th with it just lighting up. If i downshift then ease in its ok. Waiting on price on a rebuild and upgrade to triple. I have emailed carbonetic and they say the twin with the street plate is only rated for 500hp, so if im running over 10 psi, im over the limits. I need to look into the tilton/quartermaster style throwout bearing so i can run the normal plate, but then maybe the street disk and a triple would be ok, they say 700 on that. All that said my rb26 would slip the twin so i dont know.
Could you run boost by gear, or aftermarket traction control, this works well on high power fwd's - will put as much power down as possible but not let the wheels spin up more than they should therfore giving you maximum acceleration. Should work equally well on RWD
I do do boost by gear and boost by vehicle speed. Im on the wastegate spring at the moment, trying to wait till i dyno tune the high boost to see how much my boost solenoid will yield, then back off the spring some if i have enough adjustabilty. on a 12 psi spring i will probably only be able to boost like 18ish...
