9
Michael last won the day on February 19
Michael had the most liked content!
Gender
Not Telling
Location
was SW Ohio, now LA
Recent Profile Visitors
19402 profile views
Michael's Achievements
Best ways to prevent chassis /frame warping
Michael replied to Joe0690's topic in Brakes, Wheels, Suspension and Chassis
In bygone days, the cognoscenti would note, that suspension loads passed through the chassis are much higher than loads associated with engine torque. Thus, chasing stiffness is more of a concern for precision cornering than for surviving high power/torque. Cary has an excellent synopsis above. I would add the possibility of a "Herb Adams bar" (his book, "Chassis Engineering", details it), which is a sort of spine, that is parallel to the transmission tunnel but sits above it. It connects to the dash bar and to the harness bar behind the seats. Each of these connections is triangulated... in the rear, to the rear strut towers. In the front, through the firewall to the front strut towers. -
Firewall replacement - what is the order for removal
Michael replied to aircobra's topic in Fabrication / Welding
On my S30, the firewall was set back. Steps: 1. Weld the whole car to a chassis jig. By this one means 1"x1" uprights to the rocker panels etc, welded to the jig frame (big I-beams). 2. Cut off the front clip, just ahead of the firewall. 3. Cut out the firewall and the floor (area behind seats) in one piece; cut the floor at the rocker panels (which, as we recall, are welded to the chassis jig). 4. Build the roll cage on another jig. 5. Weld the roll cage into the rocker panels and the C-pillars. 6. Cut the floor-pan at the rear seats. Then weld it, and the firewall, back in. 7. Weld-in the rest of the roll cage. 8. Weld-in the front clip. 9. Weld-in diagonals etc. from the roll cage through the firewall to the front strut towers etc. -
Pete! Looooong time! Can't provide help regarding your specific query, but it would be a lovely thing to have an old-timer reunion, if only virtually. I left the thorny wilds of Ohio and relocated (so-of back) to Los Angeles, where occasionally... maybe once every 3-4 months... one sees an S30 Z on the road. Not a "hybrid" (whatever that means anymore!), one presumes, but at least the body-lines are familiar. My Z is still with me, after 27 years... but like yours, has been off of the road for a while. The irony is that the chassis, suspension, brakes and so on, are decently OK... operate better that one might expect for a 50 year old car. But that engine! Never ran right, and now doesn't run at all.
Catch me up the last six years of how to Z community the internet
Michael replied to tim.d's topic in Non Tech Board
That is of course an excellent point, but I have ample excuse in my frustrations. Content here hasn't merely waned. It's also moved in a direction away from what I hold dear... that being, the carbureted pushrod V8 in an S30. That's how we (shameless plug: I was one of the founding members) started this site some 26 years ago. Unfortunately, when I post a question about annular discharge vs. downleg-booster venturis, the result is... crickets. Not only because of general attenuation in Forum traffic, but because the frontier of interests has shifted. So yeah, for >26 years I've been trying to get the same Z running properly... and so far, have failed. Some folks build and rebuild to improve, to upgrade parts that they've broken in racing etc. Well, I've taken a Camry to the dragstrip, but have never taken the Z. It doesn't run, let alone, run well enough to be raced. And while some regulars have given up over the decades, I have not. Is that the definition of insanity? -
It's really become problematic. First we had the "search before you post anything new" exhortation, which very much quieted the forum, already back around 2012. Then we had the Facebook and instagram/tic-toc malaise, where now everything is short-video-format, to the detriment of any genuine discourse. Then, as the OP notes, we had the coronavirus collapse and no subsequent recovery. I moved from the Midwest to Los Angeles, supposedly America's hotbed of car-culture. Well, where is the car culture? I haven't seen it, online or off. And as for Z's, well, maybe every 6-8 months I'll see one on the local highways. If that. And don't get me started on the provenance of this site... the American V8 engine swap into the S30 Z. Everything is turbo now. When is the last time that anyone did anything V8-related? Sorry... no solutions, only gripes. -
Interesting. How quiet (at least subjectively speaking) are these? I am looking for a mellow, unobtrusive sound... actually I don't much care what it sounds like, so long as it is quiet, doesn't disturb anyone, doesn't draw attention, and approximates (more or less) a 1990s V8 taxicab, like a Caprice or a Crown Vic. In my application, space is not a premium, so huge mufflers (or even two in series, for each pipe --> 4 total) are OK... if that actually helps.
Low-ish compression, but very high displacement in my case. Current 461 cubic inches. Might eventually get one of those 598" short blocks and move my existing parts over. Would you recommend something like this: https://www.dynomax.com/mufflers/super-turbo-mufflers/super-turbo-offset-centered.html ? Maybe the 17769 model (3" in/out, largest in that series... I'd use two, of course).
For the folks running lower-rpm, higher displacement naturally aspirated engines (say, 400 cubic inch and above), what have been your strategy to get reasonably quiet exhaust that isn't too restrictive? I stumbled across Flowmaster's purportedly quietest series of mufflers: https://www.flowmastermufflers.com/products/exhaust/mufflers/street_chambered_mufflers/50_series_big_block/ . These would, coincidently, go behind a big block (Chevy). Muffler size isn't an issue, since my fuel tank is removed (S30) and there's a fuel cell in the hatchback area. My question is about simultaneously quieting the exhaust and keeping backpressure to a minimum. This would be dual exhaust, of course, with a conventional crossover pipe, and headers (for the moment, block huggers).
8th build? Wow! I'm still nursing my first (and only). Car has been on the road, and off. Registered, and not. The current iteration is "not". I need help - local help - with the care and feeding of the engine. The real problem isn't with the Datsun parts, but the Chevy parts... namely getting that darned engine to work properly. Seems like a simple problem, no? But nothing is simple these days! Also, the exhaust is too loud, and the transmission is geared wrongly. I need a custom re-welding for the former, and to write a check for the latter. I also need an engine hoist and a place to work on the car. Success with hobby-cars, begins with success in real estate!
HybridZ is now 26! It's too old to remain on its parents' health insurance plan, and now needs a real-job, with benefits and maybe even a 401K plan. Anyone left here, who started working on their V8 Z project back in the 20th century, and is still wrenching on it? Anyone?
OK, here's a question on carb tuning. This past summer I visited a local tuning-shop, with open ended question about whether to rebuild my poorly-running carb (a Holley vacuum-secondary 750 cfm, basic model) or to buy something else. The technician recommended something with annular discharge boosters.... wouldn't even talk about anything else. Those are nice pieces... but also expensive. Asking AI, for annular vs. downleg, I get the standard AI answer: part obvious, part irrelevant, part condescending, part generic. How about human intelligence? So... who's running an annular discharge carb, such as this one: https://www.holley.com/products/fuel_systems/carburetors/street_strip/parts/Q-750-AN?utm_term=&utm_campaign=Holley+-+Non-Brand+All+SKUs+Performance+Max&utm_source=google&utm_medium=cpc&hsa_acc=7848552874&hsa_cam=22795333857&hsa_grp=&hsa_ad=&hsa_src=x&hsa_tgt=&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gad_source=1&gad_campaignid=22795335240&gbraid=0AAAAAD1FzSrgg0ZyXizSf4N8XZyF0lFbQ&gclid=Cj0KCQiArOvIBhDLARIsAPwJXOaTarreYIfCzmnZukhFJ0DfE902wysmGZtkPzPe60nCkk0bztd8cPkaAlw2EALw_wcB ? Oh, and good luck asking such questions in our "fuel delivery" subforum!
Help me evaluate this car for sale
Michael replied to z_noob's topic in S30 Series - 240z, 260z, 280z
Also not a facebook user here, but speaking in generalities: 1. In 2025, I would think seriously about the value proposition of buying a Z. Some of us have been dabbling in this hobby/affliction for nearly 30 years, starting back when these cars were cheap, plentiful in junkyards, and blank-canvases for modification. And today? Completely different game. Hard to tinker with a 50 year old car, just as a tinkering-car. Even harder to get the performance out of it, that was the stuff of our dreams in the 1990s. 2. These cars are becoming expensive. Even woebegone projects are becoming expensive. For the less-familiar, it's a costly trap! -
And there we have it! A full quarter century old! Old enough, to run for the US House of Representatives!
For people who still run old-school large-displacement V8s (we still exist, right?)... any thoughts on the somewhat-new (been around for 5-6 years) Edelbrock AVS2 carb? This has annular boosters on the primary-side, as opposed to dog-leg. Some articles here: https://www.motortrend.com/how-to/1908-inside-look-new-edelbrock-avs2-carburetor/ and here: https://www.hotrod.com/how-to/tuning-edelbrock-avs2-carb/ . The objective is throttle response, part-throttle drivability, and overall good manners with minimal fussing/tuning. Application is my perpetually-under-repair 454. I'd be looking at the 800 cfm version with manual choke. BTW, there are a few mentions of the AVS carb on HybridZ, but they're from 2014 and earlier.. for the old-style AVS (dog leg boosters on the primaries), for example here: https://forums.hybridz.org/topic/42427-edelbrock-issues/#comment-352025.
Ben, long-term projects take... a long term. So, here's another long-term voice of support! We're almost a quarter of the way done with the 21st century. Some folks started their Z projects back in the 20th century; should hopefully be done, in one capacity or another, before the 22nd! Question: what was wrong with the megasquirt, in terms of successfully operating your LS engine? And what does the Haltech do, that renders the improvement?
