Post your Intercooler setup.
  • Please log in to reply
128 replies to this topic
#21 goodoldjam
goodoldjam
    Junior Member
  • Members
  • PipPipPipPip
  • 198 posts
  • LocationPortland OR
Posted 25 September 2010 - 08:41 AM
goodoldjam Curious to why you mounted your BOV right off the Turbo as you did?
The main reason, if you vent after your venting air that has already been cooled and that gets replaced with more warm air.
Having to remove extra heat is always something you want to avoid.
Second reason, I'm with the thinking that I'm protecting the turbo and not the throttle plate. The higher pressure is before intercooler.
It's a pretty normal BOV placement it just doesn't get recommended as much as it should.
Edited by goodoldjam, 25 September 2010 - 08:43 AM.
72 240z L28et megasquirted
#22 ktm
ktm
    The Real McCoy
  • Donating Members
  • PipPipPipPipPipPip
  • 1612 posts
  • LocationSo Cal
Posted 25 September 2010 - 10:10 AM
Nope. Remember, the air is "cooled" after passing through the I/C. It gets replaced with more air cooled by the I/C.
You are talking about maybe 1 to 2 psi. The BOV is venting to prevent damage to the turbo in all applications. Google "water hammer".
-Bo
#23 goodoldjam
goodoldjam
    Junior Member
  • Members
  • PipPipPipPip
  • 198 posts
Posted 25 September 2010 - 11:32 AM
Yes the air is re-cooled, consider that your intercooler does do work to cool the charge. Intercoolers do heat soak and dumping air that has already been cooled is a waste and should have at least some negative effect on intercooler temps. Your dumping cool air and now you have to re-cool, doesn't sound efficient. Probably could argue that it has little effect but..Remember placing on either side is no more work if you have the room.
Edit: You make 1 to 2 psi sound like a irrelevant number.
Actually I was asked a question as to why and I don't need correction. I'm not trying to push this placement down anyones throat. It is not a strange place to put a BOV. Obviously most people can decide, as did I.
Edited by goodoldjam, 25 September 2010 - 05:18 PM.
#24 280zex
280zex
    Member
  • Members
  • PipPipPipPip
  • 378 posts
  • LocationAuburn, WA
Posted 29 September 2010 - 05:04 PM
I don't run an innercooler. Boosting through a Holley carb cools off the charge nicely. Currently scaring the hell outa myself @22 psi on pump gas..Yup the charge pipe comes off the turbo and goes directly to the carb using less than 2 feet of 2.5 inch to 4 inch pipe. Cheap enough, simple, and very effective except the mpg but hey its boosted!!
Posted Image
Edited by 280zex, 29 September 2010 - 05:05 PM.
I have no idea whats going on!!
#25 stony
stony
    RB Moderator
  • Super Moderators
  • 4285 posts
  • LocationSyracuse Utah
Posted 29 September 2010 - 05:56 PM
that carb isn't cooling anything. you would be able to run higher PSI and be more in the safe zone running an intercooler.
Just my 2 cents.
5.3 truck motor, BTR stage 2 cam, BWs480, custom intercooler, AEM Infinity, 2 speed powerglide, Fully built Ford 8.8, 4:56 gears/spool, 4 link suspension.
#26 hughdogz
hughdogz
    dogZhuge
  • Donating Members
  • PipPipPipPipPip
  • 738 posts
  • LocationPortland, Orygun
Posted 29 September 2010 - 06:13 PM
Well, I'd say the Holley carb makes the cool factor increase ;)
That's a unique induction plenum! It looks custom, or at least customized.
Edited by hughdogz, 29 September 2010 - 06:14 PM.
#27 S130Z
S130Z
    Shrinkage I tell ya, it's SHRINKAGE!
  • Members
  • PipPipPipPipPip
  • 626 posts
  • LocationColumbia SC
Posted 29 September 2010 - 06:24 PM
:D
Edited by S130Z, 29 September 2010 - 06:26 PM.
Posted Image
You know you spen WAY too much time on HybridZ when you have made the connection that Tony D and Ted Nugent are the same person.
"It's not turbo lag, it's foreplay." - SlowBoy Racing
#28 280zex
280zex
    Member
  • Members
  • PipPipPipPip
  • 378 posts
Posted 29 September 2010 - 06:37 PM
the carb doesnt cool anything at all. However the atomization of fuel in the carb works like meth injection. I have 100 deg F intake temps at full run at 22psi. Its not at all good with fuel. 17mpg average and 4 mpg at wot and if it idles too long it will foul the plugs. Mabe I need to try a msd box. This setup is very different. The longer I stay on the throttle the more hp it makes until peak turbo flow.
#29 stony
stony
    RB Moderator
  • Super Moderators
  • 4285 posts
Posted 29 September 2010 - 07:48 PM
OK so it runs good all im saying is it would run better, boost higher with an intercooler.
if the outside temp is 75 degrees, my air intake temps are 75-79 degree at the top end of a 1/4 mile run. running 750 rwhp at 31 PSI
#30 Ben
Ben
    Member
  • Members
  • PipPipPipPip
  • 120 posts
  • LocationAdelaide, South Australia
Posted 04 October 2010 - 03:15 AM
My original setup had 2" SS piping and an AiResearch intercooler:
Attached File  DSC01751.JPG   331.14KB   147 downloads
The current setup uses 2.5" MS piping, and 450x300x76 FMIC:
Attached File  DSC00396.JPG   337.01KB   145 downloads
I too swapped the hot/cold side plumbing in my second version.
The intercooler/plumbing changes saw an extra 3psi boost at the same WG duty-cycle, and allowed a 15kW increase via lower AIT's and the ability to lean out the mixture.
Cheers,
Ben
L28ET 240Z
FJ20ET DR30 Skyline RS-X
RB25DET WGNC34 Stagea RSFourV
Posted Image
#31 jc052685
jc052685
    Member
  • Members
  • PipPipPipPipPip
  • 771 posts
  • LocationHouston
Posted 04 October 2010 - 08:32 AM
Posted Image
Posted Image
www.houston-nissans.com - FORUM NOW ACTIVE!!!!
74 260zt
11.83 @ 115.4 @ 17psi
L28et FTW!
Posted Image
#32 goodoldjam
goodoldjam
    Junior Member
  • Members
  • PipPipPipPip
  • 198 posts
Posted 04 October 2010 - 08:59 AM
You guys are making me think I'm hooked up backwards. I would have to run it like jc, I would have to buy some more bends. If the issue is the cold side soaking heat, I guess I could wrap it.
Edited by goodoldjam, 04 October 2010 - 09:00 AM.
#33 bobbyc
bobbyc
    Member
  • Members
  • PipPipPipPip
  • 259 posts
  • Locationlittleton, CO
Posted 04 October 2010 - 08:31 PM
before the pipes were welded and BOV flange welded on.
Posted Image
will it ever run?
#34 S130Z
S130Z
  • Members
  • PipPipPipPipPip
  • 626 posts
Posted 05 October 2010 - 05:13 AM
Posted Image
Posted Image
I have that same intercooler! How do you like it so far? I have had fairly great results with it.
Posted Image
#35 ezzzzzzz
ezzzzzzz
    Member
  • Members
  • PipPipPipPipPip
  • 951 posts
  • LocationPortsmouth Virginia
Posted 03 November 2010 - 05:51 AM
I'm using a Laminova three core aftercooler built by Rick Zimmer at www.boostecus.com for my SC'd L28 240Z. This is a mere 14" x 6" x 1.6" and rated to approximately 350hp. It is sandwiched between the SC and the plenum. A 12 volt pump, reservoir, hoses and a small radiator (around 20" x 6" x 1") will complete the system. No problems with long complex piping or giant intercoolers. Cost will come in around $1200.
Edited by ezzzzzzz, 03 November 2010 - 05:52 AM.
"I used to have super powers but my therapist took them away."
'71 240Z, '75 280Z, '71 Land Rover 88" LS1 motivated, '84 Land Rover 110" Chevy 4.3 V6 powered 5-door, '86 Range Rover RHD (wrecked), '90 Range Rover, '93 Range Rover turbo diesel, '97 Discovery
#36 S130Z
S130Z
  • Members
  • PipPipPipPipPip
  • 626 posts
Posted 14 November 2010 - 05:08 PM
Here is mine......
Posted Image
Posted Image
Posted Image
Posted Image
#37 jc052685
jc052685
    Member
  • Members
  • PipPipPipPipPip
  • 771 posts
  • LocationHouston
Posted 18 November 2010 - 10:32 PM
So far so good.
74 260zt
L28et FTW!
Posted Image
#38 Tony D
Tony D
    Wiki D
  • Donating Members
  • PipPipPipPipPipPipPipPipPip
  • 9956 posts
  • LocationReno NV & Lucena Quezon, Philippines
Posted 18 November 2010 - 11:28 PM
The problem is the air volume that has to be exhausted is more when it's hot than when it's cold. This is a common problem with industrial turbos where one side BOV works after the cooler, but it must be 25 to 50% larger when placed upstream of the cooler.
Placing it there will work, but only if the additional volume of the hot air being relieved is taken into account. Otherwise, this can cause a surge issue due to inadequate relief valve sizing.
Unless your car completely stops airflow across the intercooler when the BOV opens, it's a spurious argument to justify placing the BOV before the I/C as opposed to after it.
Additionally, the reverse wave of pressure will start at the T/B, and a BOV will stop this from travelling upstream towards the turbocharger. Your flow remains 'towards' the T/B when it vents there, venting at the turbocharger will allow reverse flow through the entire system before relief...
This can manifest itself in transitional response issues.
Edited by Tony D, 18 November 2010 - 11:33 PM.
Misanthropic Anthroparion Class 5 Hoarder, aspiring to posthumous fame as my containers are cut open and the market floods with crap I've squirrelled away over the years! I endeavour to persevere...
#39 cd1105
cd1105
    Member
  • Members
  • PipPipPipPip
  • 143 posts
  • LocationOakland, C.A.
Posted 02 December 2010 - 05:57 PM
For those who are running 2.5" intercooler piping and are using the stock turbo afm and stock T3, what kind of silicone reducers are you using if any?
#40 tyler031734
tyler031734
    Member
  • Donating Members
  • PipPipPipPip
  • 142 posts
Posted 15 January 2011 - 08:39 PM
Im using a 2" to 2.5" 90* elbow right off the stock t3. 2.5" all the way to the 60mm TB. I figured it would be the smoothest way to transition from the two sizes and 2.5" inlet/outlet inter coolers are plentiful. used an ebay kit and had left over parts but I didn't go under the motor or anything fancy. My cold side is rather long as it comes from the passenger side fresh air hole in the core support, I dont like the idea of adding more bends and trading cooler air for less efficiency. One of the reasons I went bar and plate for the IC.
73 240z, hopefully new home of a vh45de.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
